[Swift-commit] r3457 - in branches/tests-01: . libexec src/org/griphyn/vdl/karajan/lib/swiftscript tests/language-behaviour
Thu Jul 22 11:34:09 CDT 2010
Author: wozniak
Date: 2010-07-22 11:34:09 -0500 (Thu, 22 Jul 2010)
New Revision: 3457
Added:
   branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
   branches/tests-01/tests/language-behaviour/tracef.swift
Modified:
   branches/tests-01/.classpath
   branches/tests-01/libexec/vdl-lib.xml
   branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java
   branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
Move tracef() to its own class and add test
Modified: branches/tests-01/.classpath
--- branches/tests-01/.classpath	2010-07-21 22:03:40 UTC (rev 3456)
+++ branches/tests-01/.classpath	2010-07-22 16:34:09 UTC (rev 3457)
@@ -21,5 +21,7 @@
 	<classpathentry combineaccessrules="false" kind="src" path="/provider-wonky"/>
 	<classpathentry kind="lib" path="lib/jline-0.9.94.jar"/>
 	<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
+	<classpathentry kind="lib" path="/util/lib/log4j-1.2.8.jar"/>
+	<classpathentry kind="lib" path="/util/lib/backport-util-concurrent.jar"/>
 	<classpathentry kind="output" path=".build"/>
 </classpath>
Modified: branches/tests-01/libexec/vdl-lib.xml
--- branches/tests-01/libexec/vdl-lib.xml	2010-07-21 22:03:40 UTC (rev 3456)
+++ branches/tests-01/libexec/vdl-lib.xml	2010-07-22 16:34:09 UTC (rev 3457)
@@ -8,14 +8,14 @@
 	<export name="writedata"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.WriteData"/></export>
 	<export name="strcat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="strcut"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
-	<export name="strstr"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+	<export name="strstr"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="strsplit"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="regexp"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="toint"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="tofloat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="tostring"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="trace"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
-	<export name="tracef"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+	<export name="tracef"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Tracef"/></export>
 	<export name="java"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Java"/></export>
 	<export name="fileName"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.FileName"/></export>
 	<export name="fileNames"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.FileNames"/></export>
@@ -88,7 +88,7 @@
 	<export name="log"><elementDef classname="org.griphyn.vdl.karajan.lib.Log"/></export>
 	<export name="kickstart"><elementDef classname="org.griphyn.vdl.karajan.lib.Kickstart"/></export>
 	<export name="dirname"><elementDef classname="org.griphyn.vdl.karajan.lib.PathUtils"/></export>
 	<export name="reldirname"><elementDef classname="org.griphyn.vdl.karajan.lib.PathUtils"/></export>
 	<export name="basename"><elementDef classname="org.griphyn.vdl.karajan.lib.PathUtils"/></export>
@@ -96,12 +96,12 @@
 	<export name="hostname"><elementDef classname="org.griphyn.vdl.karajan.lib.PathUtils"/></export>
 	<export name="dircat"><elementDef classname="org.griphyn.vdl.karajan.lib.PathUtils"/></export>
 	<export name="pathnames"><elementDef classname="org.griphyn.vdl.karajan.lib.PathUtils"/></export>
 	<export name="execute"><elementDef classname="org.griphyn.vdl.karajan.lib.Execute"/></export>
 	<export name="expandArguments"><elementDef classname="org.griphyn.vdl.karajan.lib.ExpandArguments"/></export>
 	<export name="tparallelFor"><elementDef classname="org.griphyn.vdl.karajan.lib.ThrottledParallelFor"/></export>
