[Swift-commit] r3237 - trunk/libexec
Fri Feb 12 14:32:49 CST 2010
Author: wozniak
Date: 2010-02-12 14:32:49 -0600 (Fri, 12 Feb 2010)
New Revision: 3237
Modified:
   trunk/libexec/_swiftwrap
   trunk/libexec/cdm.pl
   trunk/libexec/vdl-int.k
   trunk/libexec/vdl-lib.xml
Log:
Basic CDM GATHER policy.
Modified: trunk/libexec/_swiftwrap
--- trunk/libexec/_swiftwrap	2010-02-10 18:34:11 UTC (rev 3236)
+++ trunk/libexec/_swiftwrap	2010-02-12 20:32:49 UTC (rev 3237)
@@ -1,4 +1,5 @@
 # this script must be invoked inside of bash, not plain sh
+# note that this script modifies $IFS
 infosection() {
         echo >& "$INFO"
@@ -132,7 +133,7 @@
 	RESULT="DEFAULT"
 	if [ -f shared/cdm.pl ]; then
-		RESULT=$( perl shared/cdm.pl $FILE < $CDM_FILE )
+		RESULT=$( perl shared/cdm.pl lookup $FILE < $CDM_FILE )
 	fi
 	echo $RESULT
@@ -177,9 +178,23 @@
 				fail 254 "Cannot BROADCAST an output file!"
 			fi
+		GATHER)
+			if [ $MODE == "INPUT" ]; then
+				fail 254 "Cannot GATHER an input file!"
+			fi
 	esac
+cdm_gather()
+	GATHER_OUTPUT=${*}
+	if [[ $CDM_FILE == "" ]]; then
+		return
+	fi
+	cdm_gather_action $GATHER_MAX $GATHER_OUTPUT
 COMMANDLINE=$@
 # get the parent directory of the directory containing _swiftwrap, to use
@@ -263,7 +278,10 @@
 shift $SHIFTCOUNT
 getarg "-cdmfile" "$@"
-CDM_FILE=$VALUE
+CDM_FILE=
+if [ "X$VALUE" != "X" ]; then
+	CDM_FILE=shared/$VALUE
+fi
 shift $SHIFTCOUNT
 getarg "-status" "$@"
@@ -293,6 +311,12 @@
 	mkdir -p $WFDIR/status/$JOBDIR
 fi
+if [ "X$CDM_FILE" != "X" ]; then
+	logstate "SOURCE_CDM_LIB $WFDIR/shared/cdm_lib.sh"
+	source $WFDIR/shared/cdm_lib.sh
+	checkError 254 "Could not source: $WFDIR/shared/cdm_lib.sh"
+fi
 if [ "X$SCRATCH" != "X" ]; then
 	log "Job directory mode is: local copy"
 	DIR=$SCRATCH/$JOBDIR/$ID
@@ -348,14 +372,11 @@
 	log "Created output directory: $DIR/$D"
 done
-log "PWD: $( pwd )"
-log "FIND: $( find . )"
 logstate "LINK_INPUTS"
 for L in $INF ; do
-        CDM_POLICY=$( cdm_lookup $L shared/$CDM_FILE )
-	log "CDM_POLICY: $L -> $CDM_POLICY"
+        CDM_POLICY=$( cdm_lookup $L $CDM_FILE )
 	if [ $CDM_POLICY != "DEFAULT" ]; then
+		log "CDM_POLICY: $L -> $CDM_POLICY"
     	        eval cdm_action $DIR "INPUT" $L $CDM_POLICY
 		continue
 	fi
@@ -374,13 +395,17 @@
 logstate "LINK_CDM_OUTPUTS"
 SKIPPED_OUTPUT=()
+GATHER_OUTPUT=()
 for L in $OUTF ; do
     	        eval cdm_action $DIR "OUTPUT" $L $CDM_POLICY
 		SKIPPED_OUTPUT=( $SKIPPED_OUTPUT $L )
 	fi
+	if [ $CDM_POLICY == "GATHER" ]; then
+		GATHER_OUTPUT=( $GATHER_OUTPUT $L )
+	fi
 done
 logstate "EXECUTE"
@@ -456,23 +481,21 @@
 logstate "MOVING_OUTPUTS $OUTF"
 for O in $OUTF ; do
-	log "output: $O"
 	if ! contains SKIPPED_OUTPUT $O ; then
 		mv -v "$DIR/$O" "$WFDIR/shared/$O" 2>&1 >&	"$INFO"
 		checkError 254 "Failed to move output file $O to shared directory"
-	else
-		log "CDM: SKIPPED_OUTPUT: $O"
 	fi
 done
+cdm_gather $GATHER_OUTPUT
 logstate "RM_JOBDIR"
-# rm -rf "$DIR" 2>&1 >& "$INFO"
+rm -rf "$DIR" 2>&1 >& "$INFO"
 checkError 254 "Failed to remove job directory $DIR"
 if [ "$STATUSMODE" = "files" ]; then
 	logstate "TOUCH_SUCCESS"
 	touch $WFDIR/status/${JOBDIR}/${ID}-success
-	log "TOUCH CODE: $WFDIR/status/${JOBDIR}/${ID}-success $?"
