[Swift-commit] r4436 - SwiftApps/SwiftR
tga at ci.uchicago.edu
Fri Apr 29 13:44:55 CDT 2011
Author: tga
Date: 2011-04-29 13:44:55 -0500 (Fri, 29 Apr 2011)
New Revision: 4436
Added:
SwiftApps/SwiftR/NOTES-custom-config
Log:
Checking in notes about providing custom swift config files.
Added: SwiftApps/SwiftR/NOTES-custom-config
--- SwiftApps/SwiftR/NOTES-custom-config (rev 0)
+++ SwiftApps/SwiftR/NOTES-custom-config 2011-04-29 18:44:55 UTC (rev 4436)
@@ -0,0 +1,54 @@
+This is currently just a repository for notes about the custom swift feature.
+Pros:
+* Can use resources not supported directly by SwiftR
+* Dynamic provisioning of workers
+* Additional configurability
+* Can handle situations beyond what snowfall can.
+Cons:
+* Additional complexity of having to write own sites, etc file
+* Less responsive: typically rely on workers to fire up after apply job is started
+Use Cases:
+* Long-running script where we want to be able to dynamically procure workers
+ - don't want to be in situation where batch allocation ends and job fails
+* More complex situations - e.g. running swift on a grid or multiple sites
+We can either use a coaster provider, or a non-coaster provider (e.g. GRAM or condor)
+Coasters Provider:
+- This should be the primary use case
+- What are sensible default settings?
+- What settings do users actually need to change? Is there an easier way to handle common cases than always requiring users to write a file from scratch?
+- Problem: coasters seem to be released when swift work queue gets short at
+ end of apply job, but R could be about to release another set of jobs.
+Non-Coasters Provider:
+- Doesn't make sense to use EvalRBatchPersistent script as each job will only be run once
+- This only suits long-running data crunching
+How to configure
+system requirements:
+* R needs to be on the default path on worker nodes
+sites file:
+* Need one or more work pools
+tc data:
+* Need bash for each pool
+cf:
+* no special settings required
+Unresolved Problems:
+- Export requires shared file system currently: need to specify all input dependencies on swift command line
More information about the Swift-commit
