[Swift-commit] r4931 - SwiftApps/GOSwift/pykoa/tools
    jonmon at ci.uchicago.edu
    Tue Aug  2 11:28:12 CDT 2011
Author: jonmon
Date: 2011-08-02 11:28:12 -0500 (Tue, 02 Aug 2011)
New Revision: 4931
Modified:
   SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
o added options that use either the trunk or stable versions of Swift for execution
o added code that dynamically finds the public ip address for the VM
  - Not sure how stable this is.
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-08-02 16:11:11 UTC (rev 4930)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-08-02 16:28:12 UTC (rev 4931)
@@ -3,6 +3,7 @@
 import re
 import sys
 import subprocess
+import commands
 import datetime
 import stat
@@ -56,6 +57,14 @@
                       default=False, action="store_true",
                       help="Run Swift as an immediate command. Watch the output that Swift produces")
+    parser.add_option("--trunk", dest="trunk",
+                      default=False, action="store_true",
+                      help="Run the development trunk version of Swift")
+    parser.add_option("--stable", dest="stable",
+                      default=True, action="store_true",
+                      help="Run the most stable release version")
     parser.add_option("-d", dest="deadline",
                       default="30m",
                       help="Set the time limit for this workflow.  " + \
@@ -267,14 +276,31 @@
         os.environ["X509_USER_KEY"] = proxyfile
         os.environ["X509_USER_PROXY"] = proxyfile
-    # Need to figure out how to get the values. Not sure how.
-    os.environ["GLOBUS_HOSTNAME"] = "174.129.136.78"
+    # Not sure this will work all the time, but this is what the internet said i could do.
+    # Need to check for errors, maybe should use the commands module for this part so I can get the status and output at the same time
+    cmd = "curl http://169.254.169.254/2009-04-04/meta-data/public-ipv4"
+    (status, host ) = commands.getstatusoutput( cmd )
+    if status != 0:
+        sys.stderr.write( "Could not determine hostname\n" )
+        return status
+    # There has to be an easier way to get the last line of a string
+    # Maybe limit the curl output from above
+    lines = []
+    for line in host.split("\n"):
+        lines.append(line)
+    host = lines[len(lines)-1]
+    os.environ["GLOBUS_HOSTNAME"] = host
     os.environ["GLOBUS_TCP_PORT_RANGE"] = "50000,51000"
     os.environ["GLOBUS_SOURCE_PORT_RANGE"] = "50000,51000"
     # Execute the script
-#    cmd = os.path.join(os.environ["HOME"], "Swift_lib/0.92", "swift")             # stable 0.92.1 release
-    cmd = os.path.join(os.environ["HOME"], "Swift_lib/trunk", "swift")             # trunk release
+    cmd = ""
+    if options.trunk:
+        cmd = os.path.join(os.environ["HOME"], "Swift_lib/trunk", "swift")             # trunk release
+    elif options.stable:
+        cmd = os.path.join(os.environ["HOME"], "Swift_lib/0.92", "swift")              # stable 0.92.1 release
     os.chdir(work_directory)
     status = -1
More information about the Swift-commit
