[Swift-commit] r3419 - in trunk/src/org/griphyn/vdl: engine karajan/lib karajan/lib/swiftscript
noreply at svn.ci.uchicago.edu
Wed Jun 30 17:31:37 CDT 2010
Author: wozniak
Date: 2010-06-30 17:31:37 -0500 (Wed, 30 Jun 2010)
New Revision: 3419
Modified:
trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
New @dirname()
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2010-06-30 05:37:34 UTC (rev 3418)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2010-06-30 22:31:37 UTC (rev 3419)
@@ -180,14 +180,21 @@
FormalArgumentSignature filenameOut1 = new FormalArgumentSignature("string");
filename.addOutputArg(filenameOut1);
functionsMap.put(filename.getName(), filename);
ProcedureSignature filenames = new ProcedureSignature("filenames");
FormalArgumentSignature filenamesIn1 = new FormalArgumentSignature(true); /* file can be specified as any type */
filenames.addInputArg(filenamesIn1);
FormalArgumentSignature filenamesOut1 = new FormalArgumentSignature("string[]"); /* i think this is what it returns */
filenames.addOutputArg(filenamesOut1);
functionsMap.put(filenames.getName(), filenames);
+ ProcedureSignature dirname = new ProcedureSignature("dirname");
+ FormalArgumentSignature dirnameIn1 = new FormalArgumentSignature(true); /* dir can be specified as any type */
+ dirname.addInputArg(dirnameIn1);
+ FormalArgumentSignature dirnameOut1 = new FormalArgumentSignature("string");
+ dirname.addOutputArg(dirnameOut1);
+ functionsMap.put(dirname.getName(), dirname);
ProcedureSignature regexp = new ProcedureSignature("regexp");
FormalArgumentSignature regexpIn1 = new FormalArgumentSignature("string");
regexp.addInputArg(regexpIn1);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java 2010-06-30 05:37:34 UTC (rev 3418)
+++ trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java 2010-06-30 22:31:37 UTC (rev 3419)
@@ -175,7 +175,7 @@
public static final String[] EMPTY_STRING_ARRAY = new String[0];
- public String[] filename(VariableStack stack) throws ExecutionException {
+ public static String[] filename(VariableStack stack) throws ExecutionException {
DSHandle ovar = (DSHandle)PA_VAR.getValue(stack);
synchronized(ovar.getRoot()) {
try {
@@ -475,7 +475,7 @@
- protected static Future addFutureListener(VariableStack stack, DSHandle handle)
+ public static Future addFutureListener(VariableStack stack, DSHandle handle)
assert Thread.holdsLock(handle.getRoot());
return getFutureWrapperMap(stack).addNodeListener(handle);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2010-06-30 05:37:34 UTC (rev 3418)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2010-06-30 22:31:37 UTC (rev 3419)
@@ -11,6 +11,7 @@
import org.globus.cog.karajan.util.TypeUtil;
import org.globus.cog.karajan.workflow.ExecutionException;
import org.globus.cog.karajan.workflow.nodes.functions.FunctionsCollection;
+import org.griphyn.vdl.karajan.lib.PathUtils;
import org.griphyn.vdl.karajan.lib.SwiftArg;
import org.griphyn.vdl.karajan.lib.VDLFunction;
import org.griphyn.vdl.mapping.DSHandle;
@@ -24,6 +25,9 @@
import org.griphyn.vdl.type.Types;
import org.griphyn.vdl.util.VDL2Config;
+import org.griphyn.vdl.mapping.AbsFile;
+import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
public class Misc extends FunctionsCollection {
private static final Logger logger = Logger.getLogger(Misc.class);
@@ -37,11 +41,12 @@
setArguments("swiftscript_tracef", new Arg[] { Arg.VARGS });
setArguments("swiftscript_strcat", new Arg[] { Arg.VARGS });
setArguments("swiftscript_strcut", new Arg[] { PA_INPUT, PA_PATTERN });
- setArguments("swiftscript_strstr", new Arg[] { PA_INPUT, PA_PATTERN });
+ setArguments("swiftscript_strstr", new Arg[] { PA_INPUT, PA_PATTERN });
setArguments("swiftscript_strsplit", new Arg[] { PA_INPUT, PA_PATTERN });
setArguments("swiftscript_regexp", new Arg[] { PA_INPUT, PA_PATTERN, PA_TRANSFORM });
setArguments("swiftscript_toint", new Arg[] { PA_INPUT });
setArguments("swiftscript_tostring", new Arg[] { PA_INPUT });
+ setArguments("swiftscript_dirname", new Arg[] { Arg.VARGS });
private static final Logger traceLogger = Logger.getLogger("org.globus.swift.trace");
@@ -362,12 +367,42 @@
return handle;
- public DSHandle swiftscript_tostring(VariableStack stack) throws ExecutionException, NoSuchTypeException,
- InvalidPathException {
- Object input = PA_INPUT.getValue(stack);
- DSHandle handle = new RootDataNode(Types.STRING);
- handle.setValue(""+input);
- handle.closeShallow();
- return handle;
+ public DSHandle swiftscript_tostring(VariableStack stack)
+ throws ExecutionException, NoSuchTypeException,
+ InvalidPathException {
+ Object input = PA_INPUT.getValue(stack);
+ DSHandle handle = new RootDataNode(Types.STRING);
+ handle.setValue(""+input);
+ handle.closeShallow();
+ return handle;
+ public DSHandle swiftscript_dirname(VariableStack stack)
+ throws ExecutionException, NoSuchTypeException, InvalidPathException {
+ DSHandle handle;
+ try
+ DSHandle[] args = SwiftArg.VARGS.asDSHandleArray(stack);
+ DSHandle arg = args[0];
+ String[] input = VDLFunction.filename(arg);
+ String name = input[0];
+ String result = new AbsFile(name).getDir();
+ handle = new RootDataNode(Types.STRING);
+ handle.setValue(result);
+ catch (HandleOpenException e) {
+ throw new FutureNotYetAvailable
+ (VDLFunction.addFutureListener(stack, e.getSource()));
+ return handle;
+ * Local Variables:
+ * c-basic-offset: 8
+ * End:
+ * vim: ft=c ts=8 sts=4 sw=4 expandtab
More information about the Swift-commit
