[Swift-commit] r3461 - branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript
Thu Jul 22 12:14:29 CDT 2010
Author: wozniak
Date: 2010-07-22 12:14:28 -0500 (Thu, 22 Jul 2010)
New Revision: 3461
Modified:
   branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
Log:
Reorganize tracef
Modified: branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
--- branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	2010-07-22 16:55:44 UTC (rev 3460)
+++ branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	2010-07-22 17:14:28 UTC (rev 3461)
@@ -22,9 +22,11 @@
     Format specifiers: <br>
       %%: % sign. <br>
       %p: Not typechecked, output as in trace(). <br>
+      %f: Typechecked float output. <br>
       %i: Typechecked int output. <br>
       %s: Typechecked string output. <br>
-      %k: Variable sKipped, no output.
+      %k: Variable sKipped, no output. <br>
+      %q: Array output
 public class Tracef extends VDLFunction {
@@ -90,89 +92,113 @@
             throw new ExecutionException
             ("tracef(): too many specifiers!");
-        if (c == 'p') {
+        if (c == 'M') {
+            append_M(args[arg], output);
+        else if (c == 'f') {
+            append_f(args[arg], output);
+        else if (c == 'i') {
+            append_i(args[arg], output);
+        else if (c == 'p') {
             output.append(args[arg].toString());
-        else if (c == 'M') {
-            try {
-                synchronized (args[arg].getRoot()) {
-                    String[] names = VDLFunction.filename(args[arg]);
-                    if (names.length > 1)
-                        output.append(names);
-                    else
-                        output.append(names[0]);
-            catch (Exception e) {
-                throw new ExecutionException
-                ("tracef(%M): Could not lookup: " + args[arg]);
         else if (c == 's') {
-            if (args[arg].getType() == Types.STRING) {
-                output.append(args[arg]).toString();
-            else {
-                ("tracef(): %s requires a string!");
+            append_s(args[arg], output);
-        else if (c == 'i') {
-            if (args[arg].getType() == Types.INT) {
-            else {
-                ("tracef(): %i requires an int!");
+        else if (c == 'q') {
+            append_q(args[arg], output);
-        else if (c == 'f') {
-            if (args[arg].getType() == Types.FLOAT) {
+        else if (c == 'k') {
+        else {
+            throw new ExecutionException
+            ("tracef(): Unknown format: %" + c);
+        return arg+1;
+    private void append_M(DSHandle arg, StringBuffer output)
+    throws ExecutionException {
+        try {
+            synchronized (arg.getRoot()) {
+                String[] names = VDLFunction.filename(arg);
+                if (names.length > 1)
+                    output.append(names);
+                else
+                    output.append(names[0]);
-            else {
-                ("tracef(): %f requires a float!");
-        else if (c == 'q') {
-            if (args[arg] instanceof ArrayDataNode) {
-                ArrayDataNode node = (ArrayDataNode) args[arg];
-                output.append("[");
-                try {
-                    int size = node.size();
-                    for (int i = 0; i < size; i++) {
-                        String entry = ""+i;
-                        DSHandle handle =
-                            node.getField(Path.parse(entry));
-                        output.append(handle);
-                        if (i < size-1)
-                            output.append(",");
+        catch (Exception e) {
+            ("tracef(%M): Could not lookup: " + arg);
+    private void append_f(DSHandle arg, StringBuffer output)
+        if (arg.getType() == Types.FLOAT) {
+            output.append(arg).toString();
+        else {
+            ("tracef(): %f requires a float!");
+    private void append_i(DSHandle arg, StringBuffer output)
+        if (arg.getType() == Types.INT) {
+        else {
+            ("tracef(): %i requires an int!");
+    private void append_q(DSHandle arg, StringBuffer output)
+        if (arg instanceof ArrayDataNode) {
+            ArrayDataNode node = (ArrayDataNode) arg;
+            output.append("[");
+            try {
+                int size = node.size();
+                for (int i = 0; i < size; i++) {
+                    String entry = ""+i;
+                    DSHandle handle =
+                        node.getField(Path.parse(entry));
+                    output.append(handle);
+                    if (i < size-1)
+                        output.append(",");
-                    e.printStackTrace();
-                    ("trace(%q): Could not get children of: " +
-                        args[arg]);
-                output.append("]");
-            else {
+                e.printStackTrace();
-                ("tracef(): %q requires an array!");
+                ("trace(%q): Could not get children of: " + arg);
+            output.append("]");
-        else if (c == 'k') {
+        else {
+            ("tracef(): %q requires an array!");
+    private void append_s(DSHandle arg, StringBuffer output)
+        if (arg.getType() == Types.STRING) {
         else {
-            ("tracef(): Unknown format: %" + c);
+            ("tracef(): %s requires a string!");
-        return arg+1;
     private void escape(char c, StringBuffer output)
         if (c == '\\') {
