[Swift-commit] r3468 - trunk/src/org/griphyn/vdl/karajan/lib
Fri Jul 23 23:27:28 CDT 2010
Author: hategan
Date: 2010-07-23 23:27:28 -0500 (Fri, 23 Jul 2010)
New Revision: 3468
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java
   trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java
   trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
   trunk/src/org/griphyn/vdl/karajan/lib/Mark.java
   trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java
   trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java
   trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
Log:
added java implementations for some functions in vdl-int
Added: trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java	2010-07-24 04:27:28 UTC (rev 3468)
@@ -0,0 +1,51 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Jul 18, 2010
+package org.griphyn.vdl.karajan.lib;
+import java.util.List;
+import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.arguments.VariableArguments;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.util.TypeUtil;
+import org.globus.cog.karajan.workflow.ExecutionException;
+public class Flatten extends VDLFunction {
+    static {
+        setArguments(Flatten.class, new Arg[] { Arg.VARGS });
+    @Override
+    protected Object function(VariableStack stack) throws ExecutionException {
+        VariableArguments v = Arg.VARGS.get(stack);
+        if (v.isEmpty()) {
+            return "";
+        else {
+            StringBuilder sb = new StringBuilder();
+            flatten(sb, v.getAll());
+            sb.deleteCharAt(sb.length() - 1);
+            return sb.toString();
+    private void flatten(StringBuilder sb, List l) {
+        for (Object o : l) {
+            if (o instanceof List) {
+                flatten(sb, (List) o);
+            else {
+                sb.append(TypeUtil.toString(o));
+                sb.append('|');
Added: trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java
--- trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java	2010-07-24 04:27:28 UTC (rev 3468)
@@ -0,0 +1,46 @@
+import org.globus.cog.karajan.arguments.ArgUtil;
+import org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments;
+import org.griphyn.vdl.mapping.AbsFile;
+public class InFileDirs extends AbstractSequentialWithArguments {
+    public static final Arg STAGEINS = new Arg.Positional("stageins");
+    static {
+        setArguments(InFileDirs.class, new Arg[] { STAGEINS });
+    @Override
+    protected void post(VariableStack stack) throws ExecutionException {
+        List files = TypeUtil.toList(STAGEINS.getValue(stack));
+        VariableArguments ret = ArgUtil.getVariableReturn(stack);
+        for (Object f : files) {
+        	String path = (String) f;
+            String dir = new AbsFile(path).getDir();
+            if (dir.startsWith("/")) {
+            	ret.append(dir.substring(1));
+            else {
+                ret.append(dir);
+        super.post(stack);
Added: trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java	2010-07-24 04:27:28 UTC (rev 3468)
@@ -0,0 +1,46 @@
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.HandleOpenException;
+import org.griphyn.vdl.mapping.Path;
+public class IsDone extends VDLFunction {
+    public static final Arg STAGEOUT = new Arg.Positional("stageout");
+    static {
+        setArguments(IsDone.class, new Arg[] { STAGEOUT });
+    @Override
+    protected Object function(VariableStack stack) throws ExecutionException,
+            HandleOpenException {
+        List files = TypeUtil.toList(STAGEOUT.getValue(stack));
+            List pv = TypeUtil.toList(f);
+            Path p = Path.parse(TypeUtil.toString(pv.get(0)));
+            DSHandle handle = (DSHandle) pv.get(1);
+            if (!IsLogged.isLogged(stack, handle, p)) {
+                return Boolean.FALSE;
+        if (files.isEmpty()) {
+        return Boolean.TRUE;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java	2010-07-24 04:22:18 UTC (rev 3467)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java	2010-07-24 04:27:28 UTC (rev 3468)
@@ -29,16 +29,20 @@
 		else {
 			path = Path.parse(TypeUtil.toString(p));
-		path = var.getPathFromRoot().append(path);
-		LogEntry entry = LogEntry.build(var.getRoot().getParam("swift#restartid") + "." + path.stringForm());
-		Map map = getLogData(stack);
-		boolean found = false;
-		synchronized (map) {
-			List files = (List) map.get(entry);
-			if (files != null && !files.isEmpty()) {
-				found = true;
