[Swift-commit] r3215 - trunk/docs
noreply at svn.ci.uchicago.edu
Sun Jan 24 18:01:37 CST 2010
Author: hategan
Date: 2010-01-24 18:01:37 -0600 (Sun, 24 Jan 2010)
New Revision: 3215
Modified:
trunk/docs/userguide.xml
Log:
added example on how to specify maxwalltime in tc.data
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml 2010-01-25 00:00:38 UTC (rev 3214)
+++ trunk/docs/userguide.xml 2010-01-25 00:01:37 UTC (rev 3215)
@@ -3234,6 +3234,10 @@
<listitem>Hours:Minutes:Seconds</listitem>
</itemizedlist>
</para>
+ <para>Example:</para>
+<screen>
+localhost echo /bin/echo INSTALLED INTEL32::LINUX GLOBUS::maxwalltime="00:20:00"
+</screen>
<para>When replication is enabled (see <link linkend="replication">replication</link>), then walltime will also be enforced at the Swift client side: when
a job has been active for more than twice the maxwalltime, Swift will kill the
job and regard it as failed.
More information about the Swift-commit
