[Swift-commit] r4412 - www/cookbook
ketan at ci.uchicago.edu
Mon Apr 25 14:51:16 CDT 2011
Author: ketan
Date: 2011-04-25 14:51:16 -0500 (Mon, 25 Apr 2011)
New Revision: 4412
Modified:
www/cookbook/cookbook-asciidoc.html
www/cookbook/cookbook-asciidoc.txt
Log:
Modified: www/cookbook/cookbook-asciidoc.html
--- www/cookbook/cookbook-asciidoc.html 2011-04-25 19:45:42 UTC (rev 4411)
+++ www/cookbook/cookbook-asciidoc.html 2011-04-25 19:51:16 UTC (rev 4412)
@@ -1159,11 +1159,11 @@
<div class="sect1">
<h2 id="_log_processing">6. Log Processing</h2>
<div class="sectionbody">
-<div class="paragraph"><p>To properly generate log plots, you must enable VDL/Karajan logging.</p></div>
-<div class="paragraph"><p>Make sure log4.properties contains:</p></div>
+<div class="paragraph"><p>To properly generate log plots, you must enable VDL/Karajan logging. Make sure log4.properties contains:</p></div>
<div class="listingblock">
<div class="content">
-<pre><tt>log4j.logger.swift=DEBUG</tt></pre>
+<pre><tt>log4j.logger.swift=DEBUG
+log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.Cpu=DEBUG</tt></pre>
</div></div>
<div class="sect2">
<h3 id="_make_a_basic_load_plot_from_coasters_cpu_log_lines">6.1. Make a basic load plot from Coasters Cpu log lines</h3>
@@ -1291,7 +1291,7 @@
<div id="footer">
<div id="footer-text">
Version 0.92<br />
-Last updated 2011-04-25 13:03:25 CDT
+Last updated 2011-04-25 14:47:18 CDT
</div>
</div>
</body>
Modified: www/cookbook/cookbook-asciidoc.txt
--- www/cookbook/cookbook-asciidoc.txt 2011-04-25 19:45:42 UTC (rev 4411)
+++ www/cookbook/cookbook-asciidoc.txt 2011-04-25 19:51:16 UTC (rev 4412)
@@ -596,11 +596,10 @@
Log Processing
-To properly generate log plots, you must enable VDL/Karajan logging.
-Make sure log4.properties contains:
+To properly generate log plots, you must enable VDL/Karajan logging. Make sure log4.properties contains:
More information about the Swift-commit
