[Swift-commit] r3486 - trunk/src/org/griphyn/vdl/karajan
noreply at svn.ci.uchicago.edu
Wed Jul 28 14:41:08 CDT 2010
Author: hategan
Date: 2010-07-28 14:41:08 -0500 (Wed, 28 Jul 2010)
New Revision: 3486
Modified:
trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
Log:
a cow list is better here
Modified: trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
--- trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java 2010-07-28 19:36:27 UTC (rev 3485)
+++ trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java 2010-07-28 19:41:08 UTC (rev 3486)
@@ -5,8 +5,7 @@
import java.util.ArrayList;
import java.util.HashSet;
-import java.util.LinkedList;
-import java.util.List;
+import java.util.Iterator;
import java.util.Map;
import java.util.Set;
@@ -20,6 +19,7 @@
import org.globus.cog.karajan.workflow.futures.FutureIterator;
import org.globus.cog.karajan.workflow.futures.FutureList;
import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
+import org.globus.cog.util.CopyOnWriteArrayList;
import org.griphyn.vdl.mapping.DSHandle;
import org.griphyn.vdl.mapping.DSHandleListener;
@@ -27,7 +27,7 @@
private ArrayList<Object> keys;
private Map values;
private boolean closed;
- private List<EventTargetPair> listeners;
+ private CopyOnWriteArrayList<EventTargetPair> listeners;
private FutureEvaluationException exception;
public ArrayIndexFutureList(DSHandle handle, Map values) {
@@ -82,7 +82,7 @@
notifyListeners();
- public boolean isClosed() {
+ public synchronized boolean isClosed() {
return closed;
@@ -93,7 +93,7 @@
public synchronized void addModificationAction(EventListener target,
Event event) {
if (listeners == null) {
- listeners = new LinkedList<EventTargetPair>();
+ listeners = new CopyOnWriteArrayList<EventTargetPair>();
listeners.add(new EventTargetPair(event, target));
@@ -107,15 +107,22 @@
return;
- for (EventTargetPair etp : listeners) {
- try {
- etp.getTarget().event(etp.getEvent());
+ Iterator<EventTargetPair> i = listeners.iterator();
+ try {
+ while (i.hasNext()) {
+ try {
+ EventTargetPair etp = i.next();
+ i.remove();
+ etp.getTarget().event(etp.getEvent());
+ catch (ExecutionException e) {
+ e.printStackTrace();
- catch (ExecutionException e) {
- e.printStackTrace();
- listeners = null;
+ finally {
+ listeners.release();
public EventTargetPair[] getListenerEvents() {
More information about the Swift-commit
