[Swift-commit] r5329 - branches/release-0.93/bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Fri Dec 2 10:03:54 CST 2011
Author: davidk
Date: 2011-12-02 10:03:54 -0600 (Fri, 02 Dec 2011)
New Revision: 5329
Modified:
   branches/release-0.93/bin/start-coaster-service
   branches/release-0.93/bin/stop-coaster-service
Log:
Integration with Globus provision
Modified: branches/release-0.93/bin/start-coaster-service
--- branches/release-0.93/bin/start-coaster-service	2011-12-02 13:54:44 UTC (rev 5328)
+++ branches/release-0.93/bin/start-coaster-service	2011-12-02 16:03:54 UTC (rev 5329)
@@ -48,6 +48,53 @@
    done
+# EC2 workers
+start-workers-ec2()
+   PORT=$1
+   EXECUTION_URL=http://localhost:$PORT
+   if [ ! -d "$SWIFTVMBOOT_DIR" ] || [ ! -x "$SWIFTVMBOOT_DIR/bin/gp-instance-create" ]; then
+      crash "SWIFTVMBOT_DIR incorrectly defined in coaster-service.conf"
+   fi
+   SEDFILE=`mktemp`
+      echo "s at _CLUSTER-NODES_@$EC2_NODES@"
+      echo "s at _INSTANCE-TYPE_@$EC2_INSTANCE_TYPE@"
+      echo "s at _KEYPAIR_@$EC2_KEYPAIR@"
+      echo "s at _KEYFILE_@$EC2_KEYFILE@"
+      echo "s at _AMI_@$EC2_AMI@"
+   } > $SEDFILE
+   sed -f $SEDFILE < "$SWIFTVMBOOT_DIR/ec2.template.conf" > "$SWIFTVMBOOT_DIR/ec2.conf"
+   rm $SEDFILE
+   echo Creating instance..
+   "$SWIFTVMBOOT_DIR/bin/gp-instance-create" -c "$SWIFTVMBOOT_DIR/ec2.conf" | sed -r "s/\x1B\[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K]//g" | tee -a gpic.out
+   SWIFTVM_INSTANCE=`awk '{print $4}' gpic.out`
+   rm gpic.out
+   echo $SWIFTVM_INSTANCE >> $HOME/.swift/.swiftvm_instance
+   echo Starting instance..
+   "$SWIFTVMBOOT_DIR/bin/gp-instance-start" "$SWIFTVM_INSTANCE" | sed -r "s/\x1B\[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K]//g"
+   WORKER_HOSTS=`$SWIFTVMBOOT_DIR/bin/gp-instance-describe $SWIFTVM_INSTANCE|sed -r "s/\x1B\[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K]//g"|awk '{print $3}'`
+   # Start worker script
+   for MACHINE in $WORKER_HOSTS
+   do
+      # Enable ssh tunneling if needed
+      if [ "$SSH_TUNNELING" == "yes" ]; then
+         ssh -q -o StrictHostKeyChecking=no -R *:$PORT:localhost:$PORT $WORKER_USERNAME@$MACHINE sleep 999 &
+         echo $! >> $PID_FILE
+      fi
+      # Copy and start worker script
+      scp -q -o StrictHostKeyChecking=no $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION > /dev/null 2>&1
+      echo "Starting worker on $MACHINE"
+      ssh -q -o StrictHostKeyChecking=no $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR" &
+   done
 # Start SSH workers
 start-workers-ssh()
@@ -256,6 +303,9 @@
    futuregrid)
       start-workers-futuregrid $LOCAL_PORT
+   ec2)
+      start-workers-ec2 $LOCAL_PORT
       crash "Unknown WORKER_MODE. Please modify coaster-service.conf"
Modified: branches/release-0.93/bin/stop-coaster-service
--- branches/release-0.93/bin/stop-coaster-service	2011-12-02 13:54:44 UTC (rev 5328)
+++ branches/release-0.93/bin/stop-coaster-service	2011-12-02 16:03:54 UTC (rev 5329)
@@ -39,9 +39,8 @@
    done
    rm $PID_FILE > /dev/null 2>&1
 fi
-echo Done
-if [ $WORKER_MODE == "futuregrid" ] && [ -f "$SWIFTVM_INSTANCES" ]; then
+if [ "$WORKER_MODE" == "futuregrid" ] && [ -f "$SWIFTVM_INSTANCES" ]; then
    for INSTANCE in `cat $SWIFTVM_INSTANCES`
    do
       $SWIFTVMBOOT_DIR/ve/bin/cloudinitd terminate $INSTANCE
@@ -49,5 +48,13 @@
    rm $SWIFTVM_INSTANCES > /dev/null 2>&1
 fi
+if [ "$WORKER_MODE" == "ec2" ] && [ -f "$SWIFTVM_INSTANCES" ]; then
+   for INSTANCE in `cat $SWIFTVM_INSTANCES`
+   do
+      echo Stopping ec2 instance $INSTANCE...
+      $SWIFTVMBOOT_DIR/bin/gp-instance-stop $INSTANCE | sed -r "s/\x1B\[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K]//g"
+  done
+  rm $SWIFTVM_INSTANCES > /dev/null 2>&1
+fi
 popd > /dev/null 2>&1
