[Swift-commit] r3260 - in trunk: etc libexec
Thu Mar 11 16:14:07 CST 2010
Author: wozniak
Date: 2010-03-11 16:14:07 -0600 (Thu, 11 Mar 2010)
New Revision: 3260
Added:
   trunk/libexec/cdm_cleanup.sh
   trunk/libexec/cdm_lib.sh
Modified:
   trunk/etc/log4j.properties
Log:
New CDM features.
Modified: trunk/etc/log4j.properties
--- trunk/etc/log4j.properties	2010-03-11 21:19:33 UTC (rev 3259)
+++ trunk/etc/log4j.properties	2010-03-11 22:14:07 UTC (rev 3260)
@@ -29,3 +29,4 @@
 log4j.logger.org.globus.cog.abstraction.coaster.rlog=INFO
 log4j.logger.org.globus.swift.data.Director=DEBUG
+log4j.logger.org.griphyn.vdl.karajan.lib=INFO
Added: trunk/libexec/cdm_cleanup.sh
--- trunk/libexec/cdm_cleanup.sh	                        (rev 0)
+++ trunk/libexec/cdm_cleanup.sh	2010-03-11 22:14:07 UTC (rev 3260)
@@ -0,0 +1,47 @@
+# Used by vdl-int.k after workflow completion
+# Flushes remaining GATHER output by using cdm_lib
+# Must define some _swiftwrap functions so they can be called by cdm_lib
+logstate() {
+	log "Progress " `date +"%Y-%m-%d %H:%M:%S.%N%z"` ${*}
+log() {
+	echo ${*}
+checkError() {
+	if [ "$?" != "0" ]; then
+		fail $@
+	fi
+fail() {
+	EC=$1
+	shift
+	log ${*}
+	exit $EC
+	set -x
+	GATHER_DIR=$1
+	GATHER_TARGET=$2
+	ID=cleanup-$3
+	if [ "X$GATHER_DIR" == "X" ]; then
+		fail 254 "Not specified: GATHER_DIR"
+	fi
+	DIR=$( dirname $0 )
+	source ${DIR}/cdm_lib.sh
+	cdm_gather_cleanup
+} >> /sandbox/cdm_cleanup.txt
+# Local Variables:
+# mode: sh
+# sh-basic-offset: 8
+# End:
Property changes on: trunk/libexec/cdm_cleanup.sh
___________________________________________________________________
Added: trunk/libexec/cdm_lib.sh
--- trunk/libexec/cdm_lib.sh	                        (rev 0)
+++ trunk/libexec/cdm_lib.sh	2010-03-11 22:14:07 UTC (rev 3260)
@@ -0,0 +1,134 @@
+# Source this for CDM shell functions
+# Setup GATHER_DIR and some variables
+cdm_gather_setup() {
+	GATHER_DIR=$1
+	logstate "GATHER_DIR $GATHER_DIR"
+	mkdir -p $GATHER_DIR
+	checkError 254 "Could not create: $GATHER_DIR"
+	GATHER_LOCKFILE=$GATHER_DIR/.cdm.lock
+	GATHER_MY_FILE=$GATHER_DIR/.cdm-$ID.lock
+	GATHER_MY_OUTBOX=$GATHER_DIR/.cdm-outgoing-$ID
+# Acquire the GATHER_LOCKFILE
+cdm_gather_lock_acquire() {
+	TRYING=1
+	COUNT=0
+	touch $GATHER_MY_FILE
+	checkError 254 "Could not touch my file: $GATHER_MY_FILE"
+	logstate "LOCK_ACQUIRE $GATHER_MY_FILE"
+	while (( TRYING )); do
+		ln $GATHER_MY_FILE $GATHER_LOCKFILE
+		CODE=$?
+		TRYING=$CODE
+		if (( TRYING )); then
+			logstate "LOCK_DELAY $GATHER_MY_FILE : $CODE"
+			if (( COUNT++ > 10 )); then
+				fail 254 "Could not acquire lock!"
+				exit 1
+			fi
+			sleep $(( RANDOM % 10 ))
+		fi
+	done
+# Move files from JOBDIR to GATHER_DIR
+cdm_gather_import() {
+	pushd jobs/$JOBDIR/$ID
+	logstate "GATHER_IMPORT $GATHER_OUTPUT"
+	mv $GATHER_OUTPUT $GATHER_DIR
+	checkError 254 "Could not move output to $GATHER_DIR"
+	popd
+# Move files from GATHER_DIR to OUTBOX
+# Note that this function modifies $IFS
+cdm_gather_export() {
+	RESULT=1
+	pushd ${GATHER_DIR}
+	IFS="
+	FILES=( $( ls -A -I ".cdm*.lock" -I ".cdm-outgoing-*" ) )
+	log "FILES: ${#FILES[@]}"
+	mkdir -p $GATHER_MY_OUTBOX
+	checkError 254 "Could not mkdir ${GATHER_MY_OUTBOX}"
+	if (( ${#FILES} > 0 )); then
+		mv ${FILES[@]} $GATHER_MY_OUTBOX
+		checkError 254 "Could not move ${FILES[@]} to $GATHER_MY_OUTBOX"
+		RESULT=0
+	fi
+	popd
+	return $RESULT
+# Release the GATHER_LOCKFILE
+cdm_gather_lock_release() {
+	logstate "LOCK_RELEASE $GATHER_LOCKFILE"
+	unlink $GATHER_LOCKFILE
+# Move files from (LFS) OUTBOX to (GFS) GATHER_TARGET
+cdm_gather_flush() {
+	pushd ${GATHER_MY_OUTBOX}
+	logstate "GATHER_TARGET $GATHER_TARGET"
+	mkdir -p ${GATHER_TARGET}
+	logstate "GATHER_FLUSH_START ${GATHER_TARGET}/cdm-gather-$ID.tar"
+	TARBALL=${GATHER_TARGET}/cdm-gather-$ID.tar
+	tar cf ${TARBALL} *
+	checkError 254 "CDM[GATHER]: error writing: ${TARBALL}"
+	logstate "GATHER_FLUSH_DONE"
+	popd
+# Called by _swiftwrap at the end of each job
+cdm_gather_action() {
+	GATHER_OUTPUT=${*}
+	GATHER_DIR=$(    perl shared/cdm.pl property GATHER_DIR    < $CDM_FILE )
+	GATHER_MAX=$(    perl shared/cdm.pl property GATHER_LIMIT  < $CDM_FILE )
+	GATHER_TARGET=$( perl shared/cdm.pl property GATHER_TARGET < $CDM_FILE )
+	cdm_gather_setup $GATHER_DIR
+	cdm_gather_lock_acquire
+	cdm_gather_import
+	USAGE=$( du -s --exclude=".cdm*" -B 1 $GATHER_DIR )
+	USAGE=${USAGE%	*} # Chop off filename in output
+	logstate "USAGE_CHECK $USAGE / $GATHER_MAX"
+	FLUSH="no"
+	if (( USAGE > GATHER_MAX )); then
+		FLUSH="yes"
+		cdm_gather_export
+	fi
+	cdm_gather_lock_release
+	if [ $FLUSH == "yes" ]; then
+		cdm_gather_flush
+	fi
+# Called by cdm_cleanup.sh at the end of the workflow
+cdm_gather_cleanup() {
+	declare -p PWD DIR GATHER_DIR GATHER_TARGET ID
+	cdm_gather_export
+	EXPORT_RESULT=$?
+	if (( EXPORT_RESULT == 0)); then
+		cdm_gather_flush
+	fi
+# Local Variables:
+# mode: sh
+# End:
