[Swift-commit] r3446 - in branches/tests-01/tests: . language/should-not-work
Mon Jul 19 16:10:02 CDT 2010
Author: wozniak
Date: 2010-07-19 16:10:01 -0500 (Mon, 19 Jul 2010)
New Revision: 3446
Added:
   branches/tests-01/tests/array_iteration.swift
   branches/tests-01/tests/array_wildcard.swift
   branches/tests-01/tests/arraymapper.swift
   branches/tests-01/tests/default.swift
   branches/tests-01/tests/diamond.swift
   branches/tests-01/tests/file_counter.swift
   branches/tests-01/tests/hello.swift
   branches/tests-01/tests/helloworld.swift
   branches/tests-01/tests/helloworld_named.swift
   branches/tests-01/tests/language/should-not-work/1151-bad-comment.swift
   branches/tests-01/tests/language/should-not-work/116-keyword-misuse-in.swift
   branches/tests-01/tests/language/should-not-work/117-empty-program.swift
   branches/tests-01/tests/language/should-not-work/case-broken2.swift
   branches/tests-01/tests/language/should-not-work/closes.swift
   branches/tests-01/tests/range.swift
Removed:
   branches/tests-01/tests/array_iteration.dtm
   branches/tests-01/tests/array_wildcard.dtm
   branches/tests-01/tests/arraymapper.dtm
   branches/tests-01/tests/default.dtm
   branches/tests-01/tests/diamond.dtm
   branches/tests-01/tests/file_counter.dtm
   branches/tests-01/tests/hello.dtm
   branches/tests-01/tests/helloworld.dtm
   branches/tests-01/tests/helloworld_named.dtm
   branches/tests-01/tests/language/should-not-work/1151-bad-comment.dtm
   branches/tests-01/tests/language/should-not-work/116-keyword-misuse-in.dtm
   branches/tests-01/tests/language/should-not-work/117-empty-program.dtm
   branches/tests-01/tests/language/should-not-work/case-broken2.dtm
   branches/tests-01/tests/language/should-not-work/closes.dtm
   branches/tests-01/tests/range.dtm
Modified:
   branches/tests-01/tests/nightly.sh
Log:
Tests: *.dtm to *.swift
Deleted: branches/tests-01/tests/array_iteration.dtm
--- branches/tests-01/tests/array_iteration.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/array_iteration.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,17 +0,0 @@
-type file {}
-(file f) echo (string s) {
-    app {
-        echo s stdout=@filename(f);
-(file fa[]) echo_batch (string sa[]) {
-    foreach string s, i in sa {
-        fa[i] = echo(s);
-string sa[] = ["hello","hi there","how are you"];
-file fa[];
-fa = echo_batch(sa);
Copied: branches/tests-01/tests/array_iteration.swift (from rev 3445, branches/tests-01/tests/array_iteration.dtm)
--- branches/tests-01/tests/array_iteration.swift	                        (rev 0)
+++ branches/tests-01/tests/array_iteration.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,17 @@
+type file {}
+(file f) echo (string s) {
+    app {
+        echo s stdout=@filename(f);
+(file fa[]) echo_batch (string sa[]) {
+    foreach string s, i in sa {
+        fa[i] = echo(s);
+string sa[] = ["hello","hi there","how are you"];
+file fa[];
+fa = echo_batch(sa);
Deleted: branches/tests-01/tests/array_wildcard.dtm
--- branches/tests-01/tests/array_wildcard.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/array_wildcard.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,13 +0,0 @@
-type file {}
-(file t) echo_wildcard (string s[]) {
-    app {
-        echo s[*] stdout=@filename(t);
-string greetings[] = ["how","are","you"];
-file hw = echo(greetings);
Copied: branches/tests-01/tests/array_wildcard.swift (from rev 3445, branches/tests-01/tests/array_wildcard.dtm)
--- branches/tests-01/tests/array_wildcard.swift	                        (rev 0)
