[Swift-commit] r3704 - trunk/bin
Mon Nov 1 19:07:58 CDT 2010
Author: davidk
Date: 2010-11-01 19:07:58 -0500 (Mon, 01 Nov 2010)
New Revision: 3704
Modified:
   trunk/bin/swift
Log:
Updated shell script to ignore error messages from bash when compiled with --disable-net-redirections
Modified: trunk/bin/swift
--- trunk/bin/swift	2010-10-30 21:33:13 UTC (rev 3703)
+++ trunk/bin/swift	2010-11-02 00:07:58 UTC (rev 3704)
@@ -139,7 +139,7 @@
     USERID=`echo $USERID $HOSTNAME $MAC | $MD5SUM |cut -d ' ' -f1`
     DATE=`date`
     KEY=`echo $USERID $DATE $$ | $MD5SUM | cut -d ' ' -f1`
-    $BASH -c "echo $KEY $USERID $SCRIPTID $SCRIPTLENGTH -1 0 > /dev/udp/$LISTENER/$PORT" &
+    $BASH -c "echo $KEY $USERID $SCRIPTID $SCRIPTLENGTH -1 0 > /dev/udp/$LISTENER/$PORT" > /dev/null 2>&1 &
 fi
 ### EXECUTE ############
@@ -154,7 +154,7 @@
 return_code=$?
 if [ "$SWIFT_USAGE_STATS" = 1 ]; then
-	$BASH -c "echo $KEY $USERID $SCRIPTID $SCRIPTLENGTH $return_code 1 > /dev/udp/$LISTENER/$PORT" &
+	$BASH -c "echo $KEY $USERID $SCRIPTID $SCRIPTLENGTH $return_code 1 > /dev/udp/$LISTENER/$PORT" > /dev/null 2>&1 &
 fi
 exit $return_code
