[Swift-commit] r3448 - usertools/swift/swiftconfig/lib/perl/File
Tue Jul 20 02:36:24 CDT 2010
Author: davidk
Date: 2010-07-20 02:36:24 -0500 (Tue, 20 Jul 2010)
New Revision: 3448
Added:
   usertools/swift/swiftconfig/lib/perl/File/Path.pm
Log:
Include correct version of File::Path to avoid issues with older version which handled file deletion differently
Added: usertools/swift/swiftconfig/lib/perl/File/Path.pm
--- usertools/swift/swiftconfig/lib/perl/File/Path.pm	                        (rev 0)
+++ usertools/swift/swiftconfig/lib/perl/File/Path.pm	2010-07-20 07:36:24 UTC (rev 3448)
@@ -0,0 +1,895 @@
+package File::Path;
+use 5.005_04;
+use strict;
+use Cwd 'getcwd';
+use File::Basename ();
+use File::Spec     ();
+BEGIN {
+    if ($] < 5.006) {
+        # can't say 'opendir my $dh, $dirname'
+        # need to initialise $dh
+        eval "use Symbol";
+use Exporter ();
+use vars qw($VERSION @ISA @EXPORT @EXPORT_OK);
+$VERSION   = '2.07_03';
+ at ISA       = qw(Exporter);
+ at EXPORT    = qw(mkpath rmtree);
+ at EXPORT_OK = qw(make_path remove_tree);
+my $Is_VMS     = $^O eq 'VMS';
+my $Is_MacOS   = $^O eq 'MacOS';
+# These OSes complain if you want to remove a file that you have no
+# write permission to:
+my $Force_Writeable = grep {$^O eq $_} qw(amigaos dos epoc MSWin32 MacOS os2);
+# Unix-like systems need to stat each directory in order to detect
+# race condition. MS-Windows is immune to this particular attack.
+my $Need_Stat_Check = !($^O eq 'MSWin32');
+sub _carp {
+    require Carp;
+    goto &Carp::carp;
+sub _croak {
+    require Carp;
+    goto &Carp::croak;
+sub _error {
+    my $arg     = shift;
+    my $message = shift;
+    my $object  = shift;
+    if ($arg->{error}) {
+        $object = '' unless defined $object;
+        $message .= ": $!" if $!;
+        push @{${$arg->{error}}}, {$object => $message};
+    else {
+        _carp(defined($object) ? "$message for $object: $!" : "$message: $!");
+sub make_path {
+    push @_, {} unless @_ and UNIVERSAL::isa($_[-1],'HASH');
+    goto &mkpath;
+sub mkpath {
+    my $old_style = !(@_ and UNIVERSAL::isa($_[-1],'HASH'));
+    my $arg;
+    my $paths;
+    if ($old_style) {
+        my ($verbose, $mode);
+        ($paths, $verbose, $mode) = @_;
+        $paths = [$paths] unless UNIVERSAL::isa($paths,'ARRAY');
+        $arg->{verbose} = $verbose;
+        $arg->{mode}    = defined $mode ? $mode : 0777;
+    else {
+        $arg = pop @_;
+        $arg->{mode}      = delete $arg->{mask} if exists $arg->{mask};
+        $arg->{mode}      = 0777 unless exists $arg->{mode};
+        ${$arg->{error}}  = [] if exists $arg->{error};
+        $paths = [@_];
+    return _mkpath($arg, $paths);
+sub _mkpath {
+    my $arg   = shift;
+    my $paths = shift;
+    my(@created,$path);
+    foreach $path (@$paths) {
+        next unless defined($path) and length($path);
+        $path .= '/' if $^O eq 'os2' and $path =~ /^\w:\z/s; # feature of CRT
+        # Logic wants Unix paths, so go with the flow.