 fi
 logstate "END"
Modified: trunk/libexec/cdm.pl
--- trunk/libexec/cdm.pl	2010-02-10 18:34:11 UTC (rev 3236)
+++ trunk/libexec/cdm.pl	2010-02-12 20:32:49 UTC (rev 3237)
@@ -29,22 +29,74 @@
     print "$result\n";
+sub cdm_property
+    my $hash = $_[0];
+    my $name = $_[1];
+    $result = "UNSET";
+    foreach (keys %$hash)
+	$property = $_;
+	if ($name eq $property)
+	    $result = "$$hash{$property}\n";
+	    last;
+    print "$result\n";
 # Command-line arguments:
-$file = $ARGV[0];
+$task = $ARGV[0];
+$arg  = $ARGV[1];
 # Read fs.data off of stdin:
 @keys = ();
 %map  = ();
+%properties = ();
 while (<STDIN>)
     chomp;
+    my $comment = index $_, "#";
+    if ($comment >= 0) {
+	$_ = substr($_, 0, $comment);
     next if $_ eq "";
     @tokens = split(/ /, $_);
-    $key    = shift(@tokens);
-    $rest   = join(' ', @tokens);
-    @keys   = (@keys, $key);
-    $map{$key} = $rest;
+    $type   = shift(@tokens);
+    if ($type eq "rule")
+	$key    = shift(@tokens);
+	$rest   = join(' ', @tokens);
+	@keys   = (@keys, $key);
+	$map{$key} = $rest;
+    elsif ($type eq "property")
+	$property = shift(@tokens);
+	$properties{$property} = $rest;
+    else
+	die "Unknown directive: $type";
-cdm_lookup(\@keys, \%map, $file);
+# Do the user task:
+if ($task eq "lookup")
+    cdm_lookup(\@keys, \%map, $arg);
+elsif ($task eq "property")
+    cdm_property(\%properties, $arg);
+else
+    die "Unknown task: $task";
Modified: trunk/libexec/vdl-int.k
--- trunk/libexec/vdl-int.k	2010-02-10 18:34:11 UTC (rev 3236)
+++ trunk/libexec/vdl-int.k	2010-02-12 20:32:49 UTC (rev 3237)
@@ -191,6 +191,25 @@
 		element(cleanup, [dir, host]
 			log(LOG:INFO, "START dir={dir} host={host}")
+			cdmfile := cdm:file()
+			log(LOG:INFO, "cdmfile {cdmfile}")
+			if(cdmfile != "" then(
+				log(LOG:INFO, "submitting cdm_cleanup.sh to {dir}")
+				task:transfer(srcfile="cdm_cleanup.sh",
+					      srcdir="{swift.home}/libexec",
+					      desthost=host, destdir=dir)
+				task:transfer(srcfile="cdm_lib.sh",
+			        log(LOG:INFO, "execute: cdm_cleanup.sh")
+				task:execute(
+					     executable="/bin/bash",
+					     arguments=list("{dir}/cdm_cleanup.sh",
+					                     cdm:get("GATHER_DIR"), cdm:get("GATHER_TARGET")
+							     sys:uid() )
+					     host=host, batch=true, tcprofile(host))
 			if(vdl:configProperty("sitedir.keep") == "false"
 				task:execute(
 					vdl:siteprofile(host, "swift:cleanupCommand"),
@@ -259,6 +278,9 @@
 				doStageinFile(provider="file", srchost="localhost", srcfile="cdm.pl",
 					    	srcdir=libexec, desthost=host, destdir=dir,
 						size=file:size("{libexec}/cdm.pl}"), policy="DEFAULT")
+				doStageinFile(provider="file", srchost="localhost", srcfile="cdm_lib.sh",
+					    	srcdir=libexec, desthost=host, destdir=dir,
+						size=file:size("{libexec}/cdm_lib.sh}"), policy="DEFAULT")
 			uParallelFor(file, files
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml	2010-02-10 18:34:11 UTC (rev 3236)
+++ trunk/libexec/vdl-lib.xml	2010-02-12 20:32:49 UTC (rev 3237)
@@ -100,7 +100,7 @@
   <namespace prefix="cdm">
   	<export name="query"><elementDef classname="org.globus.swift.data.Query"/></export>
-	<export name="property"><elementDef classname="org.globus.swift.data.Query"/></export>
+	<export name="get"><elementDef classname="org.globus.swift.data.Query"/></export>
   	<export name="file"><elementDef classname="org.globus.swift.data.Query"/></export>
   	<export name="broadcast"><elementDef classname="org.globus.swift.data.Action"/></export>
   </namespace>
