[Swift-commit] r4252 - trunk/src/org/griphyn/vdl/engine
wozniak at ci.uchicago.edu
Sun Apr 3 21:53:36 CDT 2011
Author: wozniak
Date: 2011-04-03 21:53:35 -0500 (Sun, 03 Apr 2011)
New Revision: 4252
Modified:
trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
Fix spelling
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java 2011-04-03 21:25:44 UTC (rev 4251)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java 2011-04-04 02:53:35 UTC (rev 4252)
@@ -51,9 +51,9 @@
public class Karajan {
public static final Logger logger = Logger.getLogger(Karajan.class);
- public static final String TEMPLATE_FILE_NAME = "Karajan.stg";
+ public static final String TEMPLATE_FILE_NAME = "Karajan.stg";
Map stringInternMap = new HashMap();
Map intInternMap = new HashMap();
Map floatInternMap = new HashMap();
@@ -63,7 +63,7 @@
LinkedList importList = new LinkedList();
Set importedNames = new HashSet();
int internedIDCounter = 17000;
/** an arbitrary statement identifier. Start at some high number to
@@ -80,7 +80,7 @@
compile(args[0], System.out);
public static void compile(String in, PrintStream out) throws CompilationException {
Karajan me = new Karajan();
StringTemplateGroup templates;
@@ -109,7 +109,7 @@
out.println(code.toString());
- public static ProgramDocument parseProgramXML(String defs)
+ public static ProgramDocument parseProgramXML(String defs)
throws XmlException, IOException {
XmlOptions options = new XmlOptions();
@@ -137,7 +137,7 @@
public Karajan() {
- // Built-in procedures
+ // Built-in procedures
proceduresMap = ProcedureSignature.makeProcedureSignatures();
// Built-in functions
functionsMap = ProcedureSignature.makeFunctionSignatures();
@@ -168,7 +168,7 @@
String lib_path = System.getenv("SWIFT_LIB");
String swiftfilename = moduleToImport+".swift";
String xmlfilename = moduleToImport+".xml";
File local = new File(swiftfilename);
if( !( lib_path == null || local.exists() ) )
@@ -176,9 +176,9 @@
while(st.hasMoreTokens())
String path = st.nextToken();
- String lib_script_location = path + "/" + swiftfilename;
+ String lib_script_location = path + "/" + swiftfilename;
File tmp = new File(lib_script_location);
if(tmp.exists())
swiftfilename = path + "/" + swiftfilename;
@@ -186,9 +186,9 @@
moduleToImport = path + "/" + moduleToImport;
break;
try {
VDLt2VDLx.compile(new FileInputStream(swiftfilename),new PrintStream(new FileOutputStream(xmlfilename)));
logger.debug("Compiled. Now reading in compiled XML for "+moduleToImport);
@@ -226,15 +226,15 @@
checkIsTypeDefined(typeAlias);
st.setAttribute("type", typeAlias);
TypeStructure ts = theType.getTypestructure();
- for (int j = 0; j < ts.sizeOfMemberArray(); j++) {
+ for (int j = 0; j < ts.sizeOfMemberArray(); j++) {
TypeRow tr = ts.getMemberArray(j);
StringTemplate stMember = template("memberdefinition");
stMember.setAttribute("name", tr.getMembername());
stMember.setAttribute("type", tr.getMembertype());
st.setAttribute("members", stMember);
scope.bodyTemplate.setAttribute("types", st);
@@ -249,10 +249,10 @@
Procedure proc = prog.getProcedureArray(i);
ProcedureSignature ps = new ProcedureSignature(proc.getName());
ps.setInputArgs(proc.getInputArray());
- ps.setOutputArgs(proc.getOutputArray());
+ ps.setOutputArgs(proc.getOutputArray());
proceduresMap.put(proc.getName(), ps);
for (int i = 0; i < prog.sizeOfProcedureArray(); i++) {
procedure(proc, scope);
@@ -276,7 +276,7 @@
while(it.hasNext()) {
processTypes((Program)it.next(), scope);
it=importList.iterator();
statementsForSymbols((Program)it.next(), scope);
@@ -331,12 +331,12 @@
if ((bind = proc.getBinding()) != null) {
binding(bind, procST, innerScope);
- else {
+ else {
VariableScope compoundScope = new VariableScope(this, innerScope);
