[Swift-commit] r3356 - text/parco10submission
noreply at svn.ci.uchicago.edu
Tue Jun 15 14:36:37 CDT 2010
Author: wozniak
Date: 2010-06-15 14:36:36 -0500 (Tue, 15 Jun 2010)
New Revision: 3356
Modified:
text/parco10submission/lx.zsh
Log:
Improvements
Modified: text/parco10submission/lx.zsh
--- text/parco10submission/lx.zsh 2010-06-15 15:58:16 UTC (rev 3355)
+++ text/parco10submission/lx.zsh 2010-06-15 19:36:36 UTC (rev 3356)
@@ -5,7 +5,10 @@
# Use +p & +d to create PDF & PS files.
# Modify DOC to change the relevant tex file.
# Modify TMP & BIB to use different temporary storage.
+# Use "./lx.zsh clean" to clean up
+# set -x
DEFAULTDOC="paper"
COMPILER="pdflatex"
@@ -32,6 +35,8 @@
[[ ${DOC} == "" ]] && DOC=${DEFAULTDOC}
[[ ${MAKE_PDF} == "yes" ]] && MAKE_PS="yes"
clean()
local t
@@ -58,6 +63,24 @@
done
+shoot()
+# print out an array loaded by scan()
+ local i
+ local N
+ N=$( eval print '${#'$1'}' )
+ # print N $N
+ for (( i=1 ; i <= N ; i++ ))
+ do
+ eval print -- "$"${1}"["${i}"]"
+ done
+check_bib_missing()
+ awk '$0 ~ /Warn.*database entry/ { gsub(/\"/, "", $8); print "No entry for: " $8; }'
biblio()
if [[ -f ${DOC}.bbl &&
@@ -65,19 +88,19 @@
then
rm ${DOC}.bbl
fi
- if { bibtex ${DOC} > ${BIB} }
+ if { bibtex ${DOC} >& ${BIB} }
then
printf "."
- ${COMPILER} ${DOC} > /dev/null
+ ${COMPILER} ${DOC} >& /dev/null
printf "."
- ${COMPILER} ${DOC} > ${TMP}
+ ${COMPILER} ${DOC} >& ${TMP}
printf "."
- WARNS=( $( grep "Warning--" ${BIB} ) )
+ check_bib_missing < ${BIB} | scan WARNS
if (( ${#WARNS} > 0 ))
then
printf "\n"
print "Bibtex:"
- print ${WARNS}
+ shoot WARNS
fi
else
printf "\n"
@@ -127,11 +150,10 @@
-f error ||
${DOC}.tex -nt ${DOC}.dvi ||
lx.zsh -nt ${DOC}.dvi ||
- dht.bib -nt ${DOC}.dvi ||
$( readlink Wozniak.bib ) -nt ${DOC}.dvi ||
${FORCE} == "yes" ]]
then
- if { ${COMPILER} --interaction nonstopmode ${DOC} > ${TMP} }
+ if { ${COMPILER} --interaction nonstopmode ${DOC} >& ${TMP} }
then
printf "OK"
rm -f error
More information about the Swift-commit
