[Swift-commit] r4323 - test/asciidoc-manual
wozniak at ci.uchicago.edu
Fri Apr 8 15:26:49 CDT 2011
Author: wozniak
Date: 2011-04-08 15:26:49 -0500 (Fri, 08 Apr 2011)
New Revision: 4323
Modified:
test/asciidoc-manual/manual.txt
Log:
Start on new index of Swift file accesses...
Modified: test/asciidoc-manual/manual.txt
--- test/asciidoc-manual/manual.txt 2011-04-08 19:57:29 UTC (rev 4322)
+++ test/asciidoc-manual/manual.txt 2011-04-08 20:26:49 UTC (rev 4323)
@@ -298,3 +298,52 @@
[start=2]
. Source +setup.sh+.
. Run +start.sh+.
+[appendix]
+Index of Swift input and output files
+This documents all files read and written by Swift and its underlying
+components.
+Inputs
+* The Swift script
+* sites.file
+* tc.file
+* log4j.properties
+* swift.properties
+* Provider properties files
+Outputs
+Standard output
+* This is the result of the Swift's log4-based logger WARN-level messages.
+* Contains output from HangChecker, ...
+Swift logfile
+* (+*.log+)
+* This is the result of other Swift logger messages.
+swift.log
+Wrapper logs
+* +*-info+ - in the work directory, also called the sitedir.
+* This contains output from +_swiftwrap+. CDM problems can often be
+ diagnosed here.
+Coasters worker logs
+* +*.log+
+PBS logs
More information about the Swift-commit
