[Swift-commit] r3263 - trunk/src/org/griphyn/vdl/karajan/lib/swiftscript
noreply at svn.ci.uchicago.edu
Thu Mar 18 13:21:11 CDT 2010
Author: wozniak
Date: 2010-03-18 13:21:11 -0500 (Thu, 18 Mar 2010)
New Revision: 3263
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
New tracef() %q specifier for arrays.
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2010-03-18 16:15:19 UTC (rev 3262)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2010-03-18 18:21:11 UTC (rev 3263)
@@ -2,6 +2,9 @@
import java.io.IOException;
+import java.util.Collection;
+import java.util.List;
+import java.util.Stack;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
@@ -14,8 +17,10 @@
import org.griphyn.vdl.karajan.lib.SwiftArg;
import org.griphyn.vdl.karajan.lib.VDLFunction;
import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.HandleOpenException;
import org.griphyn.vdl.mapping.InvalidPathException;
import org.griphyn.vdl.mapping.Path;
+import org.griphyn.vdl.mapping.ArrayDataNode;
import org.griphyn.vdl.mapping.RootArrayDataNode;
import org.griphyn.vdl.mapping.RootDataNode;
import org.griphyn.vdl.type.NoSuchTypeException;
@@ -164,6 +169,31 @@
throw new ExecutionException("tracef(): %i requires an int!");
+ else if (c == 'q') {
+ if (args[arg] instanceof ArrayDataNode) {
+ ArrayDataNode node = (ArrayDataNode) args[arg];
+ output.append("[");
+ try {
+ Stack stack = new Stack();
+ Collection children = args[arg].getFields(Path.CHILDREN);
+ for (Object o : children)
+ stack.push(o);
+ while (!stack.empty()) {
+ DSHandle child = (DSHandle) stack.pop();
+ output.append(child);
+ if (!stack.empty())
+ output.append(",");
+ catch (Exception e) {
+ throw new ExecutionException("trace(%q): Could not get children of: " + args[arg]);
+ output.append("]");
+ else {
+ throw new ExecutionException("tracef(): %q requires an array!");
else if (c == 'k') {
More information about the Swift-commit
