[Swift-commit] r4394 - trunk/tests/mpi
wozniak at ci.uchicago.edu
Thu Apr 21 11:19:57 CDT 2011
Author: wozniak
Date: 2011-04-21 11:19:57 -0500 (Thu, 21 Apr 2011)
New Revision: 4394
Modified:
trunk/tests/mpi/100-mpi-cp.c
Log:
Minor improvements to MPI test case
Modified: trunk/tests/mpi/100-mpi-cp.c
--- trunk/tests/mpi/100-mpi-cp.c 2011-04-20 22:13:51 UTC (rev 4393)
+++ trunk/tests/mpi/100-mpi-cp.c 2011-04-21 16:19:57 UTC (rev 4394)
@@ -19,6 +19,7 @@
#define max(a, b) (((a) > (b)) ? (a) : (b))
#define min(a, b) (((a) < (b)) ? (a) : (b))
+void print_help(void);
void read_input(const char *restrict filename, char** data, int* size);
void write_output(const char *restrict filename, char* data, int size);
void startup(void);
@@ -43,7 +44,11 @@
char* data;
int size;
- assert(argc == 3);
+ if (argc != 3)
+ print_help();
+ return 1;
if (mpi_rank == 0)
@@ -69,6 +74,7 @@
write_output(argv[2], data, size);
+ free(data);
MPI_Finalize();
return EXIT_SUCCESS;
@@ -84,6 +90,9 @@
fflush(NULL);
+ Allocates memory for *data
void read_input(const char* restrict filename, char** data, int* size)
char* result;
@@ -139,3 +148,8 @@
fclose(file);
+void print_help()
+ printf("usage: <input> <output>\n");
More information about the Swift-commit