+        if ($Is_VMS) {
+            next if $path eq '/';
+            $path = VMS::Filespec::unixify($path);
+        next if -d $path;
+        my $parent = File::Basename::dirname($path);
+        unless (-d $parent or $path eq $parent) {
+            push(@created,_mkpath($arg, [$parent]));
+        print "mkdir $path\n" if $arg->{verbose};
+        if (mkdir($path,$arg->{mode})) {
+            push(@created, $path);
+        else {
+            my $save_bang = $!;
+            my ($e, $e1) = ($save_bang, $^E);
+            $e .= "; $e1" if $e ne $e1;
+            # allow for another process to have created it meanwhile
+            if (!-d $path) {
+                $! = $save_bang;
+                    push @{${$arg->{error}}}, {$path => $e};
+                else {
+                    _croak("mkdir $path: $e");
+    return @created;
+sub remove_tree {
+    goto &rmtree;
+sub _is_subdir {
+    my($dir, $test) = @_;
+    my($dv, $dd) = File::Spec->splitpath($dir, 1);
+    my($tv, $td) = File::Spec->splitpath($test, 1);
+    # not on same volume
+    return 0 if $dv ne $tv;
+    my @d = File::Spec->splitdir($dd);
+    my @t = File::Spec->splitdir($td);
+    # @t can't be a subdir if it's shorter than @d
+    return 0 if @t < @d;
+    return join('/', @d) eq join('/', splice @t, 0, + at d);
+sub rmtree {
+    my $arg;
+    my $paths;
+    if ($old_style) {
+        my ($verbose, $safe);
+        ($paths, $verbose, $safe) = @_;
+        $arg->{safe}    = defined $safe    ? $safe    : 0;
+        if (defined($paths) and length($paths)) {
+        else {
+            _carp ("No root path(s) specified\n");
+            return 0;
+    else {
+        $arg = pop @_;
+        ${$arg->{result}} = [] if exists $arg->{result};
+        $paths = [@_];
+    $arg->{prefix} = '';
+    $arg->{depth}  = 0;
+    my @clean_path;
+    $arg->{cwd} = getcwd() or do {
+        _error($arg, "cannot fetch initial working directory");
+        return 0;
+    for ($arg->{cwd}) { /\A(.*)\Z/; $_ = $1 } # untaint
+    for my $p (@$paths) {
+        # need to fixup case and map \ to / on Windows
+        my $ortho_root = $^O eq 'MSWin32' ? _slash_lc($p)          : $p;
+        my $ortho_cwd  = $^O eq 'MSWin32' ? _slash_lc($arg->{cwd}) : $arg->{cwd};
+        my $ortho_root_length = length($ortho_root);
+        $ortho_root_length-- if $^O eq 'VMS'; # don't compare '.' with ']'
+        if ($ortho_root_length && _is_subdir($ortho_root, $ortho_cwd)) {
+            local $! = 0;
+            _error($arg, "cannot remove path when cwd is $arg->{cwd}", $p);
+            next;
+        if ($Is_MacOS) {
+            $p  = ":$p" unless $p =~ /:/;
+            $p .= ":"   unless $p =~ /:\z/;
+        elsif ($^O eq 'MSWin32') {
+            $p =~ s{[/\\]\z}{};
+        else {
+            $p =~ s{/\z}{};
+        push @clean_path, $p;
+    @{$arg}{qw(device inode perm)} = (lstat $arg->{cwd})[0,1] or do {
+        _error($arg, "cannot stat initial working directory", $arg->{cwd});
+        return 0;
+    return _rmtree($arg, \@clean_path);
+sub _rmtree {
+    my $arg   = shift;
+    my $count  = 0;
+    my $curdir = File::Spec->curdir();
+    my $updir  = File::Spec->updir();
+    my (@files, $root);
+    ROOT_DIR:
+    foreach $root (@$paths) {
+        # since we chdir into each directory, it may not be obvious
+        # to figure out where we are if we generate a message about
+        # a file name. We therefore construct a semi-canonical
+        # filename, anchored from the directory being unlinked (as
+        # opposed to being truly canonical, anchored from the root (/).
