[Swift-commit] r3826 - usertools/mpich
noreply at svn.ci.uchicago.edu
Thu Dec 23 12:45:16 CST 2010
Author: wozniak
Date: 2010-12-23 12:45:16 -0600 (Thu, 23 Dec 2010)
New Revision: 3826
Added:
usertools/mpich/mpich2-r7562.diff
Modified:
usertools/mpich/README.txt
Log:
New working MPICH patch for MPICH/Coasters
Modified: usertools/mpich/README.txt
--- usertools/mpich/README.txt 2010-12-23 18:36:52 UTC (rev 3825)
+++ usertools/mpich/README.txt 2010-12-23 18:45:16 UTC (rev 3826)
@@ -1,5 +1,10 @@
+See: http://www.ci.uchicago.edu/wiki/bin/view/SWFT/CoastersMpi
Contains the following patches:
-mpich2-1.3.diff
+mpich2-r7562.diff: works with MPICH2, revision 7562
-See: http://www.ci.uchicago.edu/wiki/bin/view/SWFT/CoastersMpi
+mpich2-1.3.diff: obsolete due to MPICH changes
Added: usertools/mpich/mpich2-r7562.diff
--- usertools/mpich/mpich2-r7562.diff (rev 0)
+++ usertools/mpich/mpich2-r7562.diff 2010-12-23 18:45:16 UTC (rev 3826)
@@ -0,0 +1,144 @@
+Index: src/pm/hydra/tools/bootstrap/external/external_init.c
+--- src/pm/hydra/tools/bootstrap/external/external_init.c (revision 7562)
++++ src/pm/hydra/tools/bootstrap/external/external_init.c (working copy)
+@@ -52,6 +52,9 @@
+ if (!strcmp(HYDT_bsci_info.launcher, "ll"))
+ HYDT_bsci_fns.launch_procs = HYDT_bscd_ll_launch_procs;
++ if (!strcmp(HYDT_bsci_info.launcher, "none"))
++ HYDT_bsci_fns.launch_procs = HYDT_bscd_none_launch_procs;
+ /* for everything else, set default values */
+ if (HYDT_bsci_fns.launch_procs == NULL)
+ HYDT_bsci_fns.launch_procs = HYDT_bscd_external_launch_procs;
+@@ -102,6 +105,11 @@
+ return external_launcher_init();
++HYD_status HYDT_bsci_launcher_none_init(void)
++ return external_launcher_init();
+ HYD_status HYDT_bsci_rmk_lsf_init(void)
+ return external_rmk_init();
+@@ -131,3 +139,4 @@
+Index: src/pm/hydra/tools/bootstrap/external/external_launch.c
+--- src/pm/hydra/tools/bootstrap/external/external_launch.c (revision 7562)
++++ src/pm/hydra/tools/bootstrap/external/external_launch.c (working copy)
+@@ -4,6 +4,8 @@
+ * See COPYRIGHT in top-level directory.
++#include "assert.h"
+ #include "hydra_utils.h"
+ #include "bsci.h"
+ #include "bscu.h"
+@@ -313,3 +315,28 @@
+ fn_fail:
+ goto fn_exit;
++HYD_status HYDT_bscd_none_launch_procs(char **args, struct HYD_node *node_list,
++ int *control_fd, int enable_stdin)
++ int i, proxy_id_index;
++ struct HYD_node *node;
++ char *proxy_id_string;
++ proxy_id_string = HYDU_malloc(16);
++ for (i = 0; args[i] != NULL; ) {
++ i++;
++ proxy_id_index = i;
++ args[proxy_id_index+1] = NULL;
++ for (i = 0, node = node_list; node; node = node->next, i++) {
++ assert(!strcmp(HYDT_bsci_info.launcher, "none"));
++ printf("HYDRA_NONE_LINE: ");
++ sprintf(proxy_id_string, "%d", i);
++ args[proxy_id_index] = proxy_id_string;
++ HYDU_print_strlist(args);
++ printf("HYDRA_NONE_END:\n");
++ fflush(stdout);
+Index: src/pm/hydra/tools/bootstrap/external/external.h
+--- src/pm/hydra/tools/bootstrap/external/external.h (revision 7562)
++++ src/pm/hydra/tools/bootstrap/external/external.h (working copy)
+@@ -20,4 +20,9 @@
+ HYD_status HYDT_bscd_external_query_env_inherit(const char *env_name, int *ret);
+ HYD_status HYDT_bscd_external_query_native_int(int *ret);
++ struct HYD_node *node_list,
++ int *control_fd,
++ int enable_stdin);
+ #endif /* EXTERNAL_H_INCLUDED */
+Index: src/pm/hydra/utils/args/args.c
+--- src/pm/hydra/utils/args/args.c (revision 7562)
++++ src/pm/hydra/utils/args/args.c (working copy)
+@@ -112,7 +112,8 @@
+ status = m->handler_fn(arg, argv_p);
+- HYDU_ERR_POP(status, "match handler returned error\n");
++ HYDU_ERR_POP(status, "match handler returned error (for %s)\n",
++ arg);
+ break;
+ m++;
+Index: src/pm/hydra/configure.in
+--- src/pm/hydra/configure.in (revision 7562)
++++ src/pm/hydra/configure.in (working copy)
+@@ -211,6 +211,7 @@
+ hydra_bss_none=true
+ available_bss=`echo $available_bss none`
+ available_rmks=`echo $available_rmks none`
++ available_launchers=`echo $available_launchers none`
+@@ -357,7 +358,7 @@
+ have_plpa=yes
+ AC_DEFINE(HAVE_PLPA,1,[Define if plpa is available])
+ fi
+ hwloc)
+ if test "$with_hwloc_prefix" = "embedded" ; then
+ PAC_CONFIG_SUBDIR([tools/bind/hwloc/hwloc],[have_hwloc=yes],[have_hwloc=no])
+@@ -428,7 +429,7 @@
+ AC_DEFINE(HAVE_BLCR,1,[Define if blcr is available])
+ available_ckpointlibs=`echo $available_ckpointlibs blcr`
+ fi
+ esac
+Index: src/pm/hydra/pm/pmiserv/pmip_cb.c
+--- src/pm/hydra/pm/pmiserv/pmip_cb.c (revision 7562)
++++ src/pm/hydra/pm/pmiserv/pmip_cb.c (working copy)
+@@ -715,7 +715,7 @@
+ cpuset);
+ HYDU_ERR_POP(status, "create process returned error\n");
+- if (HYD_pmcd_pmip.system_global.enable_stdin) {
++ if (HYD_pmcd_pmip.system_global.enable_stdin && 0) {
+ stdin_fd = STDIN_FILENO;
+ status = HYDT_dmx_register_fd(1, &stdin_fd, HYD_POLLIN,
+ (void *) (size_t) STDIN_FILENO, stdio_cb);
More information about the Swift-commit
