[Swift-commit] r3414 - trunk/src/org/griphyn/vdl/mapping/file
Tue Jun 29 13:57:28 CDT 2010
Author: wozniak
Date: 2010-06-29 13:57:28 -0500 (Tue, 29 Jun 2010)
New Revision: 3414
Modified:
   trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
Log:
Probable bug fix to CSVMapper
Modified: trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2010-06-24 20:37:31 UTC (rev 3413)
+++ trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2010-06-29 18:57:28 UTC (rev 3414)
@@ -14,7 +14,10 @@
 import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.AbstractMapper;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.GeneralizedFileFormat;
 import org.griphyn.vdl.mapping.InvalidMappingParameterException;
+import org.griphyn.vdl.mapping.Mapper;
 import org.griphyn.vdl.mapping.MappingParam;
 import org.griphyn.vdl.mapping.Path;
 import org.griphyn.vdl.mapping.PhysicalFormat;
@@ -61,13 +64,16 @@
 		if (read) {
 			return;
-		String file = PARAM_FILE.getStringValue(this);
+		String file = getCSVFile();
 		String delim = PARAM_DELIMITER.getStringValue(this);
 		String hdelim = PARAM_HDELIMITER.getStringValue(this);
 		boolean header = PARAM_HEADER.getBooleanValue(this);
 		int skip = PARAM_SKIP.getIntValue(this);
 		try {
-			BufferedReader br = new BufferedReader(new FileReader(file));
+			BufferedReader br =
+			    new BufferedReader(new FileReader(file));
 			String line;
 			StringTokenizer st;
@@ -78,10 +84,6 @@
 				int ix = 0;
 				while (st.hasMoreTokens()) {
 					String column = st.nextToken();
-					// TODO PMD reports this for the
-					// following line:
-					// An operation on an Immutable object (String, BigDecimal or BigInteger) won't change the object itself
-					// This is likely a bug
 					column.replaceAll("\\s", "_");
 					cols.add(column);
 					colindex.put(column, new Integer(ix));
@@ -127,7 +129,19 @@
-	public Collection existing() {
+	private String getCSVFile() {
+	    String result = null;
+	    Object object = PARAM_FILE.getRawValue(this);
+        DSHandle handle = (DSHandle) object;
+        Mapper mapper = handle.getMapper();
+        PhysicalFormat format = mapper.map(Path.EMPTY_PATH);
+        GeneralizedFileFormat fileFormat =
+            (GeneralizedFileFormat) format;
+        result  = fileFormat.getPath();
+        return result;
+    public Collection existing() {
 		readFile();
 		List l = new ArrayList();
 		Iterator itl = content.iterator();
