[Swift-commit] r3255 - SwiftApps/SwiftR
noreply at svn.ci.uchicago.edu
Thu Feb 25 22:24:59 CST 2010
Author: wilde
Date: 2010-02-25 22:24:59 -0600 (Thu, 25 Feb 2010)
New Revision: 3255
Added:
SwiftApps/SwiftR/TODO
SwiftApps/SwiftR/TestOpenMx1.R
Log:
Add TODO list and temporary OpenMx text.
Added: SwiftApps/SwiftR/TODO
--- SwiftApps/SwiftR/TODO (rev 0)
+++ SwiftApps/SwiftR/TODO 2010-02-26 04:24:59 UTC (rev 3255)
@@ -0,0 +1,35 @@
+x n args
+x batch
+x into svn
+x unique dirs
+_ select sites and swift args (throttles etc)
+ R docs
+ R package (SwiftR)
+ Swift docs
+ async exec
+ clean up boot: fix all calls to statistics; update boot package w/ pboot() or swiftboot()
+ error handling and null and missing values: ensure res#s correspond to arg#s
+ status
+ specify swift scripts
+ run async and grab status (track 'runs' in R)
+ increm result collect
+ pass the func as val
+ pass extra funcs and packages required
+ pass extra vals
+ pass extra files
+ specifiy unique swift scritps ala Dirk's tools
+ setup the R envs (???)
+ coasters for persistent R Servers
+ test suites
+ use littleR
+ args as alists vs args as list
+ runids, output logging
+ select exec sites and swift params etc
+ make polymorphic to *apply and snow
+ stream results back to R (so use can inspect as they arrive)
+ (pull them in with a Swift.poll() func)
+ handle discontiguous results
+ return good error messages including messages from R eval and from Swift
+ TUI
+ Name pbs jobs mnemonically
Added: SwiftApps/SwiftR/TestOpenMx1.R
--- SwiftApps/SwiftR/TestOpenMx1.R (rev 0)
+++ SwiftApps/SwiftR/TestOpenMx1.R 2010-02-26 04:24:59 UTC (rev 3255)
@@ -0,0 +1,16 @@
+require(OpenMx)
+ data(demoOneFactor)
+ manifests <- names(demoOneFactor)
+ latents <- c("G")
+ factorModel <- mxModel("One Factor",
+ type="RAM",
+ manifestVars = manifests,
+ latentVars = latents,
+ mxPath(from=latents, to=manifests),
+ mxPath(from=manifests, arrows=2),
+ mxPath(from=latents, arrows=2, free=F, values=1.0),
+ mxData(observed=cov(demoOneFactor), type="cov", numObs=500))
+ summary(mxRun(factorModel))
More information about the Swift-commit
