[Swift-commit] r3815 - trunk/tests
Tue Dec 21 15:35:32 CST 2010
Author: wozniak
Date: 2010-12-21 15:35:32 -0600 (Tue, 21 Dec 2010)
New Revision: 3815
Modified:
   trunk/tests/meta.sh
   trunk/tests/nightly.sh
Log:
Additional notes
Modified: trunk/tests/meta.sh
--- trunk/tests/meta.sh	2010-12-21 21:13:44 UTC (rev 3814)
+++ trunk/tests/meta.sh	2010-12-21 21:35:32 UTC (rev 3815)
@@ -8,3 +8,5 @@
 ssh intrepid.alcf.anl.gov $DIR/run-nightly.sh groups/group-intrepid.sh
+# Retrieve results
+# scp ...
Modified: trunk/tests/nightly.sh
--- trunk/tests/nightly.sh	2010-12-21 21:13:44 UTC (rev 3814)
+++ trunk/tests/nightly.sh	2010-12-21 21:35:32 UTC (rev 3815)
@@ -6,6 +6,8 @@
 # subdirectory called run-DATE, and generate useful HTML output and
 # tests.log
+# Usage: nightly.sh <options>* <GROUPLIST>
 # Run nightly.sh -h for quick help
 # When something goes wrong, find and check tests.log or use -v
 # Code is checked out into TOPDIR (PWD by default) (PATH is not used)
@@ -54,7 +56,7 @@
 # Background processes are used so that hung Swift jobs can be killed
 # These are the background processes (PIDs are tracked)
 # Note that PID management has not yet been perfected.  Check ps
-# in error cases.
+# in error cases, especially if you kill nightly.sh .
 # nightly.sh
 # +-monitor()
