[Swift-commit] r3253 - SwiftApps/SwiftR
Tue Feb 23 12:32:38 CST 2010
Author: wilde
Date: 2010-02-23 12:32:38 -0600 (Tue, 23 Feb 2010)
New Revision: 3253
Modified:
   SwiftApps/SwiftR/RunSwiftScript.sh
   SwiftApps/SwiftR/Swift.R
   SwiftApps/SwiftR/TestSwift.R
   SwiftApps/SwiftR/bootstrapdemo.R
   SwiftApps/SwiftR/pboot.R
Log:
Incremental commit: Added swiftopts; adjusted boot() demo; changed = to <- to slowly get R-ified.
Modified: SwiftApps/SwiftR/RunSwiftScript.sh
--- SwiftApps/SwiftR/RunSwiftScript.sh	2010-02-23 04:36:05 UTC (rev 3252)
+++ SwiftApps/SwiftR/RunSwiftScript.sh	2010-02-23 18:32:38 UTC (rev 3253)
@@ -22,7 +22,7 @@
     <execution provider="coaster" url="none" jobManager="local:pbs"/>
     <profile namespace="globus" key="workersPerNode">8</profile>
     <profile namespace="karajan" key="initialScore">10000</profile>
-    <profile namespace="karajan" key="jobThrottle">.00</profile>
+    <profile namespace="karajan" key="jobThrottle">5.99</profile>
     <filesystem provider="local"/>
     <workdirectory>$(pwd)</workdirectory>
   </pool>
Modified: SwiftApps/SwiftR/Swift.R
--- SwiftApps/SwiftR/Swift.R	2010-02-23 04:36:05 UTC (rev 3252)
+++ SwiftApps/SwiftR/Swift.R	2010-02-23 18:32:38 UTC (rev 3253)
@@ -1,38 +1,63 @@
-swiftapply <- function( func, arglists, site="local", callsperbatch=1 )
+if(is.null(swiftprops)) {
+  swiftprops.site <- "local"
+  swiftprops$callsperbatch <- 1
+swiftapply <- function( func, arglists, site=NULL, callsperbatch=NULL )
-  rundir = system("mktemp -d SwiftR.run.XXX",intern=TRUE)
-  cat("Running in ",rundir,"\n")
-  narglists = length(arglists) # number of arglists to process
-  batch=1   # Next arglist batch number to fill
-  arglist=1 # Next arglist number to insert
+  # Set Swift properties
+  if(is.null(site))
+    if( is.null(swiftprops) || is.null(swiftprops$site))
+      site <- "local"
+    else
+      site <- swiftprops$site
+  if(is.null(callsperbatch))
+    if( is.null(swiftprops) || is.null(swiftprops$callsperbatch))
+      callsperbatch <- 1
+    else
+       callsperbatch <- swiftprops$callsperbatch
+  cat("\nSwift R properties:\n")
+  cat("  site =",site,"\n");
+  cat("  callsperbatch =",callsperbatch,"\n")
+  # Execute the calls in batches
+  rundir <- system("mktemp -d SwiftR.run.XXX",intern=TRUE)
+  cat("Swift running in",rundir,"\n")
+  narglists <- length(arglists) # number of arglists to process
+  batch <- 1   # Next arglist batch number to fill
+  arglist <- 1 # Next arglist number to insert
   while(arglist <= narglists) {
-    arglistsleft = narglists - arglist + 1
+    arglistsleft <- narglists - arglist + 1
     if(arglistsleft >= callsperbatch) {
-      batchsize = callsperbatch
+      batchsize <- callsperbatch
     else {
-      batchsize = arglistsleft
+      batchsize <- arglistsleft
-    arglistbatch = list()
+    arglistbatch <- list()
     for(i in 1 : batchsize) {
-      arglistbatch[[i]] = arglists[[arglist]]
-      arglist = arglist +1
+      arglistbatch[[i]] <- arglists[[arglist]]
+      arglist <- arglist +1
-    rcall = list(func=func,arglistbatch=arglistbatch)
+    rcall <- list(func=func,arglistbatch=arglistbatch)
     save(rcall,file=paste(rundir,"/cbatch.",as.character(batch),".Rdata",sep=""))
-    batch = batch + 1;
+    batch <- batch + 1;
-  nbatches = batch - 1
+  nbatches <- batch - 1
   system(paste("./RunSwiftScript.sh",rundir,site,sep=" "))
-  rno = 1
-  rlist = list()
+  # Fetch the batch results
+  rno <- 1
+  rlist <- list()
   for(batch in 1:nbatches) {
     load(paste(rundir,"/rbatch.",as.character(batch),".Rdata",sep=""))
-    nresults = length(result)
+    nresults <- length(result)
     for(r in 1:nresults) {
-      rlist[[rno]] = result[[r]]
-      rno = rno + 1
+      rlist[[rno]] <- result[[r]]
+      rno <- rno + 1
   return(rlist)
@@ -42,14 +67,14 @@
 x n args
 x batch
-  into svn
-  unique dirs
-  select sites and swift args (throttles etc)
+x into svn
+x unique dirs
+_ select sites and swift args (throttles etc)
   R docs
   R package (SwiftR)
   Swift docs
   async exec
-  clean up boot: fix all calls to statistics
+  clean up boot: fix all calls to statistics; update boot package w/ pboot() or swiftboot()
   error handling and null and missing values: ensure res#s correspond to arg#s
   status
   specify swift scripts
@@ -60,7 +85,7 @@
   pass extra vals
   pass extra files
   specifiy unique swift scritps ala Dirk's tools
-  setup the R envs
+  setup the R envs (???)