compoundScope.bodyTemplate = procST;
- statementsForSymbols(proc, compoundScope);
- statements(proc, compoundScope);
+ statementsForSymbols(proc, compoundScope);
+ statements(proc, compoundScope);
public StringTemplate parameter(FormalParameter param, VariableScope scope) throws CompilationException {
@@ -418,7 +418,7 @@
if (param.getAbstractExpression().getDomNode().getNodeName().equals("stringConstant")) {
StringTemplate valueST = template("sConst");
valueST.setAttribute("innervalue", param.getAbstractExpression().getDomNode().getFirstChild().getNodeValue());
- paramST.setAttribute("expr",valueST);
+ paramST.setAttribute("expr",valueST);
else {
paramST.setAttribute("expr",variableReferenceST);
@@ -446,10 +446,10 @@
scope.bodyTemplate.setAttribute("declarations", variableST);
- void checkIsTypeDefined(String type) throws CompilationException {
+ void checkIsTypeDefined(String type) throws CompilationException {
while (type.length() > 2 && type.substring(type.length() - 2).equals("[]"))
- type = type.substring(0, type.length() - 2);
- if (!type.equals("int") && !type.equals("float") && !type.equals("string")
+ type = type.substring(0, type.length() - 2);
+ if (!type.equals("int") && !type.equals("float") && !type.equals("string")
&& !type.equals("boolean") && !type.equals("external")) {
boolean typeDefined = typesMap.containsKey(type);
if (!typeDefined)
@@ -549,16 +549,16 @@
public StringTemplate call(Call call, VariableScope scope, boolean inhibitOutput) throws CompilationException {
try {
- // Check is called procedure declared previously
+ // Check is called procedure declared previously
String procName = call.getProc().getLocalPart();
if (proceduresMap.get(procName) == null)
throw new CompilationException("Procedure " + procName + " is not declared.");
- // Check procedure arguments
+ // Check procedure arguments
int noOfOptInArgs = 0;
Map inArgs = new HashMap();
Map outArgs = new HashMap();
ProcedureSignature proc = (ProcedureSignature)proceduresMap.get(procName);
StringTemplate callST;
if(proc.getInvocationMode() == ProcedureSignature.INVOCATION_USERDEFINED) {
@@ -569,48 +569,48 @@
throw new CompilationException("Unknown procedure invocation mode "+proc.getInvocationMode());
callST.setAttribute("func", call.getProc().getLocalPart());
- /* Does number of input arguments match */
+ /* Does number of input arguments match */
for (int i = 0; i < proc.sizeOfInputArray(); i++) {
if (proc.getInputArray(i).isOptional())
noOfOptInArgs++;
inArgs.put(proc.getInputArray(i).getName(), proc.getInputArray(i));
- if (!proc.getAnyNumOdInputArgs() && (call.sizeOfInputArray() < proc.sizeOfInputArray() - noOfOptInArgs ||
+ if (!proc.getAnyNumOfInputArgs() && (call.sizeOfInputArray() < proc.sizeOfInputArray() - noOfOptInArgs ||
call.sizeOfInputArray() > proc.sizeOfInputArray()))
- throw new CompilationException("Wrong number of procedure input arguments: specified " + call.sizeOfInputArray() +
+ throw new CompilationException("Wrong number of procedure input arguments: specified " + call.sizeOfInputArray() +
" and should be " + proc.sizeOfInputArray());
/* Does number of output arguments match - no optional output args */
for (int i = 0; i < proc.sizeOfOutputArray(); i++) {
outArgs.put(proc.getOutputArray(i).getName(), proc.getOutputArray(i));
- if (!proc.getAnyNumOdOutputArgs() && (call.sizeOfOutputArray() != proc.sizeOfOutputArray()))
- throw new CompilationException("Wrong number of procedure output arguments: specified " + call.sizeOfOutputArray() +
+ if (!proc.getAnyNumOfOutputArgs() && (call.sizeOfOutputArray() != proc.sizeOfOutputArray()))
+ throw new CompilationException("Wrong number of procedure output arguments: specified " + call.sizeOfOutputArray() +