+++ branches/tests-01/tests/array_wildcard.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,13 @@
+type file {}
+(file t) echo_wildcard (string s[]) {
+    app {
+        echo s[*] stdout=@filename(t);
+string greetings[] = ["how","are","you"];
+file hw = echo(greetings);
Deleted: branches/tests-01/tests/arraymapper.dtm
--- branches/tests-01/tests/arraymapper.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/arraymapper.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,8 +0,0 @@
-type file {};
-file files[]<simple_mapper;pattern="*">;
-foreach f in files {
-   print(f);
Copied: branches/tests-01/tests/arraymapper.swift (from rev 3445, branches/tests-01/tests/arraymapper.dtm)
--- branches/tests-01/tests/arraymapper.swift	                        (rev 0)
+++ branches/tests-01/tests/arraymapper.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,8 @@
+type file {};
+file files[]<simple_mapper;pattern="*">;
+foreach f in files {
+   print(f);
Deleted: branches/tests-01/tests/default.dtm
--- branches/tests-01/tests/default.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/default.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,11 +0,0 @@
-type file {}
-(file t) echo (string s="hello world") { //s has a default value
-    app {
-        echo s stdout=@filename(t);		//redirect stdout to a file
-file hw1, hw2;
-hw1 = echo();		// procedure call using the default value
-hw2 = echo(s="hello again"); // using a different value
Copied: branches/tests-01/tests/default.swift (from rev 3445, branches/tests-01/tests/default.dtm)
--- branches/tests-01/tests/default.swift	                        (rev 0)
+++ branches/tests-01/tests/default.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,11 @@
+type file {}
+(file t) echo (string s="hello world") { //s has a default value
+    app {
+        echo s stdout=@filename(t);		//redirect stdout to a file
+file hw1, hw2;
+hw1 = echo();		// procedure call using the default value
+hw2 = echo(s="hello again"); // using a different value
Deleted: branches/tests-01/tests/diamond.dtm
--- branches/tests-01/tests/diamond.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/diamond.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,33 +0,0 @@
-type file {};
-(file f) generate (float p1) {
-    app {
-		generate "-aTOP -T4" "-p" p1 "-o" @f;
-(file f2) process (file f1, string name, float p2) {
-    app {
-		process "-a" name "-T4" "-p" p2 "-i" @f1 "-o" @f2;
-(file f3) combine (file f1, file f2) {
-    app {
-		combine "-aBOTTOM -T4" "-i" @f1 @f2 "-o" @f3;
-(file fd) diamond (float p1, float p2) {
-    file fa;
-    file fb;
-	file fc;
-    fa = generate(p1);
-    fb = process(fa, "LEFT", p2);
-    fc = process(fa, "RIGHT", p2);
-    fd = combine(fb, fc);
-file final<"FINAL">;
-final = diamond(1, 100);
Copied: branches/tests-01/tests/diamond.swift (from rev 3445, branches/tests-01/tests/diamond.dtm)
--- branches/tests-01/tests/diamond.swift	                        (rev 0)
+++ branches/tests-01/tests/diamond.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,33 @@
+type file {};
+(file f) generate (float p1) {
+    app {
+		generate "-aTOP -T4" "-p" p1 "-o" @f;
+(file f2) process (file f1, string name, float p2) {
+    app {
+		process "-a" name "-T4" "-p" p2 "-i" @f1 "-o" @f2;
+(file f3) combine (file f1, file f2) {
+    app {
+		combine "-aBOTTOM -T4" "-i" @f1 @f2 "-o" @f3;
+(file fd) diamond (float p1, float p2) {
+    file fa;
+    file fb;
+	file fc;
+    fa = generate(p1);
+    fb = process(fa, "LEFT", p2);
+    fc = process(fa, "RIGHT", p2);