+        my $canon = $arg->{prefix}
+            ? File::Spec->catfile($arg->{prefix}, $root)
+            : $root
+        my ($ldev, $lino, $perm) = (lstat $root)[0,1,2] or next ROOT_DIR;
+        if ( -d _ ) {
+            $root = VMS::Filespec::pathify($root) if $Is_VMS;
+            if (!chdir($root)) {
+                # see if we can escalate privileges to get in
+                # (e.g. funny protection mask such as -w- instead of rwx)
+                $perm &= 07777;
+                my $nperm = $perm | 0700;
+                if (!($arg->{safe} or $nperm == $perm or chmod($nperm, $root))) {
+                    _error($arg, "cannot make child directory read-write-exec", $canon);
+                    next ROOT_DIR;
+                elsif (!chdir($root)) {
+                    _error($arg, "cannot chdir to child", $canon);
+                    next ROOT_DIR;
+            my ($cur_dev, $cur_inode, $perm) = (stat $curdir)[0,1,2] or do {
+                _error($arg, "cannot stat current working directory", $canon);
+                next ROOT_DIR;
+            if ($Need_Stat_Check) {
+                ($ldev eq $cur_dev and $lino eq $cur_inode)
+                    or _croak("directory $canon changed before chdir, expected dev=$ldev ino=$lino, actual dev=$cur_dev ino=$cur_inode, aborting.");
+            $perm &= 07777; # don't forget setuid, setgid, sticky bits
+            # notabene: 0700 is for making readable in the first place,
+            # it's also intended to change it to writable in case we have
+            # to recurse in which case we are better than rm -rf for
+            # subtrees with strange permissions
+            if (!($arg->{safe} or $nperm == $perm or chmod($nperm, $curdir))) {
+                _error($arg, "cannot make directory read+writeable", $canon);
+                $nperm = $perm;
+            my $d;
+            $d = gensym() if $] < 5.006;
+            if (!opendir $d, $curdir) {
+                _error($arg, "cannot opendir", $canon);
+                @files = ();
+            else {
+                no strict 'refs';
+                if (!defined ${"\cTAINT"} or ${"\cTAINT"}) {
+                    # Blindly untaint dir names if taint mode is
+                    # active, or any perl < 5.006
+                    @files = map { /\A(.*)\z/s; $1 } readdir $d;
+                else {
+                    @files = readdir $d;
+                closedir $d;
+            if ($Is_VMS) {
+                # Deleting large numbers of files from VMS Files-11
+                # filesystems is faster if done in reverse ASCIIbetical order.
+                # include '.' to '.;' from blead patch #31775
+                @files = map {$_ eq '.' ? '.;' : $_} reverse @files;
+                ($root = VMS::Filespec::unixify($root)) =~ s/\.dir\z//;
+            @files = grep {$_ ne $updir and $_ ne $curdir} @files;
+            if (@files) {
+                # remove the contained files before the directory itself
+                my $narg = {%$arg};
+                @{$narg}{qw(device inode cwd prefix depth)}
+                    = ($cur_dev, $cur_inode, $updir, $canon, $arg->{depth}+1);
+                $count += _rmtree($narg, \@files);
+            # restore directory permissions of required now (in case the rmdir
+            # below fails), while we are still in the directory and may do so
+            # without a race via '.'
+            if ($nperm != $perm and not chmod($perm, $curdir)) {
+                _error($arg, "cannot reset chmod", $canon);
+            # don't leave the client code in an unexpected directory
+            chdir($arg->{cwd})
+                or _croak("cannot chdir to $arg->{cwd} from $canon: $!, aborting.");
+            # ensure that a chdir upwards didn't take us somewhere other
+            # than we expected (see CVE-2002-0435)
+            ($cur_dev, $cur_inode) = (stat $curdir)[0,1]
+                or _croak("cannot stat prior working directory $arg->{cwd}: $!, aborting.");
+                ($arg->{device} eq $cur_dev and $arg->{inode} eq $cur_inode)
+                    or _croak("previous directory $arg->{cwd} changed before entering $canon, expected dev=$ldev ino=$lino, actual dev=$cur_dev ino=$cur_inode, aborting.");
+            if ($arg->{depth} or !$arg->{keep_root}) {