-		return Boolean.valueOf(found);
+		return Boolean.valueOf(isLogged(stack, var, path));
+	public static boolean isLogged(VariableStack stack, DSHandle var, Path path) throws ExecutionException {
+	    path = var.getPathFromRoot().append(path);
+        LogEntry entry = LogEntry.build(var.getRoot().getParam("swift#restartid") + "." + path.stringForm());
+        Map map = getLogData(stack);
+        boolean found = false;
+        synchronized (map) {
+            List files = (List) map.get(entry);
+            if (files != null && !files.isEmpty()) {
+                found = true;
+        return found;
Added: trunk/src/org/griphyn/vdl/karajan/lib/Mark.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Mark.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Mark.java	2010-07-24 04:27:28 UTC (rev 3468)
@@ -0,0 +1,62 @@
+import org.griphyn.vdl.mapping.DataDependentException;
+import org.griphyn.vdl.mapping.MappingDependentException;
+public class Mark extends VDLFunction {
+    public static final Arg RESTARTS = new Arg.Positional("restarts");
+    public static final Arg ERR = new Arg.Positional("err");
+    public static final Arg MAPPING = new Arg.Optional("mapping", Boolean.FALSE);
+    static {
+        setArguments(Mark.class, new Arg[] { RESTARTS, ERR, MAPPING });
+    @Override
+        try {
+            if (TypeUtil.toBoolean(ERR.getValue(stack))) {
+                boolean mapping = TypeUtil.toBoolean(MAPPING.getValue(stack));
+                List files = TypeUtil.toList(RESTARTS.getValue(stack));
+                    DSHandle leaf = handle.getField(p);
+                    synchronized (leaf) {
+                        if (mapping) {
+                            leaf.setValue(new MappingDependentException(leaf, null));
+                        else {
+                            leaf.setValue(new DataDependentException(leaf, null));
+                        closeShallow(stack, leaf);
+        catch (Exception e) {
+            throw new ExecutionException(e);
+        return null;
Added: trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java
--- trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java	2010-07-24 04:27:28 UTC (rev 3468)
@@ -0,0 +1,52 @@
+public class OutFileDirs extends AbstractSequentialWithArguments {
+    public static final Arg STAGEOUTS = new Arg.Positional("stageouts");
+    static {
+        setArguments(OutFileDirs.class, new Arg[] { STAGEOUTS });
+    @Override
+        List files = TypeUtil.toList(STAGEOUTS.getValue(stack));
+        try {
+                String fname = VDLFunction.filename(leaf)[0];
+                String dir = new AbsFile(fname).getDir();
+                ret.append(dir);
Added: trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java
--- trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java	2010-07-24 04:27:28 UTC (rev 3468)
@@ -0,0 +1,51 @@
+public class OutFiles extends AbstractSequentialWithArguments {
+    static {
+        setArguments(OutFiles.class, new Arg[] { STAGEOUTS });
+    @Override
+        try {
+                ret.append(fname);
Added: trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java	2010-07-24 04:27:28 UTC (rev 3468)
@@ -0,0 +1,60 @@
+import org.apache.log4j.Logger;
+import org.griphyn.vdl.karajan.functions.ConfigProperty;
+public class Parameterlog extends AbstractSequentialWithArguments {
+    public static final Logger logger = Logger.getLogger(Parameterlog.class);
+    public static final Arg DIRECTION = new Arg.Positional("direction");
+    public static final Arg VAR = new Arg.Positional("variable");
+    public static final Arg ID = new Arg.Positional("id");
+    public static final Arg THREAD = new Arg.Positional("thread");
+    static {
+        setArguments(Parameterlog.class, new Arg[] { DIRECTION, VAR, ID, THREAD });
+    private Boolean enabled;
+    @Override
+    public void pre(VariableStack stack) throws ExecutionException {
+        if (enabled == null) {
+            enabled = "true".equals(ConfigProperty.getProperty("provenance.log", true, stack));
+    @Override
+    protected void executeChildren(VariableStack stack) throws ExecutionException {
+    	if (enabled) {
+    	    super.executeChildren(stack);
+    	else {
+    		complete(stack);
+    @Override
+        if (enabled) {
+            logger.info("PARAM thread=" + THREAD.getValue(stack) + " direction="
+                    + DIRECTION.getValue(stack) + " variable=" + VAR.getValue(stack)
+                    + " provenanceid=" + ID.getValue(stack));
