[Swift-commit] r4397 - in test: . beagle-tests
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Thu Apr 21 12:35:32 CDT 2011
Author: wozniak
Date: 2011-04-21 12:35:32 -0500 (Thu, 21 Apr 2011)
New Revision: 4397
Added:
   test/beagle-tests/
   test/beagle-tests/README.txt
   test/beagle-tests/pbs-test.sh
   test/beagle-tests/spin.sh
   test/beagle-tests/test-01-01-24.submit
Log:
Beagle test shell scripts
Added: test/beagle-tests/README.txt
--- test/beagle-tests/README.txt	                        (rev 0)
+++ test/beagle-tests/README.txt	2011-04-21 17:35:32 UTC (rev 4397)
@@ -0,0 +1,8 @@
+Simple tests to verify the number of
+cores given on the Beagle PBS system.
+You can run sleep or spin as the user job.
+spin.sh is good to verify that you are
+actually getting the full performance of all
+of the requested cores.
Added: test/beagle-tests/pbs-test.sh
--- test/beagle-tests/pbs-test.sh	                        (rev 0)
+++ test/beagle-tests/pbs-test.sh	2011-04-21 17:35:32 UTC (rev 4397)
@@ -0,0 +1,33 @@
+#!/bin/sh
+JOBS=$1
+DURATION=$2
+echo $JOBS $DURATION
+SPIN=/home/wozniak/pbs-tests/spin.sh
+job()
+  ID=$1
+  START=$( date +%s )
+  HOST=$( hostname )
+  # sleep ${DURATION}
+  ${SPIN} ${DURATION}
+  STOP=$( date +%s )
+  echo "${ID}: ${HOST} ${START} ${STOP}"
+for (( i=0 ; i<$JOBS ; i++ ))
+do
+  echo fork
+  job ${i} &
+done
+wait
+exit 0
Property changes on: test/beagle-tests/pbs-test.sh
___________________________________________________________________
Added: test/beagle-tests/spin.sh
--- test/beagle-tests/spin.sh	                        (rev 0)
+++ test/beagle-tests/spin.sh	2011-04-21 17:35:32 UTC (rev 4397)
@@ -0,0 +1,18 @@
+#!/bin/sh
+# On the Beagle compute node: 1 MLOOP = 22 sec
+MLOOPS=$1
+M=$(( 1024*1024 ))
+X=0
+for (( j=0 ; j<${M} ; j++ ))
+do
+  for (( i=0 ; i<${MLOOPS} ; i++ ))
+  do
+    (( X++ ))
+    (( X = X % 4000 ))
+  done
+done
+exit 0
Property changes on: test/beagle-tests/spin.sh
Added: test/beagle-tests/test-01-01-24.submit
--- test/beagle-tests/test-01-01-24.submit	                        (rev 0)
+++ test/beagle-tests/test-01-01-24.submit	2011-04-21 17:35:32 UTC (rev 4397)
@@ -0,0 +1,14 @@
+#PBS -S /bin/bash
+#PBS -N Justin
+#PBS -m n
+#PBS -A CI-MCB000021
+#PBS -l mppwidth=1,mppnppn=1,mppdepth=24
+#PBS -l walltime=00:11:00
+#PBS -q batch
+WORKER_LOGGING_LEVEL=NONE
+#PBS -v WORKER_LOGGING_LEVEL
+# # #PBS -l advres=modFTDock.47
+aprun -n 1 -N 1 -cc none -d 24 -F exclusive \
+      ${HOME}/pbs-tests/pbs-test.sh 1 1
