[Swift-commit] r4270 - trunk/src/org/griphyn/vdl/engine
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Mon Apr 4 16:15:24 CDT 2011
Author: wozniak
Date: 2011-04-04 16:15:24 -0500 (Mon, 04 Apr 2011)
New Revision: 4270
Modified:
   trunk/src/org/griphyn/vdl/engine/FormalArgumentSignature.java
   trunk/src/org/griphyn/vdl/engine/Karajan.java
   trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
   trunk/src/org/griphyn/vdl/engine/VariableScope.java
Log:
Warnings fixes in vdl.engine
Modified: trunk/src/org/griphyn/vdl/engine/FormalArgumentSignature.java
--- trunk/src/org/griphyn/vdl/engine/FormalArgumentSignature.java	2011-04-04 20:30:18 UTC (rev 4269)
+++ trunk/src/org/griphyn/vdl/engine/FormalArgumentSignature.java	2011-04-04 21:15:24 UTC (rev 4270)
@@ -53,4 +53,4 @@
 	public String toString() {
 	    return type + " " + name;
\ No newline at end of file
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2011-04-04 20:30:18 UTC (rev 4269)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2011-04-04 21:15:24 UTC (rev 4270)
@@ -8,7 +8,6 @@
 import java.io.PrintStream;
 import java.util.ArrayList;
 import java.util.LinkedList;
-import java.util.List;
 import java.util.Collection;
 import java.util.HashMap;
 import java.util.HashSet;
@@ -45,24 +44,26 @@
 import org.griphyn.vdl.karajan.Loader;
 import org.griphyn.vdl.karajan.CompilationException;
 import org.griphyn.vdl.toolkit.VDLt2VDLx;
-import org.griphyn.vdl.toolkit.VDLt2VDLx.ParsingException;
 import org.safehaus.uuid.UUIDGenerator;
 import org.w3c.dom.Node;
 public class Karajan {
 	public static final Logger logger = Logger.getLogger(Karajan.class);
+	Map<String,String> stringInternMap = new HashMap<String,String>();
+	Map<Integer,String> intInternMap = new HashMap<Integer,String>();
+	Map<Float,String> floatInternMap = new HashMap<Float,String>();
+	Map<String,ProcedureSignature> proceduresMap =
+	    new HashMap<String,ProcedureSignature>();
+	Map<String,ProcedureSignature> functionsMap =
+	Map<String,Type> typesMap = new HashMap<String,Type>();
 	public static final String TEMPLATE_FILE_NAME = "Karajan.stg";
-	Map stringInternMap = new HashMap();
-	Map intInternMap = new HashMap();
-	Map floatInternMap = new HashMap();
-	Map proceduresMap = new HashMap();
-	Map functionsMap = new HashMap();
-	Map typesMap = new HashMap();
-	LinkedList importList = new LinkedList();
-	Set importedNames = new HashSet();
+	LinkedList<Program> importList = new LinkedList<Program>();
+	Set<String> importedNames = new HashSet<String>();
 	int internedIDCounter = 17000;
@@ -99,12 +100,7 @@
 		Program prog = programDoc.getProgram();
-		try {
-			me.setTemplateGroup(templates);
-		} catch(IOException ioe) {
-			throw new CompilationException("Unable to set source templates",ioe);
+		me.setTemplateGroup(templates);
 		StringTemplate code = me.program(prog);
 		out.println(code.toString());
@@ -113,7 +109,7 @@
 		throws XmlException, IOException {
 		XmlOptions options = new XmlOptions();
-		Collection errors = new ArrayList();
+		Collection<XmlError> errors = new ArrayList<XmlError>();
 		options.setErrorListener(errors);
 		options.setValidateOnSet();
 		options.setLoadLineNumbers();
@@ -126,11 +122,8 @@
 		} else {
 			logger.warn("Validation of XML intermediate file failed.");
 			logger.warn("Validation errors:");
-			Iterator i = errors.iterator();
-			while(i.hasNext()) {
-				XmlError error = (XmlError) i.next();
+			for (XmlError error : errors)
 				logger.warn(error.toString());
 			System.exit(3);
 		return programDoc;
@@ -143,7 +136,7 @@
 		functionsMap = ProcedureSignature.makeFunctionSignatures();
-	void setTemplateGroup(StringTemplateGroup tempGroup) throws IOException {
+	void setTemplateGroup(StringTemplateGroup tempGroup) {
 		m_templates = tempGroup;
@@ -270,28 +263,15 @@
 		importList.addFirst(prog);
 		processImports(prog);
-		Iterator it;
-		it=importList.iterator();
-		while(it.hasNext()) {
-			processTypes((Program)it.next(), scope);
-			statementsForSymbols((Program)it.next(), scope);
-			processProcedures((Program)it.next(), scope);
-			statements((Program)it.next(), scope);
+		for (Program program : importList)
+		    processTypes(program, scope);
+            statementsForSymbols(program, scope);
+            processProcedures(program, scope);
+            statements(program, scope);
 		generateInternedConstants(scope.bodyTemplate);
 		return scope.bodyTemplate;
@@ -547,26 +527,31 @@
-	public StringTemplate call(Call call, VariableScope scope, boolean inhibitOutput) throws CompilationException {
+	public StringTemplate call(Call call, VariableScope scope, boolean inhibitOutput)
+	throws CompilationException {
 		try {
 			// Check is called procedure declared previously
 			String procName = call.getProc().getLocalPart();
 			if (proceduresMap.get(procName) == null)
-				throw new CompilationException("Procedure " + procName + " is not declared.");
+				throw new CompilationException
+				("Procedure " + procName + " is not declared.");
 			// Check procedure arguments
 			int noOfOptInArgs = 0;
-			Map inArgs = new HashMap();
-			Map outArgs = new HashMap();
+			Map<String, FormalArgumentSignature> inArgs =
+			    new HashMap<String, FormalArgumentSignature>();
+			Map<String, FormalArgumentSignature> outArgs =
-			ProcedureSignature proc = (ProcedureSignature)proceduresMap.get(procName);
+			ProcedureSignature proc = proceduresMap.get(procName);
 			StringTemplate callST;
 			if(proc.getInvocationMode() == ProcedureSignature.INVOCATION_USERDEFINED) {
 				callST = template("callUserDefined");
 			} else if(proc.getInvocationMode() == ProcedureSignature.INVOCATION_INTERNAL) {
 				callST = template("callInternal");
 			} else {
-				throw new CompilationException("Unknown procedure invocation mode "+proc.getInvocationMode());
+				("Unknown procedure invocation mode "+proc.getInvocationMode());
 			callST.setAttribute("func", call.getProc().getLocalPart());
 			/* Does number of input arguments match */
@@ -574,8 +559,9 @@
 				if (proc.getInputArray(i).isOptional())
 					noOfOptInArgs++;
 				inArgs.put(proc.getInputArray(i).getName(), proc.getInputArray(i));
 			if (!proc.getAnyNumOfInputArgs() && (call.sizeOfInputArray() < proc.sizeOfInputArray() - noOfOptInArgs ||
 				                                 call.sizeOfInputArray() > proc.sizeOfInputArray()))
 				throw new CompilationException("Wrong number of procedure input arguments: specified " + call.sizeOfInputArray() +
 						" and should be " + proc.sizeOfInputArray());
@@ -613,7 +599,7 @@
 					if (!inArgs.containsKey(input.getBind()))
 						throw new CompilationException("Formal argument " + input.getBind() + " doesn't exist");
-					FormalArgumentSignature formalArg = (FormalArgumentSignature)inArgs.get(input.getBind());
+					FormalArgumentSignature formalArg = inArgs.get(input.getBind());
 					String formalType = formalArg.getType();
 					String actualType = datatype(argST);
 					if (!formalArg.isAnyType() && !actualType.equals(formalType))
@@ -632,7 +618,7 @@
 					StringTemplate argST = actualParameter(input, scope);
 					callST.setAttribute("inputs", argST);
-					FormalArgumentSignature formalArg = ((ProcedureSignature)proceduresMap.get(procName)).getInputArray(i);
+					FormalArgumentSignature formalArg = proceduresMap.get(procName).getInputArray(i);
@@ -648,7 +634,7 @@
 					String formalName = input.getBind();
