[Swift-commit] r3471 - trunk/src/org/griphyn/vdl/karajan/lib
noreply at svn.ci.uchicago.edu
Fri Jul 23 23:37:51 CDT 2010
Author: hategan
Date: 2010-07-23 23:37:51 -0500 (Fri, 23 Jul 2010)
New Revision: 3471
Added:
trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java
Log:
and another one...
Added: trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java 2010-07-24 04:37:51 UTC (rev 3471)
@@ -0,0 +1,48 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Jul 18, 2010
+package org.griphyn.vdl.karajan.lib;
+import java.util.List;
+import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.arguments.ArgUtil;
+import org.globus.cog.karajan.arguments.VariableArguments;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.util.TypeUtil;
+import org.globus.cog.karajan.workflow.ExecutionException;
+import org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.Path;
+public class DoRestartLog extends AbstractSequentialWithArguments {
+ public static final Arg RESTARTOUTS = new Arg.Positional("restartouts");
+ static {
+ setArguments(DoRestartLog.class, new Arg[] { RESTARTOUTS });
+ @Override
+ protected void post(VariableStack stack) throws ExecutionException {
+ List files = TypeUtil.toList(RESTARTOUTS.getValue(stack));
+ VariableArguments ret = ArgUtil.getVariableReturn(stack);
+ try {
+ for (Object f : files) {
+ List pv = TypeUtil.toList(f);
+ Path p = Path.parse(TypeUtil.toString(pv.get(0)));
+ DSHandle handle = (DSHandle) pv.get(1);
+ LogVar.logVar(stack, handle, p);
+ catch (Exception e) {
+ throw new ExecutionException(e);
+ super.post(stack);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java
--- trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java 2010-07-24 04:31:46 UTC (rev 3470)
+++ trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java 2010-07-24 04:37:51 UTC (rev 3471)
@@ -4,6 +4,7 @@
+import org.globus.cog.karajan.stack.VariableNotFoundException;
@@ -27,15 +28,19 @@
else {
path = Path.parse(TypeUtil.toString(p));
- path = var.getPathFromRoot().append(path);
- String annotation;
- if(var.getMapper() != null) {
- annotation = "" + var.getMapper().map(path);
- } else {
- annotation = "unmapped";
- RestartLog.LOG_CHANNEL.ret(stack, var.getRoot().getParam("swift#restartid")
- + "." + path.stringForm() + "!" + annotation);
+ logVar(stack, var, path);
return null;
+ public static void logVar(VariableStack stack, DSHandle var, Path path) throws VariableNotFoundException {
+ path = var.getPathFromRoot().append(path);
+ String annotation;
+ if(var.getMapper() != null) {
+ annotation = "" + var.getMapper().map(path);
+ } else {
+ annotation = "unmapped";
+ RestartLog.LOG_CHANNEL.ret(stack, var.getRoot().getParam("swift#restartid")
+ + "." + path.stringForm() + "!" + annotation);
More information about the Swift-commit
