[Swift-commit] r3443 - in trunk/src/org/griphyn/vdl/karajan: functions lib
noreply at svn.ci.uchicago.edu
Mon Jul 19 13:38:36 CDT 2010
Author: wozniak
Date: 2010-07-19 13:38:36 -0500 (Mon, 19 Jul 2010)
New Revision: 3443
Modified:
trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java
trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
Log:
Drop unused imports; whitespace
Modified: trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java
--- trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java 2010-07-19 18:36:58 UTC (rev 3442)
+++ trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java 2010-07-19 18:38:36 UTC (rev 3443)
@@ -33,19 +33,19 @@
boolean instance = TypeUtil.toBoolean(INSTANCE.getValue(stack));
Object host = HOST.getValue(stack);
if(logger.isDebugEnabled()) {
- logger.debug("Getting property "+name+" with host "+host);
- if(host!= null) {
- // see if the host has this property defined, and if so
- // get its value
- BoundContact h = (BoundContact)host;
- String prop = (String) h.getProperty(name);
- if(prop != null) {
- logger.debug("Found property "+name+" in BoundContact");
- return prop;
- logger.debug("Could not find property "+name+" in BoundContact");
+ logger.debug("Getting property "+name+" with host "+host);
+ if(host!= null) {
+ // see if the host has this property defined, and if so
+ // get its value
+ BoundContact h = (BoundContact)host;
+ String prop = (String) h.getProperty(name);
+ if(prop != null) {
+ logger.debug("Found property "+name+" in BoundContact");
+ return prop;
+ logger.debug("Could not find property "+name+" in BoundContact");
return getProperty(name, instance, stack);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Execute.java 2010-07-19 18:36:58 UTC (rev 3442)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Execute.java 2010-07-19 18:38:36 UTC (rev 3443)
@@ -46,7 +46,7 @@
Object constraints) throws ExecutionException {
try {
registerReplica(stack, task);
- log(task, stack);
+ log(task, stack);
scheduler.addJobStatusListener(this, task);
synchronized (tasks) {
tasks.put(task, stack);
@@ -61,32 +61,32 @@
- void log(Task task, VariableStack stack)
- throws ExecutionException
- if (logger.isDebugEnabled()) {
- logger.debug(task);
- logger.debug("Submitting task " + task);
- String jobid = (String)A_JOBID.getValue(stack,null);
- logger.debug("jobid="+jobid+" task=" + task);
- else if (logger.isInfoEnabled()) {
- Specification spec = task.getSpecification();
- if (spec instanceof JobSpecification) {
- JobSpecification jobspec = (JobSpecification) spec;
- logger.info("Submit: " +
- "in: " + jobspec.getDirectory() +
- " command: " + jobspec.getExecutable() +
- " " + jobspec.getArguments());
- else {
- logger.info("Submit: " + spec);
+ void log(Task task, VariableStack stack)
+ throws ExecutionException
+ if (logger.isDebugEnabled()) {
+ logger.debug(task);
+ logger.debug("Submitting task " + task);
+ String jobid = (String) A_JOBID.getValue(stack,null);
+ logger.debug("jobid="+jobid+" task=" + task);
+ else if (logger.isInfoEnabled()) {
+ Specification spec = task.getSpecification();
+ if (spec instanceof JobSpecification) {
+ JobSpecification jobspec = (JobSpecification) spec;
+ logger.info("Submit: " +
+ "in: " + jobspec.getDirectory() +
+ " command: " + jobspec.getExecutable() +
+ " " + jobspec.getArguments());
+ else {
+ logger.info("Submit: " + spec);
protected void registerReplica(VariableStack stack, Task task) throws CanceledReplicaException {
setTaskIdentity(stack, task);
try {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2010-07-19 18:36:58 UTC (rev 3442)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java 2010-07-19 18:38:36 UTC (rev 3443)
@@ -15,9 +15,6 @@
import org.griphyn.vdl.mapping.InvalidPathException;
import org.griphyn.vdl.mapping.Path;
-import edu.emory.mathcs.backport.java.util.concurrent.ExecutorService;
-import edu.emory.mathcs.backport.java.util.concurrent.Executors;
public class SetFieldValue extends VDLFunction {
public static final Logger logger = Logger.getLogger(SetFieldValue.class);
@@ -69,10 +66,10 @@
if (leaf instanceof AbstractDataNode) {
AbstractDataNode data = (AbstractDataNode) leaf;
- Path path = data.getPathFromRoot();
- String p = path.toString();
- if (p.equals("$"))
- p = "";
+ Path path = data.getPathFromRoot();
+ String p = path.toString();
+ if (p.equals("$"))
+ p = "";
String name = data.getDisplayableName() + p;
logger.info("Set: " + name + "=" + value);
More information about the Swift-commit