+    fd = combine(fb, fc);
+file final<"FINAL">;
+final = diamond(1, 100);
Deleted: branches/tests-01/tests/file_counter.dtm
--- branches/tests-01/tests/file_counter.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/file_counter.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,20 +0,0 @@
-// a two-step workflow that essentially does
-// ls "*.txt" | wc
-type file {}
-(file f) ls (string s) {
-    app {
-        ls s stdout=@filename(f);
-(file c) wc (file f) {
-    app {
-        wc stdin=@filename(f) stdout=@filename(c);
-file list, count;
-list = ls("/");
-count = wc(list);
Copied: branches/tests-01/tests/file_counter.swift (from rev 3445, branches/tests-01/tests/file_counter.dtm)
--- branches/tests-01/tests/file_counter.swift	                        (rev 0)
+++ branches/tests-01/tests/file_counter.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,20 @@
+// a two-step workflow that essentially does
+// ls "*.txt" | wc
+type file {}
+(file f) ls (string s) {
+    app {
+        ls s stdout=@filename(f);
+(file c) wc (file f) {
+    app {
+        wc stdin=@filename(f) stdout=@filename(c);
+file list, count;
+list = ls("/");
+count = wc(list);
Deleted: branches/tests-01/tests/hello.dtm
--- branches/tests-01/tests/hello.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/hello.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,12 +0,0 @@
-type file {}
-(file t) echo (string s) {
-    app {
-file hw = echo("hello world");		// May need syntax to give a call a name.
Copied: branches/tests-01/tests/hello.swift (from rev 3445, branches/tests-01/tests/hello.dtm)
--- branches/tests-01/tests/hello.swift	                        (rev 0)
+++ branches/tests-01/tests/hello.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,12 @@
+type file {}
+(file t) echo (string s) {
+    app {
+file hw = echo("hello world");		// May need syntax to give a call a name.
Deleted: branches/tests-01/tests/helloworld.dtm
--- branches/tests-01/tests/helloworld.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/helloworld.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,8 +0,0 @@
-type file {}						//define a type for file
-(file t) echo (string s) { 			//procedure declaration
-    app {
-file hw = echo("hello world");		//procedure call
Copied: branches/tests-01/tests/helloworld.swift (from rev 3445, branches/tests-01/tests/helloworld.dtm)
--- branches/tests-01/tests/helloworld.swift	                        (rev 0)
+++ branches/tests-01/tests/helloworld.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,8 @@
+type file {}						//define a type for file
+(file t) echo (string s) { 			//procedure declaration
+    app {
+file hw = echo("hello world");		//procedure call
Deleted: branches/tests-01/tests/helloworld_named.dtm
--- branches/tests-01/tests/helloworld_named.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/helloworld_named.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,9 +0,0 @@
-    app {
-file hw<"helloworld.txt">;		//name the output file
-hw = echo("hello world");		//procedure call
Copied: branches/tests-01/tests/helloworld_named.swift (from rev 3445, branches/tests-01/tests/helloworld_named.dtm)
--- branches/tests-01/tests/helloworld_named.swift	                        (rev 0)
+++ branches/tests-01/tests/helloworld_named.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,9 @@
+    app {
+file hw<"helloworld.txt">;		//name the output file
+hw = echo("hello world");		//procedure call
Deleted: branches/tests-01/tests/language/should-not-work/1151-bad-comment.dtm