 					if (!inArgs.containsKey(formalName))
 						throw new CompilationException("Formal argument " + formalName + " doesn't exist");
-					FormalArgumentSignature formalArg = (FormalArgumentSignature)inArgs.get(formalName);
+					FormalArgumentSignature formalArg = inArgs.get(formalName);
@@ -683,7 +669,7 @@
 					if (!outArgs.containsKey(output.getBind()))
 						throw new CompilationException("Formal argument " + output.getBind() + " doesn't exist");
-					FormalArgumentSignature formalArg = (FormalArgumentSignature)outArgs.get(output.getBind());
+					FormalArgumentSignature formalArg = outArgs.get(output.getBind());
@@ -699,7 +685,7 @@
 					StringTemplate argST = actualParameter(output, scope);
 					callST.setAttribute("outputs", argST);
-					FormalArgumentSignature formalArg =((ProcedureSignature)proceduresMap.get(procName)).getOutputArray(i);
+					FormalArgumentSignature formalArg =proceduresMap.get(procName).getOutputArray(i);
 					/* type check positional output args */
@@ -741,11 +727,8 @@
 		iterateST.setAttribute("cond", condST);
 		Object statementID = new Integer(callID++);
-		Iterator scopeIterator = innerScope.getVariableIterator();
-		while(scopeIterator.hasNext()) {
-			String v=(String) scopeIterator.next();
+		for (String v : innerScope.getVariables())
 			scope.addWriter(v, statementID, true);
 		scope.appendStatement(iterateST);
@@ -778,13 +761,10 @@
 			String inVar = (String) inST.getAttribute("var");
-				scope.addWriter(v, statementID, true);
-				if (v.equals(inVar) && !innerScope.isVariableLocallyDefined(v)) {
-				    foreachST.setAttribute("selfClose", "true");
+			for (String v : innerScope.getVariables()) {
+			    scope.addWriter(v, statementID, true);
+			    if (v.equals(inVar) && !innerScope.isVariableLocallyDefined(v))
+			        foreachST.setAttribute("selfClose", "true");
 			scope.appendStatement(foreachST);
 		} catch(CompilationException re) {
@@ -812,11 +792,8 @@
-		Iterator thenScopeIterator = innerThenScope.getVariableIterator();
-		while(thenScopeIterator.hasNext()) {
-			String v=(String) thenScopeIterator.next();
+		for (String v : innerThenScope.getVariables())
 		if (elsestat != null) {
@@ -827,11 +804,8 @@
 			statementsForSymbols(elsestat, innerElseScope);
 			statements(elsestat, innerElseScope);
-			Iterator elseScopeIterator = innerElseScope.getVariableIterator();
-			while(elseScopeIterator.hasNext()) {
-				String v=(String) elseScopeIterator.next();
+			for (String v : innerElseScope.getVariables())
 		scope.appendStatement(ifST);
@@ -855,12 +829,8 @@
 			caseStat(casestat, caseScope);
-			Iterator caseScopeIterator = caseScope.getVariableIterator();
-			while(caseScopeIterator.hasNext()) {
-				String v=(String) caseScopeIterator.next();
+			for (String v : caseScope.getVariables())
 		Default defaultstat = switchstat.getDefault();
 		if (defaultstat != null) {
@@ -869,11 +839,8 @@
 			switchST.setAttribute("sdefault", defaultScope.bodyTemplate);
 			statementsForSymbols(defaultstat, defaultScope);
 			statements(defaultstat, defaultScope);
-			Iterator defaultScopeIterator = defaultScope.getVariableIterator();
-			while(defaultScopeIterator.hasNext()) {
-				String v=(String) defaultScopeIterator.next();
+			for (String v : defaultScope.getVariables())
@@ -942,7 +909,7 @@
 	public StringTemplate function(Function func, VariableScope scope) throws CompilationException {
 		StringTemplate funcST = template("function");
 		funcST.setAttribute("name", func.getName());
-		ProcedureSignature funcSignature =  (ProcedureSignature) functionsMap.get(func.getName());
+		ProcedureSignature funcSignature =  functionsMap.get(func.getName());
 		if(funcSignature == null) {
