[Swift-commit] r3475 - trunk/src/org/griphyn/vdl/karajan/lib
Fri Jul 23 23:47:35 CDT 2010
Author: hategan
Date: 2010-07-23 23:47:35 -0500 (Fri, 23 Jul 2010)
New Revision: 3475
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java
   trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java
   trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java
   trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
   trunk/src/org/griphyn/vdl/karajan/lib/Mark.java
   trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java
   trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java
   trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java
Log:
removed header with cog license
Modified: trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java	2010-07-24 04:43:17 UTC (rev 3474)
+++ trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java	2010-07-24 04:47:35 UTC (rev 3475)
@@ -1,9 +1,3 @@
-//This code is developed as part of the Java CoG Kit project
-//The terms of the license can be found at http://www.cogkit.org/license
-//This message may not be removed or altered.
  * Created on Jul 18, 2010
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java	2010-07-24 04:43:17 UTC (rev 3474)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java	2010-07-24 04:47:35 UTC (rev 3475)
@@ -1,9 +1,3 @@
Modified: trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java
--- trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java	2010-07-24 04:43:17 UTC (rev 3474)
+++ trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java	2010-07-24 04:47:35 UTC (rev 3475)
@@ -1,9 +1,3 @@
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java	2010-07-24 04:43:17 UTC (rev 3474)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java	2010-07-24 04:47:35 UTC (rev 3475)
@@ -1,9 +1,3 @@
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Mark.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Mark.java	2010-07-24 04:43:17 UTC (rev 3474)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Mark.java	2010-07-24 04:47:35 UTC (rev 3475)
@@ -1,9 +1,3 @@
Modified: trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java
--- trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java	2010-07-24 04:43:17 UTC (rev 3474)
+++ trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java	2010-07-24 04:47:35 UTC (rev 3475)
@@ -1,9 +1,3 @@
Modified: trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java
--- trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java	2010-07-24 04:43:17 UTC (rev 3474)
+++ trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java	2010-07-24 04:47:35 UTC (rev 3475)
@@ -1,9 +1,3 @@
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java	2010-07-24 04:43:17 UTC (rev 3474)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java	2010-07-24 04:47:35 UTC (rev 3475)
@@ -1,9 +1,3 @@
