[Swift-commit] r4353 - trunk/bin
skenny at ci.uchicago.edu
Wed Apr 13 01:59:33 CDT 2011
Author: skenny
Date: 2011-04-13 01:59:33 -0500 (Wed, 13 Apr 2011)
New Revision: 4353
Modified:
trunk/bin/chxml
Log:
determines location of sites file and checks that it is well-formed
Modified: trunk/bin/chxml
--- trunk/bin/chxml 2011-04-13 05:18:04 UTC (rev 4352)
+++ trunk/bin/chxml 2011-04-13 06:59:33 UTC (rev 4353)
@@ -3,7 +3,7 @@
# given a filename chxml will ensure it is well-formed xml and
# contains essential swift attributes
-import xml.parsers.expat,sys
+import xml.parsers.expat,sys,os,commands
from glob import glob
def parsefile(file):
@@ -19,20 +19,45 @@
print 'End element:', name
endTags.append(name)
-for arg in sys.argv[1:]:
- for filename in glob(arg):
- try:
- parsefile(filename)
- print "%s is well-formed" % filename
- except Exception, e:
- print "Error: there is a problem with your sites file"
- print "%s is %s" % (filename, e)
- sys.exit()
+# parse args to find sites.xml file
+sites_file = ""
+argstr = sys.argv
+if len(argstr)<2:
+ print "please specify a sites file"
+ sys.exit()
+i = 0
+for o in argstr:
+ if o == "'-sites.file'":
+ sites_file = argstr[i+1].split("'")[1]
+ elif o == "'-config'":
+ config_file = open(argstr[i+1].split("'")[1],"r")
+ for line in config_file.readlines():
+ if line.strip().startswith('#'):
+ continue
+ if line.find("sites.file")>-1:
+ print "line is "+line
+ sites_file = line.split("=")[1].strip()
+ i = i+1
+if (sites_file == ""):
+ swift_loc = commands.getoutput("which swift")
+ swift_home = swift_loc.split("bin")[0]
+ sites_file = swift_home+"etc/sites.xml"
+ print "no sites file specified, setting to default: "+sites_file
+try:
+ parsefile(sites_file)
+ print "%s is well-formed" % sites_file
+except Exception, e:
+ print "Error: there is a problem with your sites file"
+ print "%s is %s" % (sites_file, e)
+ sys.exit()
- p = xml.parsers.expat.ParserCreate()
- p.StartElementHandler = start_element
- p.EndElementHandler = end_element
- p.ParseFile(open(filename,"r"))
+p = xml.parsers.expat.ParserCreate()
+p.StartElementHandler = start_element
+p.EndElementHandler = end_element
+p.ParseFile(open(sites_file,"r"))
config = 0
pool = 0
More information about the Swift-commit
