[Swift-commit] r4343 - trunk/libexec/log-processing
wozniak at ci.uchicago.edu
Tue Apr 12 14:19:50 CDT 2011
Author: wozniak
Date: 2011-04-12 14:19:50 -0500 (Tue, 12 Apr 2011)
New Revision: 4343
Modified:
trunk/libexec/log-processing/README.txt
trunk/libexec/log-processing/block-level.pl
trunk/libexec/log-processing/cpu-job-load.pl
Log:
Correct notes
Modified: trunk/libexec/log-processing/README.txt
--- trunk/libexec/log-processing/README.txt 2011-04-12 18:27:19 UTC (rev 4342)
+++ trunk/libexec/log-processing/README.txt 2011-04-12 19:19:50 UTC (rev 4343)
@@ -16,21 +16,25 @@
. Convert the log times to Unix time
-./iso-to-secs < swift-run.log > tmp.log
+./iso-to-secs < swift-run.log > swift-run.time
. Make the start time file (this contains the earliest timestamp)
-make LOG=tmp.log start-time.tmp
+make LOG=swift-run.log start-time.tmp
+or
+extract-start-time swift-run.log > start-time.tmp
. Normalize the transition times
-./normalise-event-start-time < tmp.log > tmp.norm
+./normalise-event-start-time < swift-run.time > swift-run.norm
. Build up a load data file:
-./cpu-job-load.pl < tmp.norm > load.data
+./cpu-job-load.pl < swift-run.norm > load.data
. Plot with the JFreeChart-based plotter in usertools/plotter:
@@ -46,10 +50,26 @@
[start=5]
. Build up a completed data file:
-./cpu-job-completed.pl < tmp.norm > completed.data
+./cpu-job-completed.pl < swift-run.norm > completed.data
lines.zsh completed.cfg completed.eps completed.data
+Make a basic Block allocation plot from Coasters Block log lines
+Same as above, but:
+[start=5]
+. Build up a block allocation data file:
+./block-level.pl < swift-run.norm > blocks.data
+. Plot with the JFreeChart-based plotter in usertools/plotter:
+lines.zsh blocks.{cfg,eps,data}
Modified: trunk/libexec/log-processing/block-level.pl
--- trunk/libexec/log-processing/block-level.pl 2011-04-12 18:27:19 UTC (rev 4342)
+++ trunk/libexec/log-processing/block-level.pl 2011-04-12 19:19:50 UTC (rev 4343)
@@ -1,13 +1,13 @@
#!/usr/bin/perl
-# Accumulate the load level at each point in time
+# Accumulate the worker allocation level at each point in time
# INPUT: A Swift log file with Coasters messages:
# timestamp ... Block Starting block: workers=24 ...
# timestamp ... Block Shutting down ... (24x ...
# where timestamp is a number
-# OUTPUT: lines formatted as "timestamp level"
-# where timestamp and load are numbers,
-# level being the number of Coasters Cpus available
+# OUTPUT: lines formatted as "timestamp workers"
+# where timestamp and workers are numbers,
+# workers being the number of Coasters Cpus available
$level = 0;
Modified: trunk/libexec/log-processing/cpu-job-load.pl
--- trunk/libexec/log-processing/cpu-job-load.pl 2011-04-12 18:27:19 UTC (rev 4342)
+++ trunk/libexec/log-processing/cpu-job-load.pl 2011-04-12 19:19:50 UTC (rev 4343)
@@ -1,6 +1,7 @@
#!/usr/bin/perl
# timestamp ... Cpu ... submitting ...
# timestamp ... Cpu ... jobTerminated ...
More information about the Swift-commit
