[Swift-commit] r5018 - branches/release-0.93/examples/tutorial
davidk at ci.uchicago.edu
Mon Aug 29 10:40:14 CDT 2011
Author: davidk
Date: 2011-08-29 10:40:14 -0500 (Mon, 29 Aug 2011)
New Revision: 5018
Added:
branches/release-0.93/examples/tutorial/README
Log:
Added README to examples/tutorial
Added: branches/release-0.93/examples/tutorial/README
--- branches/release-0.93/examples/tutorial/README (rev 0)
+++ branches/release-0.93/examples/tutorial/README 2011-08-29 15:40:14 UTC (rev 5018)
@@ -0,0 +1,42 @@
+The files in this directory are examples from the
+http://www.ci.uchicago.edu/swift/guides/release-0.93/tutorial/tutorial.html[Swift tutorial].
+hello.swift
+ The Swift hello world program. It outputs a hello world message into a file
+ called hello.txt
+parameter.swift
+ Shows how to specify parameters to procedures
+manyparam.swift
+ Similar to parameter.swift, but called multiple times with different
+ parameters
+capitalise.swift
+ Gets input from a file, capitalizes the contents, and writes to a new file
+types.swift
+ How to use user-defined structures
+arrays.swift
+ Introduction to arrays
+regexp_mapper.swift
+ Example of how to use the regular expression mapper
+fixed_array_mapper.swift
+ Example of how to use the fixed array mapper
+foreach.swift
+ Demonstrates the usage of foreach by counting words in multiple files
+if.swift
+ Handling decisions with if
+sequential_iteration.swift
+ Demonstrates the usage of iterate
+default.swift
+ Shows named parameters and default values
More information about the Swift-commit