" and should be " + proc.sizeOfOutputArray());
boolean keywordArgsInput = true;
for (int i = 0; i < call.sizeOfInputArray(); i++) {
if (!call.getInputArray(i).isSetBind()) {
keywordArgsInput = false;
break;
- if (proc.getAnyNumOdInputArgs()) {
+ if (proc.getAnyNumOfInputArgs()) {
/* If procedure can have any number of input args, we don't do typechecking */
- for (int i = 0; i < call.sizeOfInputArray(); i++) {
+ for (int i = 0; i < call.sizeOfInputArray(); i++) {
ActualParameter input = call.getInputArray(i);
StringTemplate argST = actualParameter(input, scope);
callST.setAttribute("inputs", argST);
- } else if (keywordArgsInput) {
- /* if ALL arguments are specified by name=value */
+ } else if (keywordArgsInput) {
+ /* if ALL arguments are specified by name=value */
int noOfMandArgs = 0;
if (!inArgs.containsKey(input.getBind()))
throw new CompilationException("Formal argument " + input.getBind() + " doesn't exist");
FormalArgumentSignature formalArg = (FormalArgumentSignature)inArgs.get(input.getBind());
@@ -619,11 +619,11 @@
if (!formalArg.isAnyType() && !actualType.equals(formalType))
throw new CompilationException("Wrong type for parameter number " + i +
", expected " + formalType + ", got " + actualType);
if (!formalArg.isOptional())
noOfMandArgs++;
- if (!proc.getAnyNumOdInputArgs() && noOfMandArgs < proc.sizeOfInputArray() - noOfOptInArgs)
+ if (!proc.getAnyNumOfInputArgs() && noOfMandArgs < proc.sizeOfInputArray() - noOfOptInArgs)
throw new CompilationException("Mandatory argument missing");
} else { /* Positional arguments */
/* Checking types of mandatory arguments */
@@ -631,21 +631,21 @@
FormalArgumentSignature formalArg = ((ProcedureSignature)proceduresMap.get(procName)).getInputArray(i);
- String formalType = formalArg.getType();
+ String formalType = formalArg.getType();
String actualType = datatype(argST);
- ", expected " + formalType + ", got " + actualType);
+ ", expected " + formalType + ", got " + actualType);
/* Checking types of optional arguments */
for (int i = proc.sizeOfInputArray() - noOfOptInArgs; i < call.sizeOfInputArray(); i++) {
- String formalName = input.getBind();
+ String formalName = input.getBind();
if (!inArgs.containsKey(formalName))
throw new CompilationException("Formal argument " + formalName + " doesn't exist");
FormalArgumentSignature formalArg = (FormalArgumentSignature)inArgs.get(formalName);
@@ -653,20 +653,20 @@
throw new CompilationException("Wrong type for parameter " + formalName +
boolean keywordArgsOutput = true;
for (int i = 0; i < call.sizeOfOutputArray(); i++) {
if (!call.getOutputArray(i).isSetBind()) {
keywordArgsOutput = false;
break;
- if (proc.getAnyNumOdOutputArgs()) {
+ if (proc.getAnyNumOfOutputArgs()) {
/* If procedure can have any number of output args, we don't do typechecking */
- for (int i = 0; i < call.sizeOfOutputArray(); i++) {
+ for (int i = 0; i < call.sizeOfOutputArray(); i++) {
ActualParameter output = call.getOutputArray(i);
StringTemplate argST = actualParameter(output, scope);
callST.setAttribute("outputs", argST);
@@ -674,13 +674,13 @@
scope.addWriter(rootvar, new Integer(callID++), rootVariableIsPartial(call.getOutputArray(i).getAbstractExpression()));
- if (keywordArgsOutput) {
+ if (keywordArgsOutput) {
if (!outArgs.containsKey(output.getBind()))
throw new CompilationException("Formal argument " + output.getBind() + " doesn't exist");
FormalArgumentSignature formalArg = (FormalArgumentSignature)outArgs.get(output.getBind());
@@ -689,30 +689,30 @@
throw new CompilationException("Wrong type for output parameter number " + i +
String rootvar = abstractExpressionToRootVariable(call.getOutputArray(i).getAbstractExpression());
- FormalArgumentSignature formalArg =((ProcedureSignature)proceduresMap.get(procName)).getOutputArray(i);
