[Swift-commit] r4370 - SwiftApps/SwiftR/Swift/R
tga at ci.uchicago.edu
Wed Apr 13 14:02:50 CDT 2011
Author: tga
Date: 2011-04-13 14:02:50 -0500 (Wed, 13 Apr 2011)
New Revision: 4370
Modified:
SwiftApps/SwiftR/Swift/R/Export.R
Log:
Added quiet option for swiftExport. By default doesn't print out info about
file location.
Modified: SwiftApps/SwiftR/Swift/R/Export.R
--- SwiftApps/SwiftR/Swift/R/Export.R 2011-04-13 19:01:15 UTC (rev 4369)
+++ SwiftApps/SwiftR/Swift/R/Export.R 2011-04-13 19:02:50 UTC (rev 4370)
@@ -46,7 +46,9 @@
swiftExport(list=ls(globalenv()), file=file)
-swiftExport <- function (..., list=NULL, file=NULL) {
+swiftExport <- function (..., list=NULL, file=NULL,
+ quiet=getOption("swift.quiet")) {
+ if (is.null(quiet)) quiet <- TRUE
# List of object names (as R symbols or as strings)
# These will be passed directly to save() to be serialized
if (is.null(file)) {
@@ -59,7 +61,7 @@
# Separate directory for each new R session to keep files together
# and avoid conflicts.
- cat("Export directory: ", dir, "\n")
+ if (!quiet) cat("Export directory: ", dir, "\n")
dir.create(dir, recursive=T, showWarnings=FALSE, mode=kDIR_MODE)
# add the file, keeping a counter to use in the file name
@@ -67,7 +69,7 @@
if (is.null(expid)) expid = 0
options(.swift.exportid = expid + 1)
file <- file.path(dir, sprintf("E%.7d",expid))
- cat("Export file: ", file, "\n")
+ if (!quiet) cat("Export file: ", file, "\n")
# Keep track of files for later cleanup
expfiles <- getOption(".swift.exportfiles")
More information about the Swift-commit
