[Swift-commit] r5412 - in branches/release-0.93: bin etc/sites
davidk at ci.uchicago.edu
Tue Dec 13 14:40:15 CST 2011
Author: davidk
Date: 2011-12-13 14:40:15 -0600 (Tue, 13 Dec 2011)
New Revision: 5412
Modified:
branches/release-0.93/bin/gensites
branches/release-0.93/bin/start-coaster-service
branches/release-0.93/bin/stop-coaster-service
branches/release-0.93/etc/sites/persistent-coasters
Log:
Add a few parameters to gensites
Start and stop coasters improvements for ec2
Updated pcoaster template
Modified: branches/release-0.93/bin/gensites
--- branches/release-0.93/bin/gensites 2011-12-13 17:42:00 UTC (rev 5411)
+++ branches/release-0.93/bin/gensites 2011-12-13 20:40:15 UTC (rev 5412)
@@ -251,7 +251,7 @@
echo "s at _EXECUTION_URL_@${EXECUTION_URL}@"
echo "s at _SERVICE_COASTERS_@${SERVICE_COASTERS:-NO_URL_GIVEN}@"
echo "s at _SERVICE_PORT_@${SERVICE_PORT:-NO_PORT_GIVEN}@"
- echo "s at _WORKERS_PER_NODE_@${WORKERS_PER_NODE}@"
+ echo "s at _JOBS_PER_NODE_@${JOBS_PER_NODE}@"
echo "s at _JOB_THROTTLE_@${JOB_THROTTLE}@"
} > $SEDFILE
Modified: branches/release-0.93/bin/start-coaster-service
--- branches/release-0.93/bin/start-coaster-service 2011-12-13 17:42:00 UTC (rev 5411)
+++ branches/release-0.93/bin/start-coaster-service 2011-12-13 20:40:15 UTC (rev 5412)
@@ -119,9 +119,10 @@
echo Creating instance..
$SWIFTVMBOOT_DIR/bin/ec2-run-instances "$EC2_AMI" -t "$EC2_INSTANCE_TYPE" -n "$EC2_NODES" -k "$EC2_KEYPAIR"
SWIFTVM_INSTANCES=$( $SWIFTVMBOOT_DIR/bin/ec2-describe-instances | grep INSTANCE | grep -v terminated |awk '{print $2}' )
- echo $SWIFTVM_INSTANCES >> $HOME/.swift/.swiftvm_instance
+ echo $SWIFTVM_INSTANCES >> $HOME/.swift/.swiftvm_instances
echo Waiting for nodes to boot..
+ # Wait until all instances are listed as running
while /bin/true
do
SWIFTVM_INSTANCES_AS_STRING=$( echo $SWIFTVM_INSTANCES | tr "\\n" " ")
@@ -137,8 +138,12 @@
WORKER_HOSTS=$( ec2-describe-instances $SWIFTVM_INSTANCES_AS_STRING | grep INSTANCE | grep -v terminated | awk '{print $4}' )
+ if [ -f "$HOME/.swift/.machines" ]; then
+ rm $HOME/.swift/.machines
+ fi
# Start worker script
- rm $HOME/.swift/.machines
+ SSH_OPTS="-i $EC2_KEYFILE -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no"
for MACHINE in $WORKER_HOSTS
do
@@ -147,18 +152,18 @@
# Enable ssh tunneling if needed
if [ "$SSH_TUNNELING" == "yes" ]; then
- ssh -i $EC2_KEYFILE -q -o StrictHostKeyChecking=no -R *:$PORT:localhost:$PORT $WORKER_USERNAME@$MACHINE sleep 999 &
+ ssh $SSH_OPTS -R *:$PORT:localhost:$PORT $WORKER_USERNAME@$MACHINE sleep 999 > /dev/null 2>&1 &
echo $! >> $PID_FILE
fi
# Copy and start worker script
- scp -i $EC2_KEYFILE -q -o StrictHostKeyChecking=no $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION > /dev/null 2>&1
+ scp $SSH_OPTS $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION > /dev/null 2>&1
echo "Starting worker on $MACHINE"
- ssh -i $EC2_KEYFILE -q -o StrictHostKeyChecking=no $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR" &
+ ssh $SSH_OPTS $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR" > /dev/null 2>&1 &
# Copy SSH key for easier access
- cat $HOME/.ssh/*.pub | ssh -i $EC2_KEYFILE $WORKER_USERNAME@$MACHINE 'umask 077; cat >> $HOME/.ssh/authorized_keys'
+ cat $HOME/.ssh/*.pub | ssh $SSH_OPTS $WORKER_USERNAME@$MACHINE 'umask 077; cat >> $HOME/.ssh/authorized_keys' > /dev/null 2>&1
done
Modified: branches/release-0.93/bin/stop-coaster-service
--- branches/release-0.93/bin/stop-coaster-service 2011-12-13 17:42:00 UTC (rev 5411)
+++ branches/release-0.93/bin/stop-coaster-service 2011-12-13 20:40:15 UTC (rev 5412)
@@ -10,7 +10,7 @@
# Location of required files
PID_FILE="$HOME/.swift/.coaster-service-pids"
-SWIFTVM_INSTANCES="$HOME/.swift/.swiftvm_instance"
+SWIFTVM_INSTANCES="$HOME/.swift/.swiftvm_instances"
# Import settings
CONFIG_FILE=$HOME/.swift/.config
@@ -39,7 +39,7 @@
rm $SWIFTVM_INSTANCES > /dev/null 2>&1
fi
-if [ "$WORKER_MODE" == "ec2" ] && [ -f "$SWIFTVM_INSTANCES" ]; then
+if [ "$WORKER_MODE" == "gp" ] && [ -f "$SWIFTVM_INSTANCES" ]; then
for INSTANCE in `cat $SWIFTVM_INSTANCES`
do
echo Stopping ec2 instance $INSTANCE...
@@ -49,6 +49,17 @@
fi
+if [ "$WORKER_MODE" == "ec2" ] && [ -f "$SWIFTVM_INSTANCES" ]; then
+ export EC2_HOME="$SWIFTVMBOOT_DIR"
+ export EC2_PRIVATE_KEY="$EC2_KEYFILE"
+ export EC2_CERT="$EC2_CERTFILE"
+ INSTANCES_AS_STRING=$( cat $SWIFTVM_INSTANCES | tr "\\n" " ")
+ $SWIFTVMBOOT_DIR/bin/ec2-terminate-instances $INSTANCES_AS_STRING
+ if [ -f "$HOME/.swift/.swiftvm_instances" ]; then
+ rm $HOME/.swift/.swiftvm_instances
+ fi
+fi
rm "$HOME/.swift/.machines"
fi
Modified: branches/release-0.93/etc/sites/persistent-coasters
--- branches/release-0.93/etc/sites/persistent-coasters 2011-12-13 17:42:00 UTC (rev 5411)
+++ branches/release-0.93/etc/sites/persistent-coasters 2011-12-13 20:40:15 UTC (rev 5412)
@@ -4,7 +4,7 @@
url="_EXECUTION_URL_"
jobmanager="local:local"/>
<profile namespace="globus" key="workerManager">passive</profile>
- <profile namespace="globus" key="workersPerNode">4</profile>
+ <profile namespace="globus" key="jobsPerNode">_JOBS_PER_NODE_</profile>
<profile key="jobThrottle" namespace="karajan">_JOB_THROTTLE_</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<filesystem provider="local" url="none" />
More information about the Swift-commit
