[Swift-commit] r3268 - in trunk: libexec src/org/globus/swift/data/policy
Thu Mar 25 11:58:16 CDT 2010
Author: wozniak
Date: 2010-03-25 11:58:15 -0500 (Thu, 25 Mar 2010)
New Revision: 3268
Added:
   trunk/src/org/globus/swift/data/policy/Local.java
Modified:
   trunk/libexec/_swiftwrap
   trunk/src/org/globus/swift/data/policy/Policy.java
Log:
Draft of CDM LOCAL method.
Modified: trunk/libexec/_swiftwrap
--- trunk/libexec/_swiftwrap	2010-03-25 00:07:30 UTC (rev 3267)
+++ trunk/libexec/_swiftwrap	2010-03-25 16:58:15 UTC (rev 3268)
@@ -127,6 +127,7 @@
 	return 1
+# Output:
 cdm_lookup() {
 	FILE=$1
 	CDM_FILE=$2
@@ -151,7 +152,7 @@
 	case $POLICY in
 		DIRECT)
 			DIRECT_DIR=${ARGS[0]}
-			log "CDM[DIRECT]: Linking $JOBDIR/$FILE to $DIRECT_DIR/$FILE"
+			log "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE via $JOBDIR/$FILE"
 			if [ $MODE == "INPUT" ]; then
 				[ -f "$DIRECT_DIR/$FILE" ]
 				checkError 254 "CDM[DIRECT]: $DIRECT_DIR/$FILE does not exist!"
@@ -168,6 +169,22 @@
 				fail 254 "Unknown MODE: $MODE"
 			fi
+ 		LOCAL)
+ 			TOOL=${ARGS[0]}
+ 			REMOTE_DIR=${ARGS[1]}
+ 			FLAGS=${ARGS[3]}
+ 			log "CDM[LOCAL]: Copying $DIRECT_DIR/$FILE to $JOBDIR/$FILE"
+ 			if [ $MODE == "INPUT" ]; then
+ 				[ -f "$DIRECT_DIR/$FILE" ]
+ 				checkError 254 "CDM[DIRECT]: $REMOTE_DIR/$FILE does not exist!"
+ 				$TOOL $FLAGS $REMOTE_DIR/$FILE $JOBDIR/$FILE
+ 				checkError 254 "CDM[DIRECT]: Tool failed!"
+ 			elif [ $MODE == "OUTPUT" ]; then
+ 				log "CDM[LOCAL]..."
+ 			else
+ 				fail 254 "Unknown MODE: $MODE"
+ 			fi
 		BROADCAST)
 			BROADCAST_DIR=${ARGS[0]}
 			log "CDM[BROADCAST]: Linking $JOBDIR/$FILE to $BROADCAST_DIR/$FILE"
@@ -187,6 +204,31 @@
 	esac
+cdm_local_output()
+ 	L=$1
+	if [[ $CDM_FILE == "" ]]; then
+		return
+	fi
+ 	CDM_POLICY=$( cdm_lookup $L $CDM_FILE )
+ 	cdm_local_output_perform $L $CDM_POLICY
+cdm_local_output_perform()
+	L=$1
+	TOOL=$2
+	REMOTE_DIR=$3
+	FLAGS=$3
+	log "Copying $REMOTE_DIR/$FILE to $JOBDIR/$FILE"
+	mkdir -p $REMOTE_DIR
+	checkError 254 "CDM[LOCAL]: mkdir -p $REMOTE_DIR failed!"
+	$TOOL $FLAGS $JOBDIR/$FILE $REMOTE_DIR/$FILE
+	checkError 254 "CDM[LOCAL]: Tool failed!"
 cdm_gather()
 	GATHER_OUTPUT=${*}
@@ -202,6 +244,8 @@
 COMMANDLINE=$@
+echo $0 $COMMANDLINE >> /tmp/swiftwrap.out
 # get the parent directory of the directory containing _swiftwrap, to use
 # as the run directory
 # this assumes that _swiftwrap is being executed from the top level of
@@ -410,6 +454,8 @@
 	fi
 	if [ $CDM_POLICY == "GATHER" ]; then
 		GATHER_OUTPUT=( $GATHER_OUTPUT $L )
+	elif [ $CDM_POLICY == "LOCAL" ]; then
+		CDM_LOCAL_OUTPUT=( $CDM_LOCAL_OUTPUT $L )
 	fi
 done
@@ -492,6 +538,7 @@
 	fi
 done
+cdm_local_output $CDM_LOCAL_OUTPUT
 cdm_gather $GATHER_OUTPUT
 logstate "RM_JOBDIR"
Added: trunk/src/org/globus/swift/data/policy/Local.java
--- trunk/src/org/globus/swift/data/policy/Local.java	                        (rev 0)
+++ trunk/src/org/globus/swift/data/policy/Local.java	2010-03-25 16:58:15 UTC (rev 3268)
@@ -0,0 +1,14 @@
+package org.globus.swift.data.policy;
+import java.util.List;
+public class Local extends Policy {
+    public String toString() {
+        return "PULL";
+    @Override
+    public void settings(List<String> tokens) {
Modified: trunk/src/org/globus/swift/data/policy/Policy.java
--- trunk/src/org/globus/swift/data/policy/Policy.java	2010-03-25 00:07:30 UTC (rev 3267)
+++ trunk/src/org/globus/swift/data/policy/Policy.java	2010-03-25 16:58:15 UTC (rev 3268)
@@ -17,6 +17,8 @@
             return new Default();
         else if (token.compareToIgnoreCase("direct") == 0)
             return new Direct();
+        else if (token.compareToIgnoreCase("local") == 0)
+            return new Local();
         else if (token.compareToIgnoreCase("broadcast") == 0)
             return new Broadcast();
         else if (token.compareToIgnoreCase("gather") == 0)
