[Swift-commit] r3830 - in trunk/tests: groups providers providers/ssh providers/ssh-pbs-coasters
noreply at svn.ci.uchicago.edu
Mon Dec 27 17:45:24 CST 2010
Author: davidk
Date: 2010-12-27 17:45:22 -0600 (Mon, 27 Dec 2010)
New Revision: 3830
Added:
trunk/tests/groups/group-ssh.sh
trunk/tests/providers/ssh-pbs-coasters/
trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.check.sh
trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.setup.sh
trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.swift
trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.timeout
trunk/tests/providers/ssh-pbs-coasters/README
trunk/tests/providers/ssh-pbs-coasters/catsn.0001.out.expected
trunk/tests/providers/ssh-pbs-coasters/catsn.0002.out.expected
trunk/tests/providers/ssh-pbs-coasters/catsn.0003.out.expected
trunk/tests/providers/ssh-pbs-coasters/catsn.0004.out.expected
trunk/tests/providers/ssh-pbs-coasters/catsn.0005.out.expected
trunk/tests/providers/ssh-pbs-coasters/catsn.0006.out.expected
trunk/tests/providers/ssh-pbs-coasters/catsn.0007.out.expected
trunk/tests/providers/ssh-pbs-coasters/catsn.0008.out.expected
trunk/tests/providers/ssh-pbs-coasters/catsn.0009.out.expected
trunk/tests/providers/ssh-pbs-coasters/catsn.0010.out.expected
trunk/tests/providers/ssh-pbs-coasters/data.txt
trunk/tests/providers/ssh-pbs-coasters/sites.template.xml
trunk/tests/providers/ssh-pbs-coasters/tc.template.data
trunk/tests/providers/ssh-pbs-coasters/title.txt
trunk/tests/providers/ssh/
trunk/tests/providers/ssh/001-catsn-ssh.check.sh
trunk/tests/providers/ssh/001-catsn-ssh.setup.sh
trunk/tests/providers/ssh/001-catsn-ssh.swift
trunk/tests/providers/ssh/001-catsn-ssh.timeout
trunk/tests/providers/ssh/README
trunk/tests/providers/ssh/catsn.0001.out.expected
trunk/tests/providers/ssh/catsn.0002.out.expected
trunk/tests/providers/ssh/catsn.0003.out.expected
trunk/tests/providers/ssh/catsn.0004.out.expected
trunk/tests/providers/ssh/catsn.0005.out.expected
trunk/tests/providers/ssh/catsn.0006.out.expected
trunk/tests/providers/ssh/catsn.0007.out.expected
trunk/tests/providers/ssh/catsn.0008.out.expected
trunk/tests/providers/ssh/catsn.0009.out.expected
trunk/tests/providers/ssh/catsn.0010.out.expected
trunk/tests/providers/ssh/data.txt
trunk/tests/providers/ssh/sites.template.xml
trunk/tests/providers/ssh/tc.template.data
trunk/tests/providers/ssh/title.txt
Log:
Provider tests for ssh and ssh:pbs with coasters
Added: trunk/tests/groups/group-ssh.sh
--- trunk/tests/groups/group-ssh.sh (rev 0)
+++ trunk/tests/groups/group-ssh.sh 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,7 @@
+# GROUPLIST definition to run sge tests
+GROUPLIST=(
+ $TESTDIR/providers/ssh \
+ $TESTDIR/providers/ssh-pbs-coasters \
Added: trunk/tests/providers/ssh/001-catsn-ssh.check.sh
--- trunk/tests/providers/ssh/001-catsn-ssh.check.sh (rev 0)
+++ trunk/tests/providers/ssh/001-catsn-ssh.check.sh 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+for count in `seq --format "%04.f" 1 1 10`
+do
+ [ -f catsn.$count.out ] || exit 1
+ CONTENTS1=$( cat catsn.$count.out.expected )
+ CONTENTS2=$( cat catsn.$count.out )
+ [[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
+done
+exit 0
Property changes on: trunk/tests/providers/ssh/001-catsn-ssh.check.sh
___________________________________________________________________
Added: trunk/tests/providers/ssh/001-catsn-ssh.setup.sh
--- trunk/tests/providers/ssh/001-catsn-ssh.setup.sh (rev 0)
+++ trunk/tests/providers/ssh/001-catsn-ssh.setup.sh 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,4 @@
+#!/bin/bash
+cp -v $GROUP/data.txt . || exit 1
+cp -v $GROUP/*expected . || exit 1
Property changes on: trunk/tests/providers/ssh/001-catsn-ssh.setup.sh
Added: trunk/tests/providers/ssh/001-catsn-ssh.swift
--- trunk/tests/providers/ssh/001-catsn-ssh.swift (rev 0)
+++ trunk/tests/providers/ssh/001-catsn-ssh.swift 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,15 @@
+type file;
+app (file o) cat (file i)
+ cat @i stdout=@o;
+string t = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
+string char[] = @strsplit(t, "");
+file out[]<simple_mapper; location=".", prefix="catsn.",suffix=".out">;
+foreach j in [1:@toint(@arg("n","10"))] {
+ file data<"data.txt">;
+ out[j] = cat(data);
Added: trunk/tests/providers/ssh/001-catsn-ssh.timeout
--- trunk/tests/providers/ssh/001-catsn-ssh.timeout (rev 0)
+++ trunk/tests/providers/ssh/001-catsn-ssh.timeout 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+500