--- branches/tests-01/tests/language/should-not-work/1151-bad-comment.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/language/should-not-work/1151-bad-comment.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1 +0,0 @@
-/namedOutputs = waveletTransf(waveletScript, 101, "FB");
Copied: branches/tests-01/tests/language/should-not-work/1151-bad-comment.swift (from rev 3445, branches/tests-01/tests/language/should-not-work/1151-bad-comment.dtm)
--- branches/tests-01/tests/language/should-not-work/1151-bad-comment.swift	                        (rev 0)
+++ branches/tests-01/tests/language/should-not-work/1151-bad-comment.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1 @@
+/namedOutputs = waveletTransf(waveletScript, 101, "FB");
Deleted: branches/tests-01/tests/language/should-not-work/116-keyword-misuse-in.dtm
--- branches/tests-01/tests/language/should-not-work/116-keyword-misuse-in.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/language/should-not-work/116-keyword-misuse-in.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1 +0,0 @@
-in a;
Copied: branches/tests-01/tests/language/should-not-work/116-keyword-misuse-in.swift (from rev 3445, branches/tests-01/tests/language/should-not-work/116-keyword-misuse-in.dtm)
--- branches/tests-01/tests/language/should-not-work/116-keyword-misuse-in.swift	                        (rev 0)
+++ branches/tests-01/tests/language/should-not-work/116-keyword-misuse-in.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1 @@
+in a;
Deleted: branches/tests-01/tests/language/should-not-work/117-empty-program.dtm
--- branches/tests-01/tests/language/should-not-work/117-empty-program.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/language/should-not-work/117-empty-program.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1 +0,0 @@
Copied: branches/tests-01/tests/language/should-not-work/117-empty-program.swift (from rev 3445, branches/tests-01/tests/language/should-not-work/117-empty-program.dtm)
--- branches/tests-01/tests/language/should-not-work/117-empty-program.swift	                        (rev 0)
+++ branches/tests-01/tests/language/should-not-work/117-empty-program.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1 @@
Deleted: branches/tests-01/tests/language/should-not-work/case-broken2.dtm
--- branches/tests-01/tests/language/should-not-work/case-broken2.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/language/should-not-work/case-broken2.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,14 +0,0 @@
-switch(d)
-    case 1:
-     f(g);
-     break;
-    case 5:
-     j=7;
-     uuu=fn(t+7+e+3*2);
-     break;
-    default:
-     s="the default";
Copied: branches/tests-01/tests/language/should-not-work/case-broken2.swift (from rev 3445, branches/tests-01/tests/language/should-not-work/case-broken2.dtm)
--- branches/tests-01/tests/language/should-not-work/case-broken2.swift	                        (rev 0)
+++ branches/tests-01/tests/language/should-not-work/case-broken2.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,14 @@
+switch(d)
+    case 1:
+     f(g);
+     break;
+    case 5:
+     j=7;
+     uuu=fn(t+7+e+3*2);
+     break;
+    default:
+     s="the default";
Deleted: branches/tests-01/tests/language/should-not-work/closes.dtm
--- branches/tests-01/tests/language/should-not-work/closes.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/language/should-not-work/closes.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,2 +0,0 @@
Copied: branches/tests-01/tests/language/should-not-work/closes.swift (from rev 3445, branches/tests-01/tests/language/should-not-work/closes.dtm)
