[Swift-commit] r4986 - provenancedb
    lgadelha at ci.uchicago.edu
    Tue Aug 16 08:42:44 CDT 2011
Author: lgadelha
Date: 2011-08-16 08:42:42 -0500 (Tue, 16 Aug 2011)
New Revision: 4986
Modified:
   provenancedb/ProvSQL.g
Log:
Minor fixes.
Modified: provenancedb/ProvSQL.g
--- provenancedb/ProvSQL.g	2011-08-11 18:22:57 UTC (rev 4985)
+++ provenancedb/ProvSQL.g	2011-08-16 13:42:42 UTC (rev 4986)
@@ -86,38 +86,42 @@
 		HashSet<String> fromRels = new HashSet<String>();
 		String fromq = " FROM ";
 		Iterator<DefaultEdge> i = joinEdges.iterator();
-		while(i.hasNext()) {
-			DefaultEdge aux = i.next();
-			// If ds_in or ds_out were not in the original select clause's relations and they are on the the joinEdges
-			// then one has to make sure that both consumed and produced datasets are considered in the join so there
-			// is no loss of information. One alternative, implemented here, is to replace these occurrences by the ds
-			// view, which is an union of ds_in and ds_out.
-			if(qrels.contains("ds_in") || qrels.contains("ds_out")) {
-				fromRels.add(schemaGraph.getEdgeSource(aux));
-				fromRels.add(schemaGraph.getEdgeTarget(aux));
-			else {
-				if(aux.equals(schemaGraph.getEdge("ds_in","proc")) ||
-						aux.equals(schemaGraph.getEdge("ds_in","ds")) ||
-						aux.equals(schemaGraph.getEdge("ds_out","proc")) ||
-						aux.equals(schemaGraph.getEdge("ds_out","ds"))) {
-					fromRels.add("ds");
-					fromRels.add("ds_use");
-					fromRels.add("proc");
-				else {
+		Iterator<String> k = qrels.iterator();
+		if(qrels.size() == 1)
+			fromRels.add(k.next());
+		else
+			while(i.hasNext()) {
+				DefaultEdge aux = i.next();
+				// If ds_in or ds_out were not in the original select clause's relations and they are on the the joinEdges
+				// then one has to make sure that both consumed and produced datasets are considered in the join so there
+				// is no loss of information. One alternative, implemented here, is to replace these occurrences by the ds
+				// view, which is an union of ds_in and ds_out.
+				if(qrels.contains("ds_in") || qrels.contains("ds_out")) {
+				else {
+					if(aux.equals(schemaGraph.getEdge("ds_in","proc")) ||
+							aux.equals(schemaGraph.getEdge("ds_in","ds")) ||
+							aux.equals(schemaGraph.getEdge("ds_out","proc")) ||
+							aux.equals(schemaGraph.getEdge("ds_out","ds"))) {
+						fromRels.add("ds");
+						fromRels.add("ds_use");
+						fromRels.add("proc");
+					else {
+						fromRels.add(schemaGraph.getEdgeSource(aux));
+						fromRels.add(schemaGraph.getEdgeTarget(aux));
 		Iterator<String> j = fromRels.iterator();
 		if(j.hasNext())
 			fromq += j.next();
 		while(j.hasNext())
 			fromq+=","+j.next();
 		return fromq;
@@ -210,9 +214,10 @@
 			schemaGraph = buildGraph();
 			joinEdges = computeJoinEdges(schemaGraph, relations);
-			hasWhereJoinExpression=true;
+			hasWhereJoinExpression=false;
 			System.out.print("SELECT " + selectClause);
 			fromClause += computeFrom(schemaGraph, joinEdges, relations);
 			System.out.print(fromClause);
@@ -234,6 +239,10 @@
 			System.out.print(whereClause);
+		'(' { System.out.print("("); }
+		squery
+		')' { System.out.print(")"); }
 selectExpression
@@ -276,8 +285,11 @@
 whereAtom
-	:	entityAttribute OP (STRING | INT | FLOAT)
-	|	entityAttribute BETWEEN STRING AND STRING;
+	:	entityAttribute
+	OP
+	(STRING | INT | FLOAT)
+	|	entityAttribute
+	BETWEEN STRING AND STRING;
 entityAttribute	:	ID (DOT ID)?;
More information about the Swift-commit