+                if ($arg->{safe} &&
+                    ($Is_VMS ? !&VMS::Filespec::candelete($root) : !-w $root)) {
+                    print "skipped $root\n" if $arg->{verbose};
+                    next ROOT_DIR;
+                if ($Force_Writeable and !chmod $perm | 0700, $root) {
+                    _error($arg, "cannot make directory writeable", $canon);
+                print "rmdir $root\n" if $arg->{verbose};
+                if (rmdir $root) {
+                    push @{${$arg->{result}}}, $root if $arg->{result};
+                    ++$count;
+                else {
+                    _error($arg, "cannot remove directory", $canon);
+                    if ($Force_Writeable && !chmod($perm, ($Is_VMS ? VMS::Filespec::fileify($root) : $root))
+                        _error($arg, sprintf("cannot restore permissions to 0%o",$perm), $canon);
+        else {
+            # not a directory
+            $root = VMS::Filespec::vmsify("./$root")
+                if $Is_VMS
+                   && !File::Spec->file_name_is_absolute($root)
+                   && ($root !~ m/(?<!\^)[\]>]+/);  # not already in VMS syntax
+                         : !(-l $root || -w $root)))
+                next ROOT_DIR;
+            my $nperm = $perm & 07777 | 0600;
+            if ($Force_Writeable and $nperm != $perm and not chmod $nperm, $root) {
+                _error($arg, "cannot make file writeable", $canon);
+            print "unlink $canon\n" if $arg->{verbose};
+            # delete all versions under VMS
+            for (;;) {
+                if (unlink $root) {
+                else {
+                    _error($arg, "cannot unlink file", $canon);
+                    $Force_Writeable and chmod($perm, $root) or
+                    last;
+                ++$count;
+                last unless $Is_VMS && lstat $root;
+    return $count;
+sub _slash_lc {
+    # fix up slashes and case on MSWin32 so that we can determine that
+    # c:\path\to\dir is underneath C:/Path/To
+    my $path = shift;
+    $path =~ tr{\\}{/};
+    return lc($path);
+1;
+__END__
+=head1 NAME
+File::Path - Create or remove directory trees
+=head1 VERSION
+This document describes version 2.07 of File::Path, released
+2008-11-09.
+=head1 SYNOPSIS
+  use File::Path qw(make_path remove_tree);
+  make_path('foo/bar/baz', '/zug/zwang');
+  make_path('foo/bar/baz', '/zug/zwang', {
+      verbose => 1,
+      mode => 0711,
+  remove_tree('foo/bar/baz', '/zug/zwang');
+  remove_tree('foo/bar/baz', '/zug/zwang', {
+      verbose => 1,
+      error  => \my $err_list,
+  # legacy (interface promoted before v2.00)
+  mkpath('/foo/bar/baz');
+  mkpath('/foo/bar/baz', 1, 0711);
+  mkpath(['/foo/bar/baz', 'blurfl/quux'], 1, 0711);
+  rmtree('foo/bar/baz', 1, 1);
+  rmtree(['foo/bar/baz', 'blurfl/quux'], 1, 1);
+  # legacy (interface promoted before v2.06)
+  mkpath('foo/bar/baz', '/zug/zwang', { verbose => 1, mode => 0711 });
+  rmtree('foo/bar/baz', '/zug/zwang', { verbose => 1, mode => 0711 });
+=head1 DESCRIPTION
+This module provide a convenient way to create directories of
+arbitrary depth and to delete an entire directory subtree from the
+filesystem.
+The following functions are provided:
+=over
+=item make_path( $dir1, $dir2, .... )
+=item make_path( $dir1, $dir2, ...., \%opts )
+The C<make_path> function creates the given directories if they don't
+exists before, much like the Unix command C<mkdir -p>.
+The function accepts a list of directories to be created. Its
+behaviour may be tuned by an optional hashref appearing as the last
+parameter on the call.
+The function returns the list of directories actually created during
+the call; in scalar context the number of directories created.
+The following keys are recognised in the option hash:
+=over
+=item mode => $num
+The numeric permissions mode to apply to each created directory
+(defaults to 0777), to be modified by the current C<umask>. If the
+directory already exists (and thus does not need to be created),
+the permissions will not be modified.
+C<mask> is recognised as an alias for this parameter.
+=item verbose => $bool
+If present, will cause C<make_path> to print the name of each directory
+as it is created. By default nothing is printed.
+=item error => \$err
+If present, it should be a reference to a scalar.