--- branches/tests-01/tests/language/should-not-work/closes.swift	                        (rev 0)
+++ branches/tests-01/tests/language/should-not-work/closes.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,2 @@
Modified: branches/tests-01/tests/nightly.sh
--- branches/tests-01/tests/nightly.sh	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/nightly.sh	2010-07-19 21:10:01 UTC (rev 3446)
@@ -9,28 +9,34 @@
 RUNDIR=$OUTDIR/$RUNDIRBASE
 mkdir -p $RUNDIR
-if [ "$1" == "-fco" ]; then
-	FCO=1
-	shift
-elif [ "$2" == "-fco" ]; then
-	FCO=1
-fi
+OUTBASE=$RUNDIRBASE/tests.log
-if [ "$1" == "" ]; then
-	OUTBASE=$RUNDIRBASE/tests.log
-else
-	OUTBASE=$RUNDIRBASE/$1
-fi
+BRANCH="branches/tests-01"
+while [ $# -gt 0 ]; do
+  case $1 in
+    -s)
+      SKIP_CHECKOUT=1
+      shift;;
+    -x)
+      EXIT_ON_ERROR=1
+      shift;;
+      OUTBASE=$RUNDIRBASE/$1
+      shift;;
+  esac
+done
 OUT=$OUTDIR/$OUTBASE
-head() {
+header() {
 	HTMLBASE=tests-$DATE.html
 	HTML=$OUTDIR/$HTMLBASE
 	rm -f $OUTDIR/current.html
 	#This doesn't work well with servers that don't follow symlinks
 	#ln -s $HTML $OUTDIR/current.html
 	cat <<DOH >$OUTDIR/current.html
 <html>
 	<head>
@@ -81,10 +87,10 @@
 	echo $@ >>$HTML
-tail() {
+footer() {
 	MONTHS=("" "Jan" "Feb" "Mar" "Apr" "May" "Jun" "Jul" "Aug" "Sep" "Oct" "Nov" "Dec")
 	html "</tr></table></tr></table>"
 	if [ "$BINPACKAGE" != "" ]; then
 		FBP=$OUTDIR/$BINPACKAGE
 		SIZE=`ls -hs $FBP`
@@ -95,7 +101,7 @@
 	<a href="$BINPACKAGE">$BINPACKAGE</a> ($SIZE)<br>
 DOH
 	fi
 	LASTYR="00"
 	LASTMO="00"
 	html "<h1>Older tests</h1>"
@@ -153,13 +159,13 @@
 	echo $@
 	TYPE=$1
 	if [ "$TYPE" == "test" ]; then
 		NAME=$2
 		SEQ=$3
 		CMD=$4
 		RES=$5
 		LOG=$6
 		if [ "$FIRSTTEST" == "1" ]; then
 			html "<h1>Test results</h1>"
 			html "<a name=\"tests\">"
@@ -171,12 +177,12 @@
 				html "</tr></table></tr>"
 			fi
 		fi
 		if [ "$TESTPART" != "" ]; then
 			html "<tr class=\"part\"><th colspan=\"2\">$TESTPART</th></tr>"
 			TESTPART=
 		fi
 		if [ "$FLUSH" == "1" ]; then
 			html "<tr class=\"testline\"><th align=\"right\">$NAME: </th><td><table border=\"0\"><tr>"
 		fi
@@ -193,13 +199,12 @@
 			html "<a href=\"$LOG\">$SEQ</a>"
 		fi
 		html "</td>"
 	elif [ "$TYPE" == "package" ]; then
 		BINPACKAGE=$2
 	else
 		html $@
 	fi
 aexec() {
@@ -214,7 +219,6 @@
 	if [ -f $OUTDIR/x73010test.log ]; then
 		cat $OUTDIR/x73010test.log >>$OUT
 	fi
 tlog() {
@@ -321,38 +325,36 @@
 head
 TESTPART="Part I: Build"
 EXITONFAILURE=true
-if [ "$FCO" != "1" ]; then
+if [ "$SKIP_CHECKOUT" != "1" ]; then
 	TEST="Checkout CoG"
 	pexec rm -rf cog
-	vexec svn co https://cogkit.svn.sourceforge.net/svnroot/cogkit/trunk/current/src/cog
+        COG="https://cogkit.svn.sourceforge.net/svnroot/cogkit/trunk/current/src/cog"
+	vexec svn co $COG
 	TEST="Checkout Swift"
-	pexec rm -rf trunk
-	#vexec cvs -d :pserver:anonymous at cvs.cogkit.org:/cvs/cogkit co src/vdsk
-	vexec svn co https://svn.ci.uchicago.edu/svn/vdl2/trunk
+        pexec cd cog/modules
+	pexec rm -rf swift
+	vexec svn co https://svn.ci.uchicago.edu/svn/vdl2/$BRANCH swift
+        pexec cd $OUTDIR
 fi
-TEST="Directory setup"
-pexec mkdir cog/modules/vdsk
-vexec cp -r trunk/* cog/modules/vdsk
 TEST="Compile"
-pexec cd cog/modules/vdsk
+pexec cd cog/modules/swift
 pexec rm -rf dist
 vexec ant -quiet dist
 TEST="Package"
 pexec cd dist
-VDSK=`ls -d vdsk*.*`
-pexec cd $VDSK/lib
+SWIFT=$( ls -d swift-* )
+pexec cd $SWIFT/lib
 pexec rm -f castor*.jar *gt2ft*.jar ant.jar
 pexec cd ../..
