[Swift-commit] r3225 - trunk/libexec
noreply at svn.ci.uchicago.edu
Thu Feb 4 12:35:53 CST 2010
Author: wozniak
Date: 2010-02-04 12:35:53 -0600 (Thu, 04 Feb 2010)
New Revision: 3225
Modified:
trunk/libexec/_swiftwrap
Log:
Output fixes for CDM files.
Also contains whitespace style corrections.
Modified: trunk/libexec/_swiftwrap
--- trunk/libexec/_swiftwrap 2010-02-04 18:33:35 UTC (rev 3224)
+++ trunk/libexec/_swiftwrap 2010-02-04 18:35:53 UTC (rev 3225)
@@ -1,7 +1,7 @@
# this script must be invoked inside of bash, not plain sh
infosection() {
- echo >& "$INFO"
+ echo >& "$INFO"
echo "_____________________________________________________________________________" >& "$INFO"
echo >& "$INFO"
echo " $1" >& "$INFO"
@@ -98,7 +98,7 @@
done
VALUE="${VALUE:1}"
elif [ "$PARAMFILE" != "" ] && grep -E "^$NAME " $PARAMFILE ; then
- VALUE=$(grep -E "^$NAME " $PARAMFILE | cut -d ' ' -f 2-)
+ VALUE=$(grep -E "^$NAME " $PARAMFILE | cut -d ' ' -f 2-)
else
fail 254 "Missing $NAME argument"
fi
@@ -113,35 +113,48 @@
exec 3>&-
+contains() {
+ ARRAY=$1
+ X=$2
+ for a in ${!ARRAY}
+ do
+ if [[ ${a} == ${X} ]]; then
+ return 0
+ fi
+ done
+ return 1
cdm() {
- log "CDM: $@"
+ log "CDM: $@"
- local JOBDIR=$1 # Given jobdir
- local MODE=$2 # INPUT or OUTPUT
- local FILE=$3 # User file
- local POLICY=$4 # DIRECT, BROADCAST, ...
- shift 4
- local ARGS=$@
+ local JOBDIR=$1 # Given jobdir
+ local MODE=$2 # INPUT or OUTPUT
+ local FILE=$3 # User file
+ local POLICY=$4 # DIRECT, BROADCAST, ...
+ shift 4
+ local ARGS=$@
- case $POLICY in
- DIRECT)
- DIRECT_DIR=${ARGS[0]}
- log "CDM[DIRECT]: Linking $JOBDIR/$FILE to $DIRECT_DIR/$FILE"
- if [ $MODE == "INPUT" ]; then
- [ -f "$DIRECT_DIR/$FILE" ]
- checkError 254 "CDM[DIRECT]: $DIRECT_DIR/$FILE does not exist!"
- ln -s $DIRECT_DIR/$FILE $JOBDIR/$FILE
- checkError 254 "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE failed!"
- elif [ $MODE == "OUTPUT" ]; then
- touch $DIRECT_DIR/$FILE
- checkError 254 "CDM[DIRECT]: Touching $DIRECT_DIR/$FILE failed!"
- else
- fail 254 "Unknown MODE: $MODE"
- fi
- esac
+ case $POLICY in
+ DIRECT)
+ DIRECT_DIR=${ARGS[0]}
+ log "CDM[DIRECT]: Linking $JOBDIR/$FILE to $DIRECT_DIR/$FILE"
+ if [ $MODE == "INPUT" ]; then
+ [ -f "$DIRECT_DIR/$FILE" ]
+ checkError 254 "CDM[DIRECT]: $DIRECT_DIR/$FILE does not exist!"
+ ln -s $DIRECT_DIR/$FILE $JOBDIR/$FILE
+ checkError 254 "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE failed!"
+ elif [ $MODE == "OUTPUT" ]; then
+ touch $DIRECT_DIR/$FILE
+ checkError 254 "CDM[DIRECT]: Touching $DIRECT_DIR/$FILE failed!"
+ else
+ fail 254 "Unknown MODE: $MODE"
+ fi
+ esac
COMMANDLINE=$@
@@ -257,13 +270,13 @@
fi
if [ "X$SCRATCH" != "X" ]; then
- log "Job directory mode is: local copy"
- DIR=$SCRATCH/$JOBDIR/$ID
- COPYNOTLINK=1
+ log "Job directory mode is: local copy"
+ DIR=$SCRATCH/$JOBDIR/$ID
+ COPYNOTLINK=1
else
- log "Job directory mode is: link on shared filesystem"
- DIR=jobs/$JOBDIR/$ID
- COPYNOTLINK=0
+ log "Job directory mode is: link on shared filesystem"
+ DIR=jobs/$JOBDIR/$ID
+ COPYNOTLINK=0
fi
PATH=$PATH:/bin:/usr/bin
@@ -337,13 +350,13 @@
done
logstate "LINK_CDM_OUTPUTS"
+SKIPPED_OUTPUT=()
for L in $OUTF ; do
CDM_POLICY=$( perl shared/cdm.pl $L < shared/$CDM_FILE )
log "CDM_POLICY: $CDM_POLICY"
if [ $CDM_POLICY != "DEFAULT" ]; then
eval cdm $DIR "OUTPUT" $L $CDM_POLICY
- eval CDM_OUTPUT_$L="SKIP"
- break
+ SKIPPED_OUTPUT=( $SKIPPED_OUTPUT $L )
fi
done
@@ -406,7 +419,6 @@
MISSING=
for O in $OUTF ; do
- log "checking: $O"
if [ ! -f "$DIR/$O" ]; then
if [ "$MISSING" == "" ]; then
MISSING=$O
@@ -421,12 +433,12 @@
logstate "MOVING_OUTPUTS $OUTF"
for O in $OUTF ; do
- log "output: $O ${CDM_OUTPUTS}"
- if [ $( eval echo "$"$( echo CDM_OUTPUT_$O ) ) != "SKIP" ]; then
- mv "$DIR/$O" "$WFDIR/shared/$O" 2>&1 >& "$INFO"
- checkError 254 "Failed to move output file $O to shared directory"
+ log "output: $O"
+ if ! contains SKIPPED_OUTPUT $O ; then
+ mv -v "$DIR/$O" "$WFDIR/shared/$O" 2>&1 >& "$INFO"
+ checkError 254 "Failed to move output file $O to shared directory"
else
- log "CDM: SKIP OUTPUT: $O"
+ log "CDM: SKIPPED_OUTPUT: $O"
fi
done
@@ -445,10 +457,14 @@
closeinfo
if [ "X$PROGRESSIVE_INFO" == "X" ] && [ "X$SCRATCH" != "X" ]; then
- mkdir -p "$WFDIR/info/$JOBDIR"
+ mkdir -p "$WFDIR/info/$JOBDIR"
mv "$INFODIR/${ID}-info" "$WFDIR/info/$JOBDIR/${ID}-info"
fi
# ensure we exit with a 0 after a successful execution
exit 0
+# Local Variables:
+# mode: sh
+# sh-basic-offset: 8
+# End:
More information about the Swift-commit