+This scalar will be made to reference an array, which will
+be used to store any errors that are encountered.  See the L</"ERROR
+HANDLING"> section for more information.
+If this parameter is not used, certain error conditions may raise
+a fatal error that will cause the program will halt, unless trapped
+in an C<eval> block.
+=back
+=item mkpath( $dir )
+=item mkpath( $dir, $verbose, $mode )
+=item mkpath( [$dir1, $dir2,...], $verbose, $mode )
+=item mkpath( $dir1, $dir2,..., \%opt )
+The mkpath() function provide the legacy interface of make_path() with
+a different interpretation of the arguments passed.  The behaviour and
+return value of the function is otherwise identical to make_path().
+=item remove_tree( $dir1, $dir2, .... )
+=item remove_tree( $dir1, $dir2, ...., \%opts )
+The C<remove_tree> function deletes the given directories and any
+files and subdirectories they might contain, much like the Unix
+command C<rm -r> or C<del /s> on Windows.
+removed. Its behaviour may be tuned by an optional hashref
+appearing as the last parameter on the call.
+The functions returns the number of files successfully deleted.
+=over
+If present, will cause C<remove_tree> to print the name of each file as
+it is unlinked. By default nothing is printed.
+=item safe => $bool
+When set to a true value, will cause C<remove_tree> to skip the files
+for which the process lacks the required privileges needed to delete
+files, such as delete privileges on VMS. In other words, the code
+will make no attempt to alter file permissions. Thus, if the process
+is interrupted, no filesystem object will be left in a more
+permissive mode.
+=item keep_root => $bool
+When set to a true value, will cause all files and subdirectories
+to be removed, except the initially specified directories. This comes
+in handy when cleaning out an application's scratch directory.
+  remove_tree( '/tmp', {keep_root => 1} );
+=item result => \$res
+be used to store all files and directories unlinked
+during the call. If nothing is unlinked, the array will be empty.
+  remove_tree( '/tmp', {result => \my $list} );
+  print "unlinked $_\n" for @$list;
+This is a useful alternative to the C<verbose> key.
+Removing things is a much more dangerous proposition than
+creating things. As such, there are certain conditions that
+C<remove_tree> may encounter that are so dangerous that the only
+sane action left is to kill the program.
+Use C<error> to trap all that is reasonable (problems with
+permissions and the like), and let it die if things get out
+of hand. This is the safest course of action.
+=back
+=item rmtree( $dir )
+=item rmtree( $dir, $verbose, $safe )
+=item rmtree( [$dir1, $dir2,...], $verbose, $safe )
+=item rmtree( $dir1, $dir2,..., \%opt )
+The rmtree() function provide the legacy interface of remove_tree()
+with a different interpretation of the arguments passed. The behaviour
+and return value of the function is otherwise identical to
+remove_tree().
+=back
+=head2 ERROR HANDLING
+=over 4
+=item B<NOTE:>
+The following error handling mechanism is considered
+experimental and is subject to change pending feedback from
+users.
+=back
+If C<make_path> or C<remove_tree> encounter an error, a diagnostic
+message will be printed to C<STDERR> via C<carp> (for non-fatal
+errors), or via C<croak> (for fatal errors).
+If this behaviour is not desirable, the C<error> attribute may be
+used to hold a reference to a variable, which will be used to store
+the diagnostics. The variable is made a reference to an array of hash
+references.  Each hash contain a single key/value pair where the key
+is the name of the file, and the value is the error message (including
+the contents of C<$!> when appropriate).  If a general error is
+encountered the diagnostic key will be empty.
+An example usage looks like:
+  remove_tree( 'foo/bar', 'bar/rat', {error => \my $err} );
+  if (@$err) {
+      for my $diag (@$err) {
+          my ($file, $message) = %$diag;
+          if ($file eq '') {
+              print "general error: $message\n";
+          else {
+              print "problem unlinking $file: $message\n";
+  else {
+      print "No error encountered\n";
+Note that if no errors are encountered, C<$err> will reference an
+empty array.  This means that C<$err> will always end up TRUE; so you
+need to test C<@$err> to determine if errors occured.
