[Swift-commit] r4416 - trunk/libexec/log-processing
ketan at ci.uchicago.edu
Mon Apr 25 17:01:58 CDT 2011
Author: ketan
Date: 2011-04-25 17:01:58 -0500 (Mon, 25 Apr 2011)
New Revision: 4416
Added:
trunk/libexec/log-processing/plotfromoutput
Log:
added script that generates plot from the timestamps on the output folder
Added: trunk/libexec/log-processing/plotfromoutput
--- trunk/libexec/log-processing/plotfromoutput (rev 0)
+++ trunk/libexec/log-processing/plotfromoutput 2011-04-25 22:01:58 UTC (rev 4416)
@@ -0,0 +1,70 @@
+#!/bin/bash
+#bash script to plot the production rate of run from output data's arrival times
+if [ $# -ne 1 ]
+then
+echo "usage: $0 pathofoutputfolder "
+fi
+outputfolderpath=$1
+if [ -f output_times.txt ]
+then
+ rm -f output_times.txt
+fi
+if [ -f plot.dat ]
+then
+ rm -f plot.dat
+fi
+ls -ltr ${outputfolderpath} | tail +2 | cut -d" " -f6-7 | cut -c 9-16 | tr ' ' ':' > output_times.txt
+counter=0
+fline=`head -1 output_times.txt`
+initmin=`echo ${fline} | cut -d':' -f3`
+inithour=`echo ${fline} | cut -d':' -f2`
+initday=`echo ${fline} | cut -d':' -f1`
+indexhr=0
+hourchange="false"
+for line in `cat output_times.txt`
+do
+day=`echo ${line} | cut -d':' -f1`
+hour=`echo ${line} | cut -d':' -f2`
+min=`echo ${line} | cut -d':' -f3`
+diff=`expr ${min} - ${initmin}`
+if [ ${day} -eq ${initday} ]
+then
+ if [ ${hour} -eq ${inithour} ]
+ then
+ if [ ${diff} -ge 15 ] || [ ${hourchange} == "true" ]
+ then
+ # 15 minutes elapsed
+ echo ${indexhr} " " ${counter} >> plot.dat
+ indexhr=`expr ${indexhr} + 1`
+ counter=0
+ initmin=${min}
+ if [ ${hourchange} == "true" ]; then hourchange="false"; fi
+ else #fifteen minutes not over
+ counter=`expr ${counter} + 1`
+ fi
+ else #hour changes
+ hourchange="true"
+ inithour=${hour}
+ fi
+else #day changes
+ echo ${day}
+ echo "day has changed"
+ daychange="true"
+ initday=${day}
+fi
+done
Property changes on: trunk/libexec/log-processing/plotfromoutput
___________________________________________________________________
More information about the Swift-commit
