[Swift-commit] r4307 - trunk/bin
skenny at ci.uchicago.edu skenny at ci.uchicago.edu
Thu Apr 7 21:06:25 CDT 2011
Author: skenny
Date: 2011-04-07 21:06:25 -0500 (Thu, 07 Apr 2011)
New Revision: 4307
Added:
   trunk/bin/chxml
Log:
sanity check for sites.xml
Added: trunk/bin/chxml
--- trunk/bin/chxml	                        (rev 0)
+++ trunk/bin/chxml	2011-04-08 02:06:25 UTC (rev 4307)
@@ -0,0 +1,52 @@
+#!/usr/bin/env python
+# given a filename chxml will ensure it is well-formed xml and
+# contains essential swift attributes
+import xml.parsers.expat,sys
+from glob import glob
+def parsefile(file):
+    parser = xml.parsers.expat.ParserCreate()
+    parser.ParseFile(open(file, "r"))
+startTags= []
+endTags=[]
+def start_element(name, attrs):
+    startTags.append(name)
+def end_element(name):
+    print 'End element:', name
+    endTags.append(name)
+for arg in sys.argv[1:]:
+    for filename in glob(arg):
+        try:
+            parsefile(filename)
+            print "%s is well-formed" % filename
+        except Exception, e:
+            print "Error: there is a problem with your sites file"
+            print "%s is %s" % (filename, e)
+            sys.exit()
+        p = xml.parsers.expat.ParserCreate()
+        p.StartElementHandler = start_element
+        p.EndElementHandler = end_element
+        p.ParseFile(open(filename,"r"))
+config = 0
+pool = 0
+for tag in startTags:
+    if tag=="config":
+        config = 1
+    else:
+        if tag=="pool":
+            pool= 1
+if (pool and config):
+    pass
+else:
+    print "Error: there is a problem with your sites file "+sys.argv[1]
Property changes on: trunk/bin/chxml
___________________________________________________________________