 			throw new CompilationException("Unknown function: @"+func.getName());
@@ -1047,7 +1014,7 @@
 				internedID = "swift#int#" + i;
 				intInternMap.put(iobj, internedID);
 			} else {
-				internedID = (String)intInternMap.get(iobj);
+				internedID = intInternMap.get(iobj);
 			StringTemplate st = template("id");
 			st.setAttribute("var", internedID);
@@ -1062,7 +1029,7 @@
 				internedID = "swift#float#" + (internedIDCounter++);
 				floatInternMap.put(fobj, internedID);
 			} else {
-				internedID = (String)floatInternMap.get(fobj);
+				internedID = floatInternMap.get(fobj);
 			st.setAttribute("var",internedID);
@@ -1076,7 +1043,7 @@
 				internedID = "swift#string#" + (internedIDCounter++);
 				stringInternMap.put(s,internedID);
 			} else {
-				internedID = (String)stringInternMap.get(s);
+				internedID = stringInternMap.get(s);
@@ -1175,7 +1142,7 @@
 			// if the parent is an array, then check against
 			// the base type of the array
-boolean arrayMode = false;
+			boolean arrayMode = false;
 			if(parentType.endsWith("[]")) {
 				arrayMode=true;
 				parentType = parentType.substring(0, parentType.length() - 2);
@@ -1184,7 +1151,7 @@
 			String actualType = null;
 			// TODO this should be a map lookup of some kind?
-			Type t = (Type)typesMap.get(parentType);
+			Type t = typesMap.get(parentType);
 			TypeStructure ts = t.getTypestructure();
 			int j = 0;
@@ -1264,7 +1231,7 @@
 			StringTemplate st = function(f, scope);
 			/* Set function output type */
 			String name = f.getName();
-			ProcedureSignature funcSignature = (ProcedureSignature) functionsMap.get(name);
+			ProcedureSignature funcSignature = functionsMap.get(name);
 			if (funcSignature != null) {
 				/* Functions have only one output parameter */
 				st.setAttribute("datatype", funcSignature.getOutputArray(0).getType());
@@ -1279,7 +1246,7 @@
 		    ref.setVariableReference("swift#callintermediate");
 		    c.getOutputArray(0).set(ref);
 		    String name = c.getProc().getLocalPart();
-		    ProcedureSignature funcSignature = (ProcedureSignature) proceduresMap.get(name);
+		    ProcedureSignature funcSignature = proceduresMap.get(name);
 		    if (funcSignature == null) {
                 throw new CompilationException("Procedure " + name + " is not defined.");
@@ -1383,23 +1350,18 @@
 	public void generateInternedConstants(StringTemplate programTemplate) {
-		Iterator i;
-		i = stringInternMap.keySet().iterator();
-			String str = (String)i.next();
-			String variableName = (String)stringInternMap.get(str);
+		for (String key : stringInternMap.keySet()) {
+			String variableName = stringInternMap.get(key);
 			StringTemplate st = template("sConst");
-			st.setAttribute("innervalue",escapeQuotes(str));
+			st.setAttribute("innervalue",escapeQuotes(key));
 			StringTemplate vt = template("globalConstant");
 			vt.setAttribute("name",variableName);
 			vt.setAttribute("expr",st);
 			programTemplate.setAttribute("constants",vt);
-		i = intInternMap.keySet().iterator();
-			Integer key = (Integer)i.next();
-			String variableName = (String)intInternMap.get(key);
+	    for (Integer key : intInternMap.keySet()) {
+			String variableName = intInternMap.get(key);
 			StringTemplate st = template("iConst");
 			st.setAttribute("value",key);
@@ -1408,10 +1370,8 @@
-		i = floatInternMap.keySet().iterator();
-			Float key = (Float)i.next();
-			String variableName = (String)floatInternMap.get(key);
+	    for (Float key : floatInternMap.keySet()) {
+			String variableName = floatInternMap.get(key);
 			StringTemplate st = template("fConst");
@@ -1419,8 +1379,6 @@
 	String escapeQuotes(String in) {
