[Swift-commit] r3398 - in branches/woz-01/src/org/griphyn/vdl: karajan/lib mapping
Tue Jun 22 12:08:17 CDT 2010
Author: wozniak
Date: 2010-06-22 12:08:17 -0500 (Tue, 22 Jun 2010)
New Revision: 3398
Modified:
   branches/woz-01/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
   branches/woz-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java
Log:
Move some logging from INFO to DEBUG
Modified: branches/woz-01/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- branches/woz-01/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2010-06-21 18:23:44 UTC (rev 3397)
+++ branches/woz-01/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2010-06-22 17:08:17 UTC (rev 3398)
@@ -10,6 +10,7 @@
 import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
 import org.griphyn.vdl.karajan.Pair;
 import org.griphyn.vdl.karajan.PairIterator;
+import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.mapping.InvalidPathException;
 import org.griphyn.vdl.mapping.Path;
@@ -32,9 +33,9 @@
 		    Path path = parsePath(OA_PATH.getValue(stack), stack);
 			DSHandle leaf = var.getField(path);
 			DSHandle value = (DSHandle) PA_VALUE.getValue(stack);
-			if (logger.isInfoEnabled()) {
-				logger.info("Setting " + leaf + " to " + value);
+			log(leaf, value);
 			synchronized (var.getRoot()) {
             // TODO want to do a type check here, for runtime type checking
             // and pull out the appropriate internal value from value if it
@@ -61,7 +62,20 @@
-	/** make dest look like source - if its a simple value, copy that
+	private void log(DSHandle leaf, DSHandle value) {
+	    if (logger.isDebugEnabled()) {
+	        logger.debug("Setting " + leaf + " to " + value);
+	    else {
+	        if (leaf instanceof AbstractDataNode) {
+	            AbstractDataNode data = (AbstractDataNode) leaf;
+	            String name = data.getDisplayableName();
+	            logger.info("Set: " + name + "=" + value);
+    /** make dest look like source - if its a simple value, copy that
 	    and if its an array then recursively copy */
 	void deepCopy(DSHandle dest, DSHandle source, VariableStack stack) throws ExecutionException {
 		if (source.getType().isPrimitive()) {
Modified: branches/woz-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- branches/woz-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2010-06-21 18:23:44 UTC (rev 3397)
+++ branches/woz-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2010-06-22 17:08:17 UTC (rev 3398)
@@ -151,7 +151,7 @@
 		return sb.toString();
-	protected String getDisplayableName() {
+	public String getDisplayableName() {
 		String prefix = getRoot().getParam("dbgname");
 		if (prefix == null) {
 			prefix = getRoot().getParam("prefix");
@@ -395,7 +395,7 @@
 		this.closed = true;
 		notifyListeners();
-			logger.info("closed " + this.getIdentifyingString());
+			logger.debug("closed " + this.getIdentifyingString());
 		// so because its closed, we can dump the contents