+ FormalArgumentSignature formalArg =((ProcedureSignature)proceduresMap.get(procName)).getOutputArray(i);
/* type check positional output args */
if (!inhibitOutput) {
scope.appendStatement(callST);
@@ -756,20 +756,20 @@
StringTemplate foreachST = template("foreach");
foreachST.setAttribute("var", foreach.getVar());
foreachST.setAttribute("line", foreach.getSrc().substring(foreach.getSrc().indexOf(' ') + 1));
XmlObject in = foreach.getIn().getAbstractExpression();
StringTemplate inST = expressionToKarajan(in, scope);
foreachST.setAttribute("in", inST);
String inType = datatype(inST);
if (inType.length() < 2 || !inType.substring(inType.length() - 2).equals("[]"))
throw new CompilationException("You can iterate through an array structure only");
- String varType = inType.substring(0, inType.length() - 2);
+ String varType = inType.substring(0, inType.length() - 2);
innerScope.addVariable(foreach.getVar(), varType);
foreachST.setAttribute("indexVar", foreach.getIndexVar());
if(foreach.getIndexVar() != null) {
innerScope.addVariable(foreach.getIndexVar(), "int");
innerScope.bodyTemplate = foreachST;
@@ -799,7 +799,7 @@
ifST.setAttribute("condition", conditionST.toString());
if (!datatype(conditionST).equals("boolean"))
throw new CompilationException ("Condition in if statement has to be of boolean type.");
Then thenstat = ifstat.getThen();
Else elsestat = ifstat.getElse();
@@ -842,7 +842,7 @@
scope.bodyTemplate.setAttribute("statements", switchST);
StringTemplate conditionST = expressionToKarajan(switchstat.getAbstractExpression(), scope);
switchST.setAttribute("condition", conditionST.toString());
/* TODO can switch statement can be anything apart from int and float ? */
if (!datatype(conditionST).equals("int") && !datatype(conditionST).equals("float"))
throw new CompilationException("Condition in switch statements has to be of numeric type.");
@@ -852,7 +852,7 @@
VariableScope caseScope = new VariableScope(this, scope);
caseScope.bodyTemplate = new StringTemplate("case");
switchST.setAttribute("cases", caseScope.bodyTemplate);
caseStat(casestat, caseScope);
Iterator caseScopeIterator = caseScope.getVariableIterator();
@@ -911,8 +911,8 @@
StringTemplate argumentST = expressionToKarajan(argument, scope);
String type = datatype(argumentST);
if(type.equals("string") || type.equals("string[]")
- || type.equals("int") || type.equals("float")
- || type.equals("int[]") || type.equals("float[]")
+ || type.equals("int") || type.equals("float")
+ || type.equals("int[]") || type.equals("float[]")
|| type.equals("boolean") || type.equals("boolean[]")) {
appST.setAttribute("arguments", argumentST);
} else {
@@ -942,7 +942,7 @@
public StringTemplate function(Function func, VariableScope scope) throws CompilationException {
StringTemplate funcST = template("function");
funcST.setAttribute("name", func.getName());
- ProcedureSignature funcSignature = (ProcedureSignature) functionsMap.get(func.getName());
+ ProcedureSignature funcSignature = (ProcedureSignature) functionsMap.get(func.getName());
if(funcSignature == null) {
throw new CompilationException("Unknown function: @"+func.getName());
@@ -950,28 +950,28 @@
for (int i = 0; i < funcSignature.sizeOfInputArray(); i++) {
if (funcSignature.getInputArray(i).isOptional())
- noOfOptInArgs++;
- if (!funcSignature.getAnyNumOdInputArgs() &&
+ noOfOptInArgs++;
+ if (!funcSignature.getAnyNumOfInputArgs() &&
(arguments.length < funcSignature.sizeOfInputArray() - noOfOptInArgs ||
arguments.length > funcSignature.sizeOfInputArray()))
- throw new CompilationException("Wrong number of function input arguments: specified " +
+ throw new CompilationException("Wrong number of function input arguments: specified " +