 	<export name="appStageins"><elementDef classname="org.griphyn.vdl.karajan.lib.AppStageins"/></export>
 	<export name="appStageouts"><elementDef classname="org.griphyn.vdl.karajan.lib.AppStageouts"/></export>
   </namespace>
Modified: branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java
--- branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java	2010-07-21 22:03:40 UTC (rev 3456)
+++ branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java	2010-07-22 16:34:09 UTC (rev 3457)
@@ -132,8 +132,8 @@
         catch (Exception e) {
             e.printStackTrace();
             throw new RuntimeException
-            ("Error attempting to invoke: " + method.getDeclaringClass() +
-                "." + method);
+            ("Error attempting to invoke: " +
+                method.getDeclaringClass() + "." + method);
         return result;
Modified: branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2010-07-21 22:03:40 UTC (rev 3456)
+++ branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2010-07-22 16:34:09 UTC (rev 3457)
@@ -11,14 +11,12 @@
 import org.globus.cog.karajan.util.TypeUtil;
 import org.globus.cog.karajan.workflow.ExecutionException;
 import org.globus.cog.karajan.workflow.nodes.functions.FunctionsCollection;
-import org.griphyn.vdl.karajan.lib.PathUtils;
 import org.griphyn.vdl.karajan.lib.SwiftArg;
 import org.griphyn.vdl.karajan.lib.VDLFunction;
 import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.mapping.HandleOpenException;
 import org.griphyn.vdl.mapping.InvalidPathException;
 import org.griphyn.vdl.mapping.Path;
-import org.griphyn.vdl.mapping.ArrayDataNode;
 import org.griphyn.vdl.mapping.RootArrayDataNode;
 import org.griphyn.vdl.mapping.RootDataNode;
 import org.griphyn.vdl.type.NoSuchTypeException;
@@ -38,7 +36,6 @@
 	static {
 		setArguments("swiftscript_trace", new Arg[] { Arg.VARGS });
-		setArguments("swiftscript_tracef", new Arg[] { Arg.VARGS });
 		setArguments("swiftscript_strcat", new Arg[] { Arg.VARGS });
 		setArguments("swiftscript_strcut", new Arg[] { PA_INPUT, PA_PATTERN });
         setArguments("swiftscript_strstr", new Arg[] { PA_INPUT, PA_PATTERN });
@@ -47,7 +44,7 @@
 		setArguments("swiftscript_toint", new Arg[] { PA_INPUT });
 		setArguments("swiftscript_tofloat", new Arg[] { PA_INPUT });
 		setArguments("swiftscript_tostring", new Arg[] { PA_INPUT });
-                setArguments("swiftscript_dirname", new Arg[] { Arg.VARGS });
+		setArguments("swiftscript_dirname", new Arg[] { Arg.VARGS });
 	private static final Logger traceLogger = Logger.getLogger("org.globus.swift.trace");
@@ -67,171 +64,7 @@
 		traceLogger.warn(buf);
 		return null;
-       Formatted trace output. <br>
-       Example: tracef("\t%s\n", "hello"); <br>
-       Differences from trace():
-       1) respects \t, \n and \\;
-       2) allows for typechecked format specifiers;
-       3) allows for consumption of variables without display (%k);
-       4) does not impose any formatting (commas, etc.).  <br><br>
-       Format specifiers: <br>
-           %%: % sign. <br>
-           %p: Not typechecked, output as in trace(). <br>
-           %i: Typechecked int output. <br>
-           %s: Typechecked string output. <br>
-           %k: Variable sKipped, no output.
-	public DSHandle swiftscript_tracef(VariableStack stack)
-	throws ExecutionException, NoSuchTypeException,
-	InvalidPathException {
-	    DSHandle[] args = SwiftArg.VARGS.asDSHandleArray(stack);
-		StringBuffer buf = new StringBuffer();
-		for (int i = 0; i < args.length; i++) {
-			DSHandle handle = args[i];
-			VDLFunction.waitFor(stack, handle);
-		String msg = format(args);
-		buf.append(msg);
-		traceLogger.warn(buf);
-		return null;
-       Helper for {@link #swiftscript_tracef}.