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2011-04-04 20:30:18 UTC (rev 4269)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2011-04-04 21:15:24 UTC (rev 4270)
@@ -2,6 +2,8 @@
+import java.util.List;
+import java.util.Map;
 import org.globus.swift.language.FormalParameter;
@@ -9,8 +11,8 @@
 public class ProcedureSignature {
 	private String name;
-	private ArrayList inputArgs;
-	private ArrayList outputArgs;
+	private List<FormalArgumentSignature> inputArgs;
+	private List<FormalArgumentSignature> outputArgs;
 	private boolean anyNumOfInputArgs;
 	private boolean anyNumOfOutputArgs; /* this is maybe unnecessary*/
 	private int invocationMode;
@@ -23,8 +25,8 @@
 	public ProcedureSignature(String name) {
 		this.name = name;
-		inputArgs = new ArrayList();
-		outputArgs = new ArrayList();
+		inputArgs = new ArrayList<FormalArgumentSignature>();
+		outputArgs = new ArrayList<FormalArgumentSignature>();
 		anyNumOfInputArgs = false;
 		anyNumOfOutputArgs = false;
 		invocationMode = INVOCATION_USERDEFINED;
@@ -70,27 +72,26 @@
 	    new FormalArgumentSignature[0];
 	public FormalArgumentSignature[] getInputArray() {
-		return (FormalArgumentSignature[])
-		    inputArgs.toArray(FORMAL_ARGUMENT_SIGNATURE_ARRAY);
+		return inputArgs.toArray(FORMAL_ARGUMENT_SIGNATURE_ARRAY);
 	public FormalArgumentSignature[] getOutputArray() {
-		    outputArgs.toArray(FORMAL_ARGUMENT_SIGNATURE_ARRAY);
+		return outputArgs.toArray(FORMAL_ARGUMENT_SIGNATURE_ARRAY);
 	public FormalArgumentSignature getInputArray(int i) {
-		return (FormalArgumentSignature) inputArgs.get(i);
+		return inputArgs.get(i);
 	public FormalArgumentSignature getOutputArray(int i) {
-		return (FormalArgumentSignature) outputArgs.get(i);
+		return outputArgs.get(i);
 	public void setInputArgs(FormalParameter[] fp) {
 		for (int i = 0; i < fp.length; i++) {
-			FormalArgumentSignature fas = new FormalArgumentSignature(fp[i].getType().getLocalPart(),
-					                                                  fp[i].getName());
+			FormalArgumentSignature fas =
+			    new FormalArgumentSignature(fp[i].getType().getLocalPart(),
+			        fp[i].getName());
 			fas.setOptional(!fp[i].isNil());
 			this.addInputArg(fas);
@@ -114,8 +115,10 @@
 		return this.invocationMode;
-	public static HashMap makeProcedureSignatures() {
-		HashMap proceduresMap = new HashMap();
+	public static Map<String,ProcedureSignature>
+	makeProcedureSignatures() {
 		ProcedureSignature readData = new ProcedureSignature("readData");
 		FormalArgumentSignature rdInputArg = new FormalArgumentSignature(true);
@@ -164,8 +167,10 @@
 		return proceduresMap;
-	public static HashMap makeFunctionSignatures () {
-		HashMap functionsMap = new HashMap();
+	makeFunctionSignatures() {
 		ProcedureSignature arg = new ProcedureSignature("arg");
 		FormalArgumentSignature argIn1 = new FormalArgumentSignature("string");
Modified: trunk/src/org/griphyn/vdl/engine/VariableScope.java
--- trunk/src/org/griphyn/vdl/engine/VariableScope.java	2011-04-04 20:30:18 UTC (rev 4269)
+++ trunk/src/org/griphyn/vdl/engine/VariableScope.java	2011-04-04 21:15:24 UTC (rev 4270)
@@ -80,13 +80,13 @@
 	/** Set of variables (String token names) that are declared in
 	    this scope - not variables in parent scopes, though. */
-	Set variables = new HashSet();
-	Map varTypes = new HashMap();
+	Set<String> variables = new HashSet<String>();
+	Map<String, String> varTypes = new HashMap<String, String>();
 	/** Set of variables (String token names) which are global and
 	    declared in this scope (which must be a root scope). Variables
 	    in this set must also appear in the variables set. */
-	Set globals = new HashSet();
+	Set<String> globals = new HashSet<String>();
 	/** Asserts that a named variable is declared in this scope.
