[Swift-commit] r5343 - trunk/docs/siteguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon Dec 5 12:14:43 CST 2011
Author: ketan
Date: 2011-12-05 12:14:43 -0600 (Mon, 05 Dec 2011)
New Revision: 5343
Modified:
   trunk/docs/siteguide/grid
Log:
documenting gwms based worker submission to grid
Modified: trunk/docs/siteguide/grid
--- trunk/docs/siteguide/grid	2011-12-05 17:24:46 UTC (rev 5342)
+++ trunk/docs/siteguide/grid	2011-12-05 18:14:43 UTC (rev 5343)
@@ -220,8 +220,8 @@
                    >& start-grid-service.out
-Starting workers on OSG sites
+Starting workers on OSG sites through GRAM
 Make sure that your "greensites" file is in the current working
 directory.
@@ -248,6 +248,26 @@
               >& swift-workers.out &
+Starting workers on OSG sites through GlideinWMS
+As an alternative to the above gram based 'direct' worker submission, a GlideinWMS based worker submission can be made. The service start step would be same as above.
+GlideinWMS is a Glidein Based WMS (Workload Management System) that works on top of condor.
+As with the case of Gram based workers, the condor directory must be pre-created and will be used by Condor to
+return stdout and stderr files from the Condor jobs, which will
+execute the wrapper script "run-workers.sh".
+NOTE: this script is current built manually, and wraps around and
+transports the worker.pl script. This needs to be automated.
+run-gwms-workers http://communicado.ci.uchicago.edu:$(cat service-0.wport) 100 >& gwms-workers.out &
+In the above commandline, one can change the number of workers by changing the second commandline argument, which is 100 in this example.
 Adding workers from TeraGrid sites