-	private String format(DSHandle[] args) throws ExecutionException {
-	    if (! (args[0].getType() == Types.STRING))
-	        throw new ExecutionException("First argument to tracef() must be a string!");
-	    String spec = args[0].toString();
-	    StringBuffer output = new StringBuffer();
-	    int i = 0;
-	    int a = 1;
-	    while (i < spec.length()) {
-	        char c = spec.charAt(i);
-	        if (c == '%') {
-	            char d = spec.charAt(++i);
-	            a = append(d, a, args, output);
-	        else if (c == '\\') {
-	            escape(d, output);
-	        else {
-	            output.append(c);
-	        i++;
-	    String result = output.toString();
-	    return result;
-	private int append(char c, int arg, DSHandle[] args, StringBuffer output) throws ExecutionException {
-	    if (c == '%') {
-	        output.append('%');
-	        return arg;
-	    if (arg >= args.length) {
-	        throw new ExecutionException("tracef(): too many specifiers!");
-	    if (c == 'p') {
-	        output.append(args[arg].toString());
-	    else if (c == 'M') {
-	        try {
-	            synchronized (args[arg].getRoot()) {
-	                String[] names = VDLFunction.filename(args[arg]);
-	                if (names.length > 1)
-	                    output.append(names);
-	                else
-	                    output.append(names[0]);
-	        catch (Exception e) {
-	            throw new ExecutionException("tracef(%M): Could not lookup: " + args[arg]);
-	    else if (c == 's') {
-	        if (args[arg].getType() == Types.STRING) {
-	            output.append(args[arg]).toString();
-	        else {
-	            throw new ExecutionException("tracef(): %s requires a string!");
-	    else if (c == 'i') {
-	        if (args[arg].getType() == Types.INT) {
-	        else {
-	            throw new ExecutionException("tracef(): %i requires an int!");
-	    else if (c == 'f') {
-	        if (args[arg].getType() == Types.FLOAT) {
-	        else {
-	            throw new ExecutionException("tracef(): %f requires a float!");
-	    else if (c == 'q') {
-	        if (args[arg] instanceof ArrayDataNode) {
-	            ArrayDataNode node = (ArrayDataNode) args[arg];
-	            output.append("[");
-	            try {
-	                int size = node.size();
-	                for (int i = 0; i < size; i++) {
-	                    String entry = ""+i;
-	                    DSHandle handle = node.getField(Path.parse(entry));
-	                    output.append(handle);
-	                    if (i < size-1)
-	                        output.append(",");
-	                e.printStackTrace();
-	                throw new ExecutionException("trace(%q): Could not get children of: " + args[arg]);
-                output.append("]");
-	        else {
-	            throw new ExecutionException("tracef(): %q requires an array!");
-	    else if (c == 'k') {
-	    else {
-	        throw new ExecutionException("tracef(): Unknown format: %" + c);
-	    return arg+1;
-	private void escape(char c, StringBuffer output) throws ExecutionException {
-	    if (c == '\\') {
-	        output.append('\\');
-	    else if (c == 'n') {
-	        output.append('\n');
-	    else if (c == 't') {
-	        output.append('\t');
-	    else {
-	        throw new ExecutionException("tracef(): unknown backslash escape sequence!");
 	public DSHandle swiftscript_strcat(VariableStack stack) throws ExecutionException, NoSuchTypeException,
 		Object[] args = SwiftArg.VARGS.asArray(stack);
Added: branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
--- branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	                        (rev 0)
+++ branches/tests-01/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	2010-07-22 16:34:09 UTC (rev 3457)
@@ -0,0 +1,194 @@
+package org.griphyn.vdl.karajan.lib.swiftscript;
+import org.apache.log4j.Logger;
+import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.workflow.ExecutionException;
+import org.griphyn.vdl.karajan.lib.SwiftArg;
+import org.griphyn.vdl.karajan.lib.VDLFunction;
+import org.griphyn.vdl.mapping.ArrayDataNode;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.Path;
+import org.griphyn.vdl.type.Types;
+    Formatted trace output. <br>
+    Example: tracef("\t%s\n", "hello"); <br>
+    Differences from trace():
+    1) respects \t, \n and \\;
+    2) allows for typechecked format specifiers;
+    3) allows for consumption of variables without display (%k);
+    4) does not impose any formatting (commas, etc.).  <br><br>
+    Format specifiers: <br>
+      %%: % sign. <br>
+      %p: Not typechecked, output as in trace(). <br>
+      %i: Typechecked int output. <br>
+      %s: Typechecked string output. <br>
+      %k: Variable sKipped, no output.
