[Swift-commit] r3724 - trunk/tests/cdm
noreply at svn.ci.uchicago.edu
Wed Nov 24 11:18:13 CST 2010
Author: wozniak
Date: 2010-11-24 11:18:12 -0600 (Wed, 24 Nov 2010)
New Revision: 3724
Added:
trunk/tests/cdm/401-external.check.sh
trunk/tests/cdm/401-external.clean.sh
trunk/tests/cdm/401-external.setup.sh
trunk/tests/cdm/401-external.swift
Removed:
trunk/tests/cdm/210-external.check.sh
trunk/tests/cdm/210-external.clean.sh
trunk/tests/cdm/210-external.setup.sh
trunk/tests/cdm/210-external.swift
Modified:
trunk/tests/cdm/README.txt
Log:
Move 210-external to 401-external
Deleted: trunk/tests/cdm/210-external.check.sh
--- trunk/tests/cdm/210-external.check.sh 2010-11-24 17:03:13 UTC (rev 3723)
+++ trunk/tests/cdm/210-external.check.sh 2010-11-24 17:18:12 UTC (rev 3724)
@@ -1,11 +0,0 @@
-#!/bin/sh
-set -x
-cat external.out || exit 1
-rm -v external.out || exit 1
-grep $( uname -m ) 210-input.txt || exit 1
-grep $( uname -m ) 210-output.txt || exit 1
-exit 0
Deleted: trunk/tests/cdm/210-external.clean.sh
--- trunk/tests/cdm/210-external.clean.sh 2010-11-24 17:03:13 UTC (rev 3723)
+++ trunk/tests/cdm/210-external.clean.sh 2010-11-24 17:18:12 UTC (rev 3724)
@@ -1,7 +0,0 @@
-#!/bin/sh
-set -x
-rm -v 210-input.txt 210-output.txt
-exit 0
Deleted: trunk/tests/cdm/210-external.setup.sh
--- trunk/tests/cdm/210-external.setup.sh 2010-11-24 17:03:13 UTC (rev 3723)
+++ trunk/tests/cdm/210-external.setup.sh 2010-11-24 17:18:12 UTC (rev 3724)
@@ -1,12 +0,0 @@
-#!/bin/sh
-set -x
- uname -a
- date
-} > 210-input.txt
-cp -v $GROUP/external.sh .
-exit 0
Deleted: trunk/tests/cdm/210-external.swift
--- trunk/tests/cdm/210-external.swift 2010-11-24 17:03:13 UTC (rev 3723)
+++ trunk/tests/cdm/210-external.swift 2010-11-24 17:18:12 UTC (rev 3724)
@@ -1,11 +0,0 @@
-type file;
-app (file o) copy (file i)
- cp @i @o;
-file f1<"210-input.txt">;
-file f2<"210-output.txt">;
-f2 = copy(f1);
Copied: trunk/tests/cdm/401-external.check.sh (from rev 3708, trunk/tests/cdm/210-external.check.sh)
--- trunk/tests/cdm/401-external.check.sh (rev 0)
+++ trunk/tests/cdm/401-external.check.sh 2010-11-24 17:18:12 UTC (rev 3724)
@@ -0,0 +1,11 @@
+#!/bin/sh
+set -x
+cat external.out || exit 1
+rm -v external.out || exit 1
+grep $( uname -m ) 210-input.txt || exit 1
+grep $( uname -m ) 210-output.txt || exit 1
+exit 0
Copied: trunk/tests/cdm/401-external.clean.sh (from rev 3708, trunk/tests/cdm/210-external.clean.sh)
--- trunk/tests/cdm/401-external.clean.sh (rev 0)
+++ trunk/tests/cdm/401-external.clean.sh 2010-11-24 17:18:12 UTC (rev 3724)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -v 210-input.txt 210-output.txt
+exit 0
Copied: trunk/tests/cdm/401-external.setup.sh (from rev 3708, trunk/tests/cdm/210-external.setup.sh)
--- trunk/tests/cdm/401-external.setup.sh (rev 0)
+++ trunk/tests/cdm/401-external.setup.sh 2010-11-24 17:18:12 UTC (rev 3724)
@@ -0,0 +1,12 @@
+#!/bin/sh
+set -x
+ uname -a
+ date
+} > 210-input.txt
+cp -v $GROUP/external.sh .
+exit 0
Copied: trunk/tests/cdm/401-external.swift (from rev 3708, trunk/tests/cdm/210-external.swift)
--- trunk/tests/cdm/401-external.swift (rev 0)
+++ trunk/tests/cdm/401-external.swift 2010-11-24 17:18:12 UTC (rev 3724)
@@ -0,0 +1,11 @@
+type file;
+app (file o) copy (file i)
+ cp @i @o;
+file f1<"210-input.txt">;
+file f2<"210-output.txt">;
+f2 = copy(f1);
Modified: trunk/tests/cdm/README.txt
--- trunk/tests/cdm/README.txt 2010-11-24 17:03:13 UTC (rev 3723)
+++ trunk/tests/cdm/README.txt 2010-11-24 17:18:12 UTC (rev 3724)
@@ -1,5 +1,5 @@
000 series : noop tests
200 series : DIRECT tests
-300 series : BROADCAST test
+300 series : BROADCAST tests
+400 series : EXTERNAL tests
More information about the Swift-commit
