[Swift-commit] r4424 - trunk/libexec/log-processing
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Apr 26 16:24:10 CDT 2011
Author: wozniak
Date: 2011-04-26 16:24:10 -0500 (Tue, 26 Apr 2011)
New Revision: 4424
Modified:
   trunk/libexec/log-processing/README.txt
Log:
Update log-processing documentation
Modified: trunk/libexec/log-processing/README.txt
--- trunk/libexec/log-processing/README.txt	2011-04-26 21:07:49 UTC (rev 4423)
+++ trunk/libexec/log-processing/README.txt	2011-04-26 21:24:10 UTC (rev 4424)
@@ -4,8 +4,8 @@
 To properly generate log plots, you must enable VDL/Karajan logging.
-You should check the scripts that you intend to use to determine
-what log lines they require and ensure that you are generating
+You should check the scripts that you intend to use to determine
+what log lines they require and ensure that you are generating
 those lines via log4j.properties
 Make sure log4.properties contains:
@@ -13,88 +13,83 @@
 log4j.logger.swift=DEBUG
-Make a basic load plot from Coasters Cpu log lines
-. Generate the log (may set log4j.logger.swift=INFO for this one)
-(assuming the log is titled swift-run.log)
+Normalize event times in the log to the run start time
-. Convert the log times to Unix time
-./iso-to-secs < swift-run.log > swift-run.time
+* Generate the log, assuming the log is titled +swift-run.log+
-. Make the start time file (this contains the earliest timestamp)
-make LOG=swift-run.log start-time.tmp
+make -f libexec/log-processing/makefile.implicit swift-run.plot.norm
-or
-extract-start-time swift-run.log > start-time.tmp
-. Normalize the transition times
-./normalise-event-start-time < swift-run.time > swift-run.norm
+Make a basic load plot from Coasters Cpu log lines
+. Normalize the log.
 . Build up a load data file:
 ./cpu-job-load.pl < swift-run.norm > load.data
 . Plot with the JFreeChart-based plotter in usertools/plotter:
 lines.zsh load.cfg load.eps load.data
 Make a basic job completion plot from Coasters Cpu log lines
-Same as above, but:
-[start=5]
 . Build up a completed data file:
 ./cpu-job-completed.pl < swift-run.norm > completed.data
 lines.zsh completed.cfg completed.eps completed.data
 Make a basic Block allocation plot from Coasters Block log lines
-[start=5]
 . Build up a block allocation data file:
 ./block-level.pl < swift-run.norm > blocks.data
 lines.zsh blocks.{cfg,eps,data}
 Make a job runtime distribution plot from Coasters Cpu log lines
-[start=5]
-. Build up a job runtime file:
+. Build up a job runtime file:
 ./extract-times.pl < swift-run.norm > times.data
-. Put the job runtimes into 1-second buckets:
+. Put the job runtimes into 1-second buckets:
 ./ buckets.pl 1 times.data > buckets.data
 lines.zsh buckets.cfg buckets.eps buckets.data