+public class Tracef extends VDLFunction {
+    private static final Logger logger =
+        Logger.getLogger(Tracef.class);
+    static {
+        setArguments(Tracef.class, new Arg[] { Arg.VARGS });
+    @Override
+    protected Object function(VariableStack stack)
+    throws ExecutionException {
+        DSHandle[] args = SwiftArg.VARGS.asDSHandleArray(stack);
+        for (int i = 0; i < args.length; i++) {
+            DSHandle handle = args[i];
+            VDLFunction.waitFor(stack, handle);
+        String msg = format(args);
+        logger.info(msg);
+        System.out.print(msg);
+        return null;
+    private String format(DSHandle[] args)
+        if (! (args[0].getType() == Types.STRING))
+            throw new ExecutionException
+            ("First argument to tracef() must be a string!");
+        String spec = args[0].toString();
+        StringBuffer output = new StringBuffer();
+        int i = 0;
+        int a = 1;
+        while (i < spec.length()) {
+            char c = spec.charAt(i);
+            if (c == '%') {
+                char d = spec.charAt(++i);
+                a = append(d, a, args, output);
+            else if (c == '\\') {
+                escape(d, output);
+            else {
+                output.append(c);
+            i++;
+        String result = output.toString();
+        return result;
+    private int append(char c, int arg, DSHandle[] args,
+                       StringBuffer output)
+        if (c == '%') {
+            output.append('%');
+            return arg;
+        if (arg >= args.length) {
+            ("tracef(): too many specifiers!");
+        if (c == 'p') {
+            output.append(args[arg].toString());
+        else if (c == 'M') {
+            try {
+                synchronized (args[arg].getRoot()) {
+                    String[] names = VDLFunction.filename(args[arg]);
+                    if (names.length > 1)
+                        output.append(names);
+                    else
+                        output.append(names[0]);
+            catch (Exception e) {
+                ("tracef(%M): Could not lookup: " + args[arg]);
+        else if (c == 's') {
+            if (args[arg].getType() == Types.STRING) {
+                output.append(args[arg]).toString();
+            else {
+                ("tracef(): %s requires a string!");
+        else if (c == 'i') {
+            if (args[arg].getType() == Types.INT) {
+            else {
+                ("tracef(): %i requires an int!");
+        else if (c == 'f') {
+            if (args[arg].getType() == Types.FLOAT) {
+            else {
+                ("tracef(): %f requires a float!");
+        else if (c == 'q') {
+            if (args[arg] instanceof ArrayDataNode) {
+                ArrayDataNode node = (ArrayDataNode) args[arg];
+                output.append("[");
+                try {
+                    int size = node.size();
+                    for (int i = 0; i < size; i++) {
+                        String entry = ""+i;
+                        DSHandle handle =
+                            node.getField(Path.parse(entry));
+                        output.append(handle);
+                        if (i < size-1)
+                            output.append(",");
+                    e.printStackTrace();
+                    ("trace(%q): Could not get children of: " +
+                        args[arg]);
+                output.append("]");
+            else {
+                ("tracef(): %q requires an array!");
+        else if (c == 'k') {
+        else {
+            ("tracef(): Unknown format: %" + c);
+        return arg+1;
+    private void escape(char c, StringBuffer output)
+        if (c == '\\') {
+            output.append('\\');
+        else if (c == 'n') {
+            output.append('\n');
+        else if (c == 't') {
+            output.append('\t');
+        else {
+            ("tracef(): unknown backslash escape sequence!");
Added: branches/tests-01/tests/language-behaviour/tracef.swift
--- branches/tests-01/tests/language-behaviour/tracef.swift	                        (rev 0)
+++ branches/tests-01/tests/language-behaviour/tracef.swift	2010-07-22 16:34:09 UTC (rev 3457)
@@ -0,0 +1,4 @@
+tracef("3:%i\n", 3);
+tracef("4:%s\n", "4");
+tracef("fraction:%f\n", 22.0/7.0);