+=head2 NOTES
+C<File::Path> blindly exports C<mkpath> and C<rmtree> into the
+current namespace. These days, this is considered bad style, but
+to change it now would break too much code. Nonetheless, you are
+invited to specify what it is you are expecting to use:
+  use File::Path 'rmtree';
+The routines C<make_path> and C<remove_tree> are B<not> exported
+by default. You must specify which ones you want to use.
+  use File::Path 'remove_tree';
+Note that a side-effect of the above is that C<mkpath> and C<rmtree>
+are no longer exported at all. This is due to the way the C<Exporter>
+module works. If you are migrating a codebase to use the new
+interface, you will have to list everything explicitly. But that's
+just good practice anyway.
+  use File::Path qw(remove_tree rmtree);
+=head3 SECURITY CONSIDERATIONS
+There were race conditions 1.x implementations of File::Path's
+C<rmtree> function (although sometimes patched depending on the OS
+distribution or platform). The 2.0 version contains code to avoid the
+problem mentioned in CVE-2002-0435.
+See the following pages for more information:
+  http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=286905
+  http://www.nntp.perl.org/group/perl.perl5.porters/2005/01/msg97623.html
+  http://www.debian.org/security/2005/dsa-696
+Additionally, unless the C<safe> parameter is set (or the
+third parameter in the traditional interface is TRUE), should a
+C<remove_tree> be interrupted, files that were originally in read-only
+mode may now have their permissions set to a read-write (or "delete
+OK") mode.
+=head1 DIAGNOSTICS
+FATAL errors will cause the program to halt (C<croak>), since the
+problem is so severe that it would be dangerous to continue. (This
+can always be trapped with C<eval>, but it's not a good idea. Under
+the circumstances, dying is the best thing to do).
+SEVERE errors may be trapped using the modern interface. If the
+they are not trapped, or the old interface is used, such an error
+will cause the program will halt.
+All other errors may be trapped using the modern interface, otherwise
+they will be C<carp>ed about. Program execution will not be halted.
+=over 4
+=item mkdir [path]: [errmsg] (SEVERE)
+C<make_path> was unable to create the path. Probably some sort of
+permissions error at the point of departure, or insufficient resources
+(such as free inodes on Unix).
+=item No root path(s) specified
+C<make_path> was not given any paths to create. This message is only
+emitted if the routine is called with the traditional interface.
+The modern interface will remain silent if given nothing to do.
+=item No such file or directory
+On Windows, if C<make_path> gives you this warning, it may mean that
+you have exceeded your filesystem's maximum path length.
+=item cannot fetch initial working directory: [errmsg]
+C<remove_tree> attempted to determine the initial directory by calling
+C<Cwd::getcwd>, but the call failed for some reason. No attempt
+will be made to delete anything.
+=item cannot stat initial working directory: [errmsg]
+C<remove_tree> attempted to stat the initial directory (after having
+successfully obtained its name via C<getcwd>), however, the call
+failed for some reason. No attempt will be made to delete anything.
+=item cannot chdir to [dir]: [errmsg]
+C<remove_tree> attempted to set the working directory in order to
+begin deleting the objects therein, but was unsuccessful. This is
+usually a permissions issue. The routine will continue to delete
+other things, but this directory will be left intact.
+=item directory [dir] changed before chdir, expected dev=[n] ino=[n], actual dev=[n] ino=[n], aborting. (FATAL)
+C<remove_tree> recorded the device and inode of a directory, and then
+moved into it. It then performed a C<stat> on the current directory
+and detected that the device and inode were no longer the same. As
+this is at the heart of the race condition problem, the program
+will die at this point.
+=item cannot make directory [dir] read+writeable: [errmsg]
+C<remove_tree> attempted to change the permissions on the current directory
+to ensure that subsequent unlinkings would not run into problems,
+but was unable to do so. The permissions remain as they were, and
+the program will carry on, doing the best it can.
+=item cannot read [dir]: [errmsg]
+C<remove_tree> tried to read the contents of the directory in order
+to acquire the names of the directory entries to be unlinked, but
+was unsuccessful. This is usually a permissions issue. The
+program will continue, but the files in this directory will remain
+after the call.