Added: trunk/tests/providers/ssh/README
--- trunk/tests/providers/ssh/README (rev 0)
+++ trunk/tests/providers/ssh/README 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,2 @@
+May need to edit sites.template.xml file if work directory contained in $WORK differs on local and remote machines
+Requires auth.defaults to be set up correctly in ~/.ssh
Added: trunk/tests/providers/ssh/catsn.0001.out.expected
--- trunk/tests/providers/ssh/catsn.0001.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0001.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/catsn.0002.out.expected
--- trunk/tests/providers/ssh/catsn.0002.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0002.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/catsn.0003.out.expected
--- trunk/tests/providers/ssh/catsn.0003.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0003.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/catsn.0004.out.expected
--- trunk/tests/providers/ssh/catsn.0004.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0004.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/catsn.0005.out.expected
--- trunk/tests/providers/ssh/catsn.0005.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0005.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/catsn.0006.out.expected
--- trunk/tests/providers/ssh/catsn.0006.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0006.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/catsn.0007.out.expected
--- trunk/tests/providers/ssh/catsn.0007.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0007.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/catsn.0008.out.expected
--- trunk/tests/providers/ssh/catsn.0008.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0008.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/catsn.0009.out.expected
--- trunk/tests/providers/ssh/catsn.0009.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0009.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/catsn.0010.out.expected
--- trunk/tests/providers/ssh/catsn.0010.out.expected (rev 0)
+++ trunk/tests/providers/ssh/catsn.0010.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/data.txt
--- trunk/tests/providers/ssh/data.txt (rev 0)
+++ trunk/tests/providers/ssh/data.txt 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh/sites.template.xml
--- trunk/tests/providers/ssh/sites.template.xml (rev 0)
+++ trunk/tests/providers/ssh/sites.template.xml 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,8 @@
+<config>
+<pool handle="ssh">
+ <execution provider="ssh" url="login1.pads.ci.uchicago.edu" />
+ <filesystem provider="ssh" url="login1.pads.ci.uchicago.edu" />
+ <profile key="jobThrottle" namespace="karajan">0</profile>
+ <workdirectory>_WORK_</workdirectory>
+</pool>
+</config>
Added: trunk/tests/providers/ssh/tc.template.data
--- trunk/tests/providers/ssh/tc.template.data (rev 0)
+++ trunk/tests/providers/ssh/tc.template.data 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,8 @@
+ssh echo /bin/echo INSTALLED INTEL32::LINUX
+ssh cat /bin/cat INSTALLED INTEL32::LINUX
+ssh ls /bin/ls INSTALLED INTEL32::LINUX
+ssh grep /bin/grep INSTALLED INTEL32::LINUX
+ssh sort /bin/sort INSTALLED INTEL32::LINUX
+ssh paste /bin/paste INSTALLED INTEL32::LINUX
+ssh wc /usr/bin/wc INSTALLED INTEL32::LINUX
Added: trunk/tests/providers/ssh/title.txt
--- trunk/tests/providers/ssh/title.txt (rev 0)
+++ trunk/tests/providers/ssh/title.txt 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+SSH Configuration Test
Added: trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.check.sh
--- trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.check.sh (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.check.sh 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+do
+done
+exit 0
Property changes on: trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.check.sh
Added: trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.setup.sh
--- trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.setup.sh (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.setup.sh 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,4 @@
+#!/bin/bash
Property changes on: trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.setup.sh
Added: trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.swift
--- trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.swift (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.swift 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,15 @@
