[Swift-commit] r4347 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu
Tue Apr 12 15:14:26 CDT 2011
Author: wozniak
Date: 2011-04-12 15:14:26 -0500 (Tue, 12 Apr 2011)
New Revision: 4347
Modified:
usertools/plotter/src/plotter/Lines.java
Log:
Enable user to turn legend off
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java 2011-04-12 19:37:04 UTC (rev 4346)
+++ usertools/plotter/src/plotter/Lines.java 2011-04-12 20:14:26 UTC (rev 4347)
@@ -37,6 +37,8 @@
static Double ymin = null;
static Double ymax = null;
+ static boolean withLegend = true;
Generate simple plot.
@param collection The x,y data.
@@ -74,8 +76,6 @@
return false;
- final boolean withLegend = true;
JFreeChart chart =
ChartFactory.createXYLineChart
(title, xlabel, ylabel, collection,
@@ -265,6 +265,7 @@
height (output image height)
xmin, xmax, ymin, ymax (auto-selected if not given)
bw (Black and white, true/false, default false)
+ legend.enabled (true/false, default true)
static void scanProperties()
@@ -290,6 +291,9 @@
tmp = properties.getProperty("bw");
if (tmp != null)
bw = Boolean.parseBoolean(tmp);
+ tmp = properties.getProperty("legend.enabled");
+ if (tmp != null)
+ withLegend = Boolean.parseBoolean(tmp);
More information about the Swift-commit