-pexec rm -rf vdsk-$DATE
-pexec mv $VDSK vdsk-$DATE
-vexec tar -pczf $OUTDIR/vdsk-$DATE.tar.gz vdsk-$DATE
-out package "vdsk-$DATE.tar.gz"
+pexec rm -rf swift-$DATE
+pexec mv $SWIFT swift-$DATE
+vexec tar -pczf $OUTDIR/swift-$DATE.tar.gz swift-$DATE
+out package "swift-$DATE.tar.gz"
-PATH=$PWD/vdsk-$DATE/bin:$PATH
+PATH=$PWD/swift-$DATE/bin:$PATH
 cd ..
 TESTDIR=$PWD/tests
 echo "Path: $PATH" >>$OUT
@@ -361,21 +363,18 @@
 EXITONFAILURE=false
 TESTPART="Part II: Local Tests"
-for TEST in `ls $TESTDIR/*.dtm $TESTDIR/*.swift`; do
-	BN=`basename $TEST`
-	echo $BN
-	cp $TESTDIR/$BN .
-	TESTNAME=${BN%.dtm}
-	TESTNAME=${TESTNAME%.swift}
-	TEST="<a href=\"$RUNDIRBASE/$BN\">$TESTNAME</a>"
-	ssexec "Compile" vdlc $BN
-	for ((i=0; $i<9; i=$i+1)); do
-		pexec swift -sites.file ~/.vdl2/sites-local.xml $TESTNAME.kml
-	done
-	vexec swift -sites.file ~/.vdl2/sites-local.xml $TESTNAME.kml
+for TEST in $( ls $TESTDIR/*.swift ); do # $TESTDIR/*.dtm
+  TESTNAME=$( basename $TEST)
+  echo TESTNAME: $TESTNAME
+  cp -uv $TESTDIR/$TESTNAME .
+  TEST="<a href=\"$RUNDIRBASE/$TESTNAME\">$TESTNAME</a>"
+  # ssexec "Compile" vdlc $BN
+  for ((i=0; $i<9; i=$i+1)); do
+    pexec swift -sites.file ~/.vdl2/sites-local.xml $TESTNAME
+  done
+  vexec swift -sites.file ~/.vdl2/sites-local.xml $TESTNAME
 done
 TESTPART="Part III: Grid Tests"
@@ -384,11 +383,11 @@
 	BN=`basename $TEST`
 	echo $BN
 	cp $TESTDIR/$BN .
 	TESTNAME=${BN%.dtm}
 		pexec swift -sites.file ~/.vdl2/sites-grid.xml $TESTNAME.kml
@@ -397,4 +396,4 @@
 done
 #Don't remove me:
-tail
+footer
Deleted: branches/tests-01/tests/range.dtm
--- branches/tests-01/tests/range.dtm	2010-07-19 21:06:11 UTC (rev 3445)
+++ branches/tests-01/tests/range.dtm	2010-07-19 21:10:01 UTC (rev 3446)
@@ -1,5 +0,0 @@
-int nums[] = [0:20:2];  // generate a list 0, 2, 4, 6, 8 ...
-foreach num in nums {
-	print(num);
Copied: branches/tests-01/tests/range.swift (from rev 3445, branches/tests-01/tests/range.dtm)
--- branches/tests-01/tests/range.swift	                        (rev 0)
+++ branches/tests-01/tests/range.swift	2010-07-19 21:10:01 UTC (rev 3446)
@@ -0,0 +1,5 @@
+int nums[] = [0:20:2];  // generate a list 0, 2, 4, 6, 8 ...
+foreach num in nums {
+	print(num);
