[Swift-commit] r5421 - branches/release-0.93/bin
davidk at ci.uchicago.edu
Thu Dec 15 14:13:42 CST 2011
Author: davidk
Date: 2011-12-15 14:13:42 -0600 (Thu, 15 Dec 2011)
New Revision: 5421
Modified:
branches/release-0.93/bin/start-coaster-service
Log:
A few ec2 fixes
Modified: branches/release-0.93/bin/start-coaster-service
--- branches/release-0.93/bin/start-coaster-service 2011-12-14 22:04:16 UTC (rev 5420)
+++ branches/release-0.93/bin/start-coaster-service 2011-12-15 20:13:42 UTC (rev 5421)
@@ -1,4 +1,4 @@
-#!/bin/bash
+#!/bin/bash -x
# crash: Report a problem and exit
crash()
@@ -117,7 +117,7 @@
export EC2_CERT="$EC2_CERTFILE"
echo Creating instance..
- $SWIFTVMBOOT_DIR/bin/ec2-run-instances "$EC2_AMI" -t "$EC2_INSTANCE_TYPE" -n "$EC2_NODES" -k "$EC2_KEYPAIR"
+ $SWIFTVMBOOT_DIR/bin/ec2-run-instances "$EC2_AMI" -t "$EC2_INSTANCE_TYPE" -n "$EC2_NODES" -K "$EC2_KEYFILE" -C "$EC2_CERT"
SWIFTVM_INSTANCES=$( $SWIFTVMBOOT_DIR/bin/ec2-describe-instances | grep INSTANCE | grep -v terminated |awk '{print $2}' )
echo $SWIFTVM_INSTANCES >> $HOME/.swift/.swiftvm_instances
echo Waiting for nodes to boot..
@@ -126,7 +126,7 @@
while /bin/true
do
SWIFTVM_INSTANCES_AS_STRING=$( echo $SWIFTVM_INSTANCES | tr "\\n" " ")
- STATUS_LIST=$( $SWIFTVMBOOT_DIR/ec2-describe-instances $SWIFTVM_INSTANCES_AS_STRING | grep INSTANCE | grep -v terminated | awk '{print $6}' |sort -u )
+ STATUS_LIST=$( $SWIFTVMBOOT_DIR/bin/ec2-describe-instances $SWIFTVM_INSTANCES_AS_STRING | grep INSTANCE | grep -v terminated | awk '{print $6}' |sort -u )
if [ "$STATUS_LIST" == "running" ]; then
break
fi
@@ -136,7 +136,7 @@
# There is some delay between when the machines are 'running', and when system utilities like sshd are started
sleep 30
- WORKER_HOSTS=$( $SWIFTVMBOOT_DIR/ec2-describe-instances $SWIFTVM_INSTANCES_AS_STRING | grep INSTANCE | grep -v terminated | awk '{print $4}' )
+ WORKER_HOSTS=$( $SWIFTVMBOOT_DIR/bin/ec2-describe-instances $SWIFTVM_INSTANCES_AS_STRING | grep INSTANCE | grep -v terminated | awk '{print $4}' )
if [ -f "$HOME/.swift/.machines" ]; then
rm $HOME/.swift/.machines
More information about the Swift-commit
