[Swift-commit] r4265 - trunk/tests
wozniak at ci.uchicago.edu
Mon Apr 4 14:49:00 CDT 2011
Author: wozniak
Date: 2011-04-04 14:49:00 -0500 (Mon, 04 Apr 2011)
New Revision: 4265
Modified:
trunk/tests/suite.sh
Log:
More error checking and diagnostic output
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-04-04 18:27:05 UTC (rev 4264)
+++ trunk/tests/suite.sh 2011-04-04 19:49:00 UTC (rev 4265)
@@ -13,10 +13,12 @@
# have the conventional cog/modules/swift configuration,
# and you have done an ant dist, you can run
# suite.sh -a -c -g -p -s -o /tmp tests/groups/group-all-local.sh
+# or cd into /tmp and run
+# suite.sh -a -c -g -p -s cog/modules/swift/tests/groups/group-all-local.sh
# Run suite.sh -h for quick help
# When something goes wrong, find and check tests.log or use -v
-# Code is checked out into TOPDIR (PWD by default) (PATH is not used)
+# Code is checked out into TOPDIR (PWD by default) (PATH is overridden)
# The variables COG_VERSION and SWIFT_VERSION must be set for code checkout
# e.g. COG_VERSION=branches/4.1.8, SWIFT_VERSION=branches/release-0.92
# Swift is compiled and installed in its source tree
@@ -991,8 +993,10 @@
source $GROUPLISTFILE || exit 1
cd $TOPDIR
+[ $? != 0 ] && crash "Could not use given TOPDIR: $TOPDIR"
mkdir -p $RUNDIR
-[ $? != 0 ] && echo "Could not mkdir: $RUNDIR" && exit 1
+[ $? != 0 ] && crash "Could not mkdir: $RUNDIR"
date > $LOG
@@ -1025,6 +1029,15 @@
TESTNAME="Compile"
start_row
+# Exit early if the Swift directory is not there
+if [[ ! -d $TOPDIR/cog/modules/swift ]]
+then
+ echo "Could not find swift source directory"
+ echo "TOPDIR: $TOPDIR"
+ echo "Looked for $TOPDIR/cog/modules/swift"
+ crash
+fi
test_exec cd $TOPDIR/cog/modules/swift
if (( $CLEAN )); then
test_exec rm -rf dist
More information about the Swift-commit