   coasters for persistent R Servers
   test suites
   use littleR
Modified: SwiftApps/SwiftR/TestSwift.R
--- SwiftApps/SwiftR/TestSwift.R	2010-02-23 04:36:05 UTC (rev 3252)
+++ SwiftApps/SwiftR/TestSwift.R	2010-02-23 18:32:38 UTC (rev 3253)
@@ -1,42 +1,48 @@
 require(boot)
 source("Swift.R")
-SKIP=FALSE
 sumcrits <- function(duckdata,dogdata) { sum( duckdata$plumage, dogdata$mvo ) }
 args=list(ducks,dogs)
 arglist = rep(list(args),9)
-if(SKIP) {
+if(TRUE) { # Basic tests
-res = do.call(sumcrits,args)
-cat("Test of do.call(sumcrits)\n")
-print(res)
+    res = do.call(sumcrits,args)
+    cat("Test of do.call(sumcrits)\n")
+    print(res)
-cat("\nTest of swiftapply(sumcrits,arglist)\n")
-res = swiftapply(sumcrits,arglist)
-print(res)
+    cat("\nTest of swiftapply(sumcrits,arglist)\n")
+    res = swiftapply(sumcrits,arglist)
+    print(res)
-cat("\nTest of swiftapply(sumcrits,arglist,callsperbatch=10)\n")
-res = swiftapply(sumcrits,arglist,callsperbatch=10)
-print(res)
+if(FALSE) { # Test various batch sizes
-cat("\nTest of swiftapply(sumcrits,arglist,callsperbatch=2)\n")
-res = swiftapply(sumcrits,arglist,callsperbatch=2)
-print(res)
+    cat("\nTest of swiftapply(sumcrits,arglist,callsperbatch=10)\n")
+    res = swiftapply(sumcrits,arglist,callsperbatch=10)
+    print(res)
-cat("\nTest of swiftapply(sumcrits,arglist,callsperbatch=3)\n")
-res = swiftapply(sumcrits,arglist,callsperbatch=3)
-print(res)
+    cat("\nTest of swiftapply(sumcrits,arglist,callsperbatch=2)\n")
+    res = swiftapply(sumcrits,arglist,callsperbatch=2)
+    print(res)
-cat("\nTest of swiftapply(sumcrits,arglist,callsperbatch=20)\n")
-res = swiftapply(sumcrits,arglist,callsperbatch=20)
-print(res)
+    cat("\nTest of swiftapply(sumcrits,arglist,callsperbatch=3)\n")
+    res = swiftapply(sumcrits,arglist,callsperbatch=3)
+    print(res)
-} # END SKIP
+    cat("\nTest of swiftapply(sumcrits,arglist,callsperbatch=20)\n")
+    res = swiftapply(sumcrits,arglist,callsperbatch=20)
+    print(res)
-cat("\nTest of swiftapply(sumcrits,arglist[1000],callsperbatch=1)\n")
-arglist = rep(list(args),1000)
-res = swiftapply(sumcrits,arglist,callsperbatch=2,site="pbs")
-print(res[[1]])
-print(res[[1000]])
+if(FALSE) { # Larger-scale tests
+    cat("\nTest of swiftapply(sumcrits,arglist[1000],callsperbatch=1)\n")
+    arglist = rep(list(args),1000)
+    res = swiftapply(sumcrits,arglist,callsperbatch=2,site="pbs")
+    print(res[[1]])
+    print(res[[1000]])
Modified: SwiftApps/SwiftR/bootstrapdemo.R
--- SwiftApps/SwiftR/bootstrapdemo.R	2010-02-23 04:36:05 UTC (rev 3252)
+++ SwiftApps/SwiftR/bootstrapdemo.R	2010-02-23 18:32:38 UTC (rev 3253)
@@ -8,6 +8,13 @@
 require(OpenMx)
 require(boot)
+# Update the boot() function to call swiftapply() for parallel execution.
+if(FALSE) {
+  source("pboot.R")
+  assignInNamespace("boot",boot,"boot")
 # Define a function called mles which will return maximum likelihood estimates
 # It uses the demoOneFactor dataset and one factor model on the OpenMx homepage
 # http://openmx.psyc.virginia.edu
@@ -32,12 +39,8 @@
 # Run 100 bootstraps (a smallish number)
-boot.out=list()
+system.time(boot(demoOneFactor,mles,R=10000))
-boot.out[[1]] = pboot(demoOneFactor,mles,R=100)
-#boot.out[[2]] = boot(demoOneFactor,mles,R=8)
-#boot.out[[3]] = boot(demoOneFactor,mles,R=9)
 print("done booting - boot.out is:")
 print(boot.out)
 print("end of boot.out")
Modified: SwiftApps/SwiftR/pboot.R
--- SwiftApps/SwiftR/pboot.R	2010-02-23 04:36:05 UTC (rev 3252)
+++ SwiftApps/SwiftR/pboot.R	2010-02-23 18:32:38 UTC (rev 3253)
@@ -1,4 +1,4 @@
-pboot =
+boot =
 function (data, statistic, R, sim = "ordinary", stype = "i",
           strata = rep(1, n), L = NULL, m = 0, weights = NULL,
           ran.gen = function(d, p) d, mle = NULL, simple = FALSE, ...)
@@ -106,7 +106,7 @@
             # for (r in 1L:sum(R)) t.star[r, ] <- statistic(data, i[r, ], ...)
             alists = list()
             for (r in 1L:sum(R)) alists[[r]] <- list(data,i[r,],...)
-            reslist = swiftapplyb(statistic,alists,callsperbatch=25)
+            reslist = swiftapply(statistic,alists,callsperbatch=25)
             for (r in 1L:sum(R)) t.star[r, ] <- reslist[[r]]