 	    Might also eventually contain more information about the
@@ -189,9 +189,9 @@
 	/** List of templates to be executed in sequence after the present
 	    in-preparation statement is outputted. */
-	List presentStatementPostStatements =  Collections.synchronizedList(new ArrayList());
+	List<StringTemplate> presentStatementPostStatements =  Collections.synchronizedList(new ArrayList<StringTemplate>());
-	Map variableUsage = Collections.synchronizedMap(new HashMap());
+	Map<String, Variable> variableUsage = Collections.synchronizedMap(new HashMap<String, Variable>());
 	/** indicates that the present in-preparation statement writes to the
 	    named variable. If the variable is declared in the local scope,
@@ -224,18 +224,18 @@
 // variable or we find an upwards assignment prohibition or we run
 // out of scopes
-// TODO so far this should find undelcared variables at compile time
+// TODO so far this should find undeclared variables at compile time
 // so perhaps worth making this into a separate patch if it actually
 // works
 			if(isVariableWriteable(variableName, partialWriter)) {
-				Variable variable = (Variable) variableUsage.get(variableName);
+				Variable variable = variableUsage.get(variableName);
 				if(variable == null) {
 					variable = new Variable();
 					variableUsage.put(variableName, variable);
-				List statementList = variable.writingStatements;
+				List<Object> statementList = variable.writingStatements;
 				if(!statementList.contains(closeID)) {
 					statementList.add(closeID);
@@ -264,24 +264,25 @@
 				logger.debug("thats the declaration for "+name);
 				return declST;
-		} else { // assume its a List
-			Iterator it = ((List) decls).iterator();
-				StringTemplate declST = (StringTemplate) it.next();
-				logger.debug("looking at declaration "+declST);
-try {
-				if(declST.getAttribute("name").equals(name)) {
-					logger.debug("thats the declaration for "+name);
-					return declST;
-} catch(java.util.NoSuchElementException nse) {
-					logger.debug("it so definitely wasn't in that one, we got an exception.");
-// TODO this is not a nice use of exceptions...
+		} else { // assume its a List of StringTemplate
+		     @SuppressWarnings("unchecked")
+		     List<StringTemplate> list = (List<StringTemplate>) decls;
+		     for (StringTemplate declST : list) {
+		         logger.debug("looking at declaration "+declST);
+		         try {
+		             if(declST.getAttribute("name").equals(name)) {
+		                 logger.debug("thats the declaration for "+name);
+		                 return declST;
+		         } catch(java.util.NoSuchElementException nse) {
+		             logger.debug
+		             ("it so definitely wasn't in that one, we got an exception.");
+		             // TODO this is not a nice use of exceptions...
-logger.info("UH OH - couldn't find local definition for "+name);
+		logger.info("UH OH - couldn't find local definition for "+name);
 		return null;
@@ -293,23 +294,27 @@
 		StringTemplate wrapperST = compiler.template("sequential");
 		bodyTemplate.setAttribute("statements", wrapperST);
 		wrapperST.setAttribute("statements",statementST);
-		Iterator it = presentStatementPostStatements.iterator();
+		Iterator<StringTemplate> it = presentStatementPostStatements.iterator();
 			wrapperST.setAttribute("statements", it.next());
-		presentStatementPostStatements =  Collections.synchronizedList(new ArrayList());
+		presentStatementPostStatements =  Collections.synchronizedList(new ArrayList<StringTemplate>());
 	/** Stores information about a variable that is referred to in this
 	    scope. Should probably get used for dataset marking eventually. */
 	class Variable {
-		List writingStatements =  Collections.synchronizedList(new ArrayList());
+		List<Object> writingStatements =  Collections.synchronizedList(new ArrayList<Object>());
-	Iterator getVariableIterator() {
+	Iterator<String> getVariableIterator() {
 		return variableUsage.keySet().iterator();
+	Set<String> getVariables() {
+	    return variableUsage.keySet();
 	public VariableScope getRootScope() {
 		return rootScope;
