[Swift-commit] r4938 - in SwiftApps/GOSwift: bin pykoa/tools
    jonmon at ci.uchicago.edu
    Wed Aug  3 15:52:04 CDT 2011
Author: jonmon
Date: 2011-08-03 15:52:04 -0500 (Wed, 03 Aug 2011)
New Revision: 4938
Added:
   SwiftApps/GOSwift/bin/koa-goswift-manage
   SwiftApps/GOSwift/pykoa/tools/koa_goswift_manage.py
Removed:
   SwiftApps/GOSwift/bin/koa-goswift-kill
Log:
o commit files for the goswift_manage command.  Resume is not implemented and stop is broken.
Deleted: SwiftApps/GOSwift/bin/koa-goswift-kill
--- SwiftApps/GOSwift/bin/koa-goswift-kill	2011-08-03 14:22:32 UTC (rev 4937)
+++ SwiftApps/GOSwift/bin/koa-goswift-kill	2011-08-03 20:52:04 UTC (rev 4938)
@@ -1,15 +0,0 @@
-#!/bin/sh
-if [ -z "$KOA_HOME" ]; then
-   echo "Error: KOA_HOME must be set"
-   exit 1
-fi
-if [ -s "$KOA_USER" ]; then
-   echo "Error: KOA_USER must be set"
-   exit 1
-fi
-export KOA_API_11=TRUE
-exec $KOA_HOME/pykoa/tools/koa_goswift_kill.py "$@"
\ No newline at end of file
Copied: SwiftApps/GOSwift/bin/koa-goswift-manage (from rev 4937, SwiftApps/GOSwift/bin/koa-goswift-kill)
--- SwiftApps/GOSwift/bin/koa-goswift-manage	                        (rev 0)
+++ SwiftApps/GOSwift/bin/koa-goswift-manage	2011-08-03 20:52:04 UTC (rev 4938)
@@ -0,0 +1,15 @@
+#!/bin/sh
+if [ -z "$KOA_HOME" ]; then
+   echo "Error: KOA_HOME must be set"
+   exit 1
+fi
+if [ -s "$KOA_USER" ]; then
+   echo "Error: KOA_USER must be set"
+   exit 1
+fi
+export KOA_API_11=TRUE
+exec $KOA_HOME/pykoa/tools/koa_goswift_kill.py "$@"
Added: SwiftApps/GOSwift/pykoa/tools/koa_goswift_manage.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift_manage.py	                        (rev 0)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift_manage.py	2011-08-03 20:52:04 UTC (rev 4938)
@@ -0,0 +1,64 @@
+import os
+import sys
+import commands
+import pykoa
+import pykoa.tools
+from pykoa.koaexception import cli_exception_handler
+def setup_opts(argv):
+    help_screen = """
+goswift_manage [option] <run-number>
+Stop a currently running run or resume a stopped run.
+Type 'man goswift_manage' for details. \
+    parser = pykoa.tools.get_option_parser(help_screen)
+    parser.add_option("--stop", dest="stop",
+                      default=False, action="store_true",
+                      help="Stop/resume a run my the run id")
+    (options, args) pykoa.tools.parse_args(parser, argv)
+    return (parser, options, args)
+def stop(run_id):
+    user = os.environ["USER"]
+    (status, output) = commands.getstatusoutput("ps -u "+user+" -f")
+    if status != 0:
+        sys.stderr.write("Failed to get a list of running processes\n")
+        return 1
+    ppid = ??
+    processes = [ppid]
+    lines = []
+    for line in ouput.split("\n"):
+        parsed_line = line.split(" ")
+        if ppid == parsed_line[2]:
+            processes.append(parsed_line[1])
+            ppid = int(parsed_line[1])
+    for pid in processes:
+        os.kill(pid, 9)
+    return 0
+ at cli_exception_handler
+def main( argv=sys.argv[1:] ):
+    (parser, options, args) = setup_opts(argv)
+    ret = -1
+    if len(args) != 1:
+        parser.print_help()
+        return 1
+    if options.stop:
+        ret = stop(args[0])
+    return ret
+if __name__ == "__main__":
+    rc = main()
+    sys.exit(rc)
Property changes on: SwiftApps/GOSwift/pykoa/tools/koa_goswift_manage.py
___________________________________________________________________
Added: svn:executable
More information about the Swift-commit