arguments.length + " and should be " + funcSignature.sizeOfInputArray());
for(int i = 0; i < arguments.length; i++ ) {
StringTemplate exprST = expressionToKarajan(arguments[i], scope);
funcST.setAttribute("args", exprST);
/* Type check of function arguments */
- if (!funcSignature.getAnyNumOdInputArgs()) {
+ if (!funcSignature.getAnyNumOfInputArgs()) {
String actualType = datatype(exprST);
FormalArgumentSignature fas = funcSignature.getInputArray(i);
- if (!fas.isAnyType() && !fas.getType().equals(actualType))
+ if (!fas.isAnyType() && !fas.getType().equals(actualType))
", expected " + fas.getType() + ", got " + actualType);
return funcST;
@@ -1015,7 +1015,7 @@
st.setAttribute("right", rightST);
if (datatype(leftST).equals("boolean") && datatype(rightST).equals("boolean"))
st.setAttribute("datatype", "boolean");
- else
+ else
throw new CompilationException("Or operation can only be applied to parameters of type boolean.");
return st;
} else if (expressionQName.equals(AND_EXPR)) {
@@ -1028,7 +1028,7 @@
- else
+ else
throw new CompilationException("And operation can only be applied to parameters of type boolean.");
return st;
} else if (expressionQName.equals(BOOL_EXPR)) {
@@ -1036,7 +1036,7 @@
boolean b = xmlBoolean.getBooleanValue();
StringTemplate st = template("bConst");
st.setAttribute("value",""+b);
- st.setAttribute("datatype", "boolean");
+ st.setAttribute("datatype", "boolean");
return st;
} else if (expressionQName.equals(INT_EXPR)) {
XmlInt xmlInt = (XmlInt) expression;
@@ -1089,9 +1089,9 @@
StringTemplate rightST = expressionToKarajan(o.getAbstractExpressionArray(1), scope);
st.setAttribute("op", o.getOp());
st.setAttribute("left", leftST);
- st.setAttribute("right", rightST);
- checkTypesInCondExpr(o.getOp(), datatype(leftST), datatype(rightST), st);
+ st.setAttribute("right", rightST);
+ checkTypesInCondExpr(o.getOp(), datatype(leftST), datatype(rightST), st);
return st;
} else if (expressionQName.equals(ARITH_EXPR)) {
LabelledBinaryOperator o = (LabelledBinaryOperator) expression;
@@ -1100,9 +1100,9 @@
StringTemplate leftST = expressionToKarajan(o.getAbstractExpressionArray(0), scope);
- checkTypesInArithmExpr(o.getOp(), datatype(leftST), datatype(rightST), st);
+ checkTypesInArithmExpr(o.getOp(), datatype(leftST), datatype(rightST), st);
return st;
} else if (expressionQName.equals(UNARY_NEGATION_EXPR)) {
UnlabelledUnaryOperator e = (UnlabelledUnaryOperator) expression;
@@ -1121,7 +1121,7 @@
st.setAttribute("exp", expST);
if (datatype(expST).equals("boolean"))
- else
+ else
throw new CompilationException("Not operation can only be applied to parameter of type boolean.");
return st;
} else if (expressionQName.equals(VARIABLE_REFERENCE_EXPR)) {
@@ -1133,7 +1133,7 @@
StringTemplate st = template("id");
st.setAttribute("var", s);
String actualType;
actualType = scope.getVariableType(s);
st.setAttribute("datatype", actualType);
return st;
@@ -1156,8 +1156,8 @@
StringTemplate newst = template("extractarrayelement");
newst.setAttribute("arraychild", arrayST);
newst.setAttribute("parent", parentST);
- String arrayType = datatype(parentST);
+ String arrayType = datatype(parentST);
if (datatype(arrayST).equals("int")) {
newst.setAttribute("datatype", arrayType.substring(0, arrayType.length()-2));
} else {
@@ -1168,7 +1168,7 @@
} else if (expressionQName.equals(STRUCTURE_MEMBER_EXPR)) {
StructureMember sm = (StructureMember) expression;
StringTemplate parentST = expressionToKarajan(sm.getAbstractExpression(), scope);
String parentType = datatype(parentST);
@@ -1181,7 +1181,7 @@
parentType = parentType.substring(0, parentType.length() - 2);
- String actualType = null;
+ String actualType = null;
// TODO this should be a map lookup of some kind?