+type file;
+ cat @i stdout=@o;
Added: trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.timeout
--- trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.timeout (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/001-catsn-ssh-pbs-coasters.timeout 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+500
Added: trunk/tests/providers/ssh-pbs-coasters/README
--- trunk/tests/providers/ssh-pbs-coasters/README (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/README 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,3 @@
+Requires a valid proxy - run grid-proxy-init before running this test if you haven't already
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0001.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0001.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0001.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0002.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0002.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0002.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0003.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0003.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0003.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0004.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0004.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0004.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0005.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0005.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0005.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0006.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0006.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0006.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0007.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0007.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0007.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0008.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0008.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0008.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0009.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0009.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0009.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/catsn.0010.out.expected
--- trunk/tests/providers/ssh-pbs-coasters/catsn.0010.out.expected (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/catsn.0010.out.expected 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/data.txt
--- trunk/tests/providers/ssh-pbs-coasters/data.txt (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/data.txt 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/ssh-pbs-coasters/sites.template.xml
--- trunk/tests/providers/ssh-pbs-coasters/sites.template.xml (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/sites.template.xml 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,15 @@
+<config>
+<pool handle="ssh-pbs-coasters">
+ <execution jobmanager="ssh:pbs" provider="coaster" url="login1.pads.ci.uchicago.edu" />
+ <profile key="maxtime" namespace="globus">3000</profile>
+ <profile key="workersPerNode" namespace="globus">8</profile>
+ <profile key="slots" namespace="globus">1</profile>
+ <profile key="nodeGranularity" namespace="globus">1</profile>
+ <profile key="maxNodes" namespace="globus">10</profile>
+ <profile key="queue" namespace="globus">short</profile>
+ <profile key="jobThrottle" namespace="karajan">0.5</profile>
+ <profile key="initialScore" namespace="karajan">10000</profile>
+</pool>
+</config>
Added: trunk/tests/providers/ssh-pbs-coasters/tc.template.data
--- trunk/tests/providers/ssh-pbs-coasters/tc.template.data (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/tc.template.data 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1,8 @@
+ssh-pbs-coasters echo /bin/echo INSTALLED INTEL32::LINUX
+ssh-pbs-coasters cat /bin/cat INSTALLED INTEL32::LINUX
+ssh-pbs-coasters ls /bin/ls INSTALLED INTEL32::LINUX
+ssh-pbs-coasters grep /bin/grep INSTALLED INTEL32::LINUX
+ssh-pbs-coasters sort /bin/sort INSTALLED INTEL32::LINUX
+ssh-pbs-coasters paste /bin/paste INSTALLED INTEL32::LINUX
+ssh-pbs-coasters wc /usr/bin/wc INSTALLED INTEL32::LINUX
Added: trunk/tests/providers/ssh-pbs-coasters/title.txt
--- trunk/tests/providers/ssh-pbs-coasters/title.txt (rev 0)
+++ trunk/tests/providers/ssh-pbs-coasters/title.txt 2010-12-27 23:45:22 UTC (rev 3830)
@@ -0,0 +1 @@
+SSH with PBS and Coasters Configuration Test
More information about the Swift-commit