+=item cannot reset chmod [dir]: [errmsg]
+C<remove_tree>, after having deleted everything in a directory, attempted
+to restore its permissions to the original state but failed. The
+directory may wind up being left behind.
+=item cannot remove [dir] when cwd is [dir]
+The current working directory of the program is F</some/path/to/here>
+and you are attempting to remove an ancestor, such as F</some/path>.
+The directory tree is left untouched.
+The solution is to C<chdir> out of the child directory to a place
+outside the directory tree to be removed.
+=item cannot chdir to [parent-dir] from [child-dir]: [errmsg], aborting. (FATAL)
+C<remove_tree>, after having deleted everything and restored the permissions
+of a directory, was unable to chdir back to the parent. The program
+halts to avoid a race condition from occurring.
+=item cannot stat prior working directory [dir]: [errmsg], aborting. (FATAL)
+C<remove_tree> was unable to stat the parent directory after have returned
+from the child. Since there is no way of knowing if we returned to
+where we think we should be (by comparing device and inode) the only
+way out is to C<croak>.
+=item previous directory [parent-dir] changed before entering [child-dir], expected dev=[n] ino=[n], actual dev=[n] ino=[n], aborting. (FATAL)
+When C<remove_tree> returned from deleting files in a child directory, a
+check revealed that the parent directory it returned to wasn't the one
+it started out from. This is considered a sign of malicious activity.
+=item cannot make directory [dir] writeable: [errmsg]
+Just before removing a directory (after having successfully removed
+everything it contained), C<remove_tree> attempted to set the permissions
+on the directory to ensure it could be removed and failed. Program
+execution continues, but the directory may possibly not be deleted.
+=item cannot remove directory [dir]: [errmsg]
+C<remove_tree> attempted to remove a directory, but failed. This may because
+some objects that were unable to be removed remain in the directory, or
+a permissions issue. The directory will be left behind.
+=item cannot restore permissions of [dir] to [0nnn]: [errmsg]
+After having failed to remove a directory, C<remove_tree> was unable to
+restore its permissions from a permissive state back to a possibly
+more restrictive setting. (Permissions given in octal).
+=item cannot make file [file] writeable: [errmsg]
+C<remove_tree> attempted to force the permissions of a file to ensure it
+could be deleted, but failed to do so. It will, however, still attempt
+to unlink the file.
+=item cannot unlink file [file]: [errmsg]
+C<remove_tree> failed to remove a file. Probably a permissions issue.
+=item cannot restore permissions of [file] to [0nnn]: [errmsg]
+After having failed to remove a file, C<remove_tree> was also unable
+to restore the permissions on the file to a possibly less permissive
+setting. (Permissions given in octal).
+=back
+=head1 SEE ALSO
+=over 4
+=item *
+L<File::Remove>
+Allows files and directories to be moved to the Trashcan/Recycle
+Bin (where they may later be restored if necessary) if the operating
+system supports such functionality. This feature may one day be
+made available directly in C<File::Path>.
+=item *
+L<File::Find::Rule>
+When removing directory trees, if you want to examine each file to
+decide whether to delete it (and possibly leaving large swathes
+alone), F<File::Find::Rule> offers a convenient and flexible approach
+to examining directory trees.
+=back
+=head1 BUGS
+Please report all bugs on the RT queue:
+L<http://rt.cpan.org/NoAuth/Bugs.html?Dist=File-Path>
+=head1 ACKNOWLEDGEMENTS
+Paul Szabo identified the race condition originally, and Brendan
+O'Dea wrote an implementation for Debian that addressed the problem.
+That code was used as a basis for the current code. Their efforts
+are greatly appreciated.
+Gisle Aas made a number of improvements to the documentation for
+2.07 and his advice and assistance is also greatly appreciated.
+=head1 AUTHORS
+Tim Bunce and Charles Bailey. Currently maintained by David Landgren
+<F<david at landgren.net>>.
+=head1 COPYRIGHT
+This module is copyright (C) Charles Bailey, Tim Bunce and
+David Landgren 1995-2008. All rights reserved.
+=head1 LICENSE
+This library is free software; you can redistribute it and/or modify
+it under the same terms as Perl itself.
+=cut