Type t = (Type)typesMap.get(parentType);
@@ -1194,7 +1194,7 @@
break;
if (j == ts.sizeOfMemberArray())
- throw new CompilationException("No member " + sm.getMemberName() + " in structure " + parentType);
+ throw new CompilationException("No member " + sm.getMemberName() + " in structure " + parentType);
if (actualType == null) {
throw new CompilationException("Type " + parentType + " is not defined.");
@@ -1204,13 +1204,13 @@
StringTemplate newst = template("slicearray");
newst.setAttribute("memberchild", sm.getMemberName());
- newst.setAttribute("datatype", actualType);
+ newst.setAttribute("datatype", actualType);
return newst;
} else {
StringTemplate newst = template("extractstructelement");
return newst;
// TODO the template layout for this and ARRAY_SUBSCRIPT are
@@ -1227,7 +1227,7 @@
elemType = datatype(elemST);
else if (!elemType.equals(datatype(elemST)))
throw new CompilationException("Wrong array element type.");
- st.setAttribute("elements", elemST);
+ st.setAttribute("elements", elemST);
if (elemType.equals(""))
logger.warn("WARNING: Empty array constant");
@@ -1245,18 +1245,18 @@
stepST = expressionToKarajan(range.getAbstractExpressionArray(2), scope);
st.setAttribute("step", stepST);
String fromType = datatype(fromST);
String toType = datatype(toST);
if (stepST == null && (!fromType.equals("int") || !toType.equals("int")))
throw new CompilationException("Step in range specification can be omitted only when from and to types are int");
- else if ((fromType.equals("int") && toType.equals("int")) &&
+ else if ((fromType.equals("int") && toType.equals("int")) &&
(stepST == null || datatype(stepST).equals("int")))
st.setAttribute("datatype", "int[]");
- else if (fromType.equals("float") && toType.equals("float") &&
+ else if (fromType.equals("float") && toType.equals("float") &&
datatype(stepST).equals("float"))
st.setAttribute("datatype", "float[]");
- else
+ else
throw new CompilationException("Range can only be specified with numeric types");
return st;
} else if (expressionQName.equals(FUNCTION_EXPR)) {
@@ -1273,25 +1273,25 @@
return st;
} else if (expressionQName.equals(CALL_EXPR)) {
Call c = (Call) expression;
- c.addNewOutput();
+ c.addNewOutput();
VariableScope subscope = new VariableScope(this, scope);
VariableReferenceDocument ref = VariableReferenceDocument.Factory.newInstance();
ref.setVariableReference("swift#callintermediate");
c.getOutputArray(0).set(ref);
String name = c.getProc().getLocalPart();
ProcedureSignature funcSignature = (ProcedureSignature) proceduresMap.get(name);
if (funcSignature == null) {
throw new CompilationException("Procedure " + name + " is not defined.");
if (funcSignature.sizeOfOutputArray() != 1) {
throw new CompilationException("Procedure " + name + " must have exactly one " +
"return value to be used in an expression.");
StringTemplate call = template("callexpr");
String type = funcSignature.getOutputArray(0).getType();
subscope.addInternalVariable("swift#callintermediate", type);
@@ -1303,7 +1303,7 @@
} else {
throw new CompilationException("unknown expression implemented by class "+expression.getClass()+" with node name "+expressionQName +" and with content "+expression);
- // perhaps one big throw catch block surrounding body of this method
+ // perhaps one big throw catch block surrounding body of this method
// which shows Compiler Exception and line number of error
@@ -1311,31 +1311,31 @@
if (left.equals(right))
- else
+ else
throw new CompilationException("Conditional operator can only be applied to parameters of same type.");
- if ((op.equals("==") || op.equals("!=")) && !left.equals("int") && !left.equals("float")
+ if ((op.equals("==") || op.equals("!=")) && !left.equals("int") && !left.equals("float")
&& !left.equals("string") && !left.equals("boolean"))
- throw new CompilationException("Conditional operator " + op +
+ throw new CompilationException("Conditional operator " + op +
" can only be applied to parameters of type int, float, string and boolean.");
- if ((op.equals("<=") || op.equals(">=") || op.equals(">") || op.equals("<"))
+ if ((op.equals("<=") || op.equals(">=") || op.equals(">") || op.equals("<"))
&& !left.equals("int") && !left.equals("float") && !left.equals("string"))
" can only be applied to parameters of type int, float and string.");
void checkTypesInArithmExpr(String op, String left, String right, StringTemplate st)
st.setAttribute("datatype", left);
- else
+ else
throw new CompilationException("Arithmetic operation can only be applied to parameters of same type.");
if (op.equals("+") && !left.equals("int") && !left.equals("float") && !left.equals("string"))
throw new CompilationException("Arithmetic operation + can only be applied to parameters of type int, float and string.");
if ((op.equals("-") || op.equals("*")) && !left.equals("int") && !left.equals("float"))
- throw new CompilationException("Arithmetic operation " + op +
+ throw new CompilationException("Arithmetic operation " + op +
" can only be applied to parameters of type int and float.");
if (op.equals("/") && !left.equals("float"))
throw new CompilationException("Arithmetic operation / can only be applied to parameters of type float.");
@@ -1426,15 +1426,15 @@
String escapeQuotes(String in) {
return in.replaceAll("\"", """);
String datatype(StringTemplate st) {
String result = null;
- try {
+ try {
result = st.getAttribute("datatype").toString();
- catch (Exception e) {
- throw new RuntimeException("Not typed properly: " + st);
+ catch (Exception e) {
+ throw new RuntimeException("Not typed properly: " + st);
- return result;
+ return result;
More information about the Swift-commit
