[Swift-commit] r3400 - in branches/woz-01/src/org/griphyn/vdl: karajan/lib mapping
noreply at svn.ci.uchicago.edu
Tue Jun 22 12:39:26 CDT 2010
Author: wozniak
Date: 2010-06-22 12:39:26 -0500 (Tue, 22 Jun 2010)
New Revision: 3400
Modified:
branches/woz-01/src/org/griphyn/vdl/karajan/lib/CloseDataset.java
branches/woz-01/src/org/griphyn/vdl/karajan/lib/New.java
branches/woz-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java
Log:
Move more log INFO to DEBUG
Modified: branches/woz-01/src/org/griphyn/vdl/karajan/lib/CloseDataset.java
--- branches/woz-01/src/org/griphyn/vdl/karajan/lib/CloseDataset.java 2010-06-22 17:34:29 UTC (rev 3399)
+++ branches/woz-01/src/org/griphyn/vdl/karajan/lib/CloseDataset.java 2010-06-22 17:39:26 UTC (rev 3400)
@@ -23,8 +23,8 @@
Path path = parsePath(OA_PATH.getValue(stack), stack);
DSHandle var = (DSHandle) PA_VAR.getValue(stack);
try {
- if (logger.isInfoEnabled()) {
- logger.info("Closing " + var);
+ if (logger.isDebugEnabled()) {
+ logger.debug("Closing " + var);
var = var.getField(path);
closeChildren(stack, var);
Modified: branches/woz-01/src/org/griphyn/vdl/karajan/lib/New.java
--- branches/woz-01/src/org/griphyn/vdl/karajan/lib/New.java 2010-06-22 17:34:29 UTC (rev 3399)
+++ branches/woz-01/src/org/griphyn/vdl/karajan/lib/New.java 2010-06-22 17:39:26 UTC (rev 3400)
@@ -134,7 +134,7 @@
throw new ExecutionException("vdl:new requires a type specification for value "
+ value);
- logger.info("NEW id="+handle.getIdentifier());
+ logger.debug("NEW id="+handle.getIdentifier());
return handle;
catch (Exception e) {
Modified: branches/woz-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- branches/woz-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2010-06-22 17:34:29 UTC (rev 3399)
+++ branches/woz-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2010-06-22 17:39:26 UTC (rev 3400)
@@ -563,8 +563,8 @@
public synchronized void addListener(DSHandleListener listener) {
- logger.info("Adding handle listener \"" + listener + "\" to \""
+ logger.debug("Adding handle listener \"" + listener + "\" to \""
+ getIdentifyingString() + "\"");
if (listeners == null) {
@@ -582,9 +582,9 @@
while (i.hasNext()) {
DSHandleListener listener = (DSHandleListener) i.next();
i.remove();
- logger.info("Notifying listener \"" + listener
- + "\" about \"" + getIdentifyingString() + "\"");
+ logger.debug("Notifying listener \"" + listener
+ + "\" about \"" + getIdentifyingString() + "\"");
listener.handleClosed(this);
More information about the Swift-commit
